  #46
Old 09-07-2009, 05:10 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Quote:
Originally Posted by Vasbinder View Post
Is it the only heater in the engine?
On a LB7 YES
Unless you count the glow plugs
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #47
Old 09-07-2009, 05:22 PM
Vasbinder's Avatar
Vasbinder Vasbinder is offline
Default
So I can pull it out and It will still start in cold weather. It don't get that cold down here maybe get in the 20's
__________________
2011 Duramax
  #48
Old 09-07-2009, 05:25 PM
That's better
Default
Pull it out,If you have troubles( doubtfull) re-install it for winter
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #49
Old 03-16-2018, 02:47 PM
Kutch87 Kutch87 is offline
FNG
Default Obd2 or others
Do they make a handheld to reset or turn codes values to zero? I really do t want to buy a efi live system at the moment but want to delete ahi and get. Something like a obd2 reader that can turn codes off permanently
  #50
Old 03-16-2018, 03:13 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
No it will have to be disabled thru efi live. I unhooked mine and I never got a code unless it was below 50 degrees or so. If you get a OBD2 reader you can erase the code everytime it comes on....you dug pretty deep in the library for this thread
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #51
Old 03-17-2018, 05:00 AM
FNG
Default
I was just on Google looking up stuff and this thread that I'm a member on popped up. Plus I haven't seen where to start a thread.
  #52
Old 03-17-2018, 06:56 AM
Noreaster's Avatar
Noreaster Noreaster is offline
Default
Its been such a long time since I deleted mine but seem to remember reading that guys were wiring up a light bulb to give it some resistance & not throw a code
This was way back before efilive was readily available, try looking at posts & threads from atleast 10 years ago
__________________
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #53
Old 03-17-2018, 08:11 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
The ecm just needs to see the circuit pulled to ground to stop it from coding. A cheap incandescent bulb(led may nothave enough loading to ground) connected to the iah wire will stop codes. All that will happen is the light will come on when the iah should which will complete the circuit to keep the ecm happy.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #54
Old 04-12-2018, 11:52 AM
kellock kellock is offline
Gearhead
Default dummy load
Quote:
Originally Posted by Turbotug View Post
I have plugged mine and disabled it with EFILive, but it still shows around 5v while the truck is running..
Go buy a cheap lighted off on switch hook it up to thr power wire for source for th deleted heater ground it and leave it in the on position you can then erase the code and it will not come on again
  #55
Old 04-12-2018, 03:32 PM
Gearhead
Default intake heaters
Hey soution for deleting code is running a dummy load tae up hotwire from heater buy cheap off/on lighted switch connect one side to power wire from heater run ground wire from the other side making line hot when u start truck it will trick puter into hinking all is well and will not throw code then erace code wih a simple code reader
  #56
Old 04-13-2018, 06:41 AM
77cruiser 77cruiser is offline
Gearhead
Default
I deleted mine & did the light bulb trick & so far no code. But mine didn't get a code for glow plugs with one side unhooked & all of them not working on the other side.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
