  #16
Old 12-29-2017, 05:51 AM
jpowel29's Avatar
jpowel29 jpowel29 is offline
Default
Reply sent
__________________
Trying some new things...
  #17
Old 01-10-2018, 08:20 AM
jpowel29's Avatar
Default
LLY turbo w/vane sensor - $400
LLY crankshaft - $300
LLY rods - $150
New GM standard bore piston ring set - PN 97250331 (GM 97386951) - $285
LLY Balancer - $40
LLY Std Bore Block - $600
LBZ Upper/Lower Valve covers - $100 each side
LBZ Y-Bridge - $40
LBZ Rear Cover - $100
Coolant Crossover Bridge and Thermostat HSG - $45
LBZ Rods - $150
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
LBZ Fuel Rails, Rail Pressure Sensor, and Hardlines - $375
LBZ CP3 w/regulator - $300
__________________
  #18
Old 01-15-2018, 12:27 PM
jpowel29's Avatar
Default
Also available
Fresh set of LLY heads. Cleaned, inspected, professional valve job and blend, all new SoCal beehive springs, retainers, valve seals, and spring seat/shims. Can also provide rocker arm assemblies, intake runners, y bridge, valve covers, etc to make a more complete top end.
$1400 for the heads.
__________________
  #19
Old 01-15-2018, 04:40 PM
jpowel29's Avatar
Default
LBZ Crank and LLY turbo are sold.
Fresh set of LLY heads (just redone with SoCal Beehive spring kit) - $1400
LLY rods - $120
LLY cam - $125
LLY Balancer - $25
LLY Flexplate - $50
LBZ Y-Bridge - $40
LBZ Rods - $150
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
__________________
  #20
Old 01-20-2018, 01:44 PM
jpowel29's Avatar
Default
LBZ rods sold
LLY rods - $120
LLY cam - $125
LLY Balancer - $25
LLY Flexplate - $50
LBZ Std Bore Block - $450
LBZ Y-Bridge - $40
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
__________________
  #21
Old 02-01-2018, 04:15 AM
jpowel29's Avatar
Default
LLY rods - $120
LLY cam - $125
LLY Exhaust Manifolds (DR and PASS) - $40
LLY Balancer - $25
LLY Flexplate - $50
LBZ Y-Bridge - $40
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
__________________
  #22
Old 02-02-2018, 11:59 AM
jpowel29's Avatar
Default
LLY Exhaust Manifolds are sold
LLY Turbo - very nice core - $400
Fresh from cylinder head shop - set of LLY heads (just redone with fresh valve job, seals, and SoCal Beehive spring kit) - $1400
LLY rods - $120
LLY cam - $125
LLY Balancer - $25
LLY Flexplate - $50
LBZ Std Bore Block - $425 (will need to go .020" over)
LBZ Welded Y-Bridge - $125
LBZ Cam - $125
LBZ Flexplate - $40
LBZ Balancer - $40
__________________
  #23
Old 02-05-2018, 11:16 AM
jpowel29's Avatar
Default
LBZ CP3 is in good condition with around 110k miles on it. Removed from my CCSB when I swapped over to a stroker pump. Turns over freely by hand and is stored in a sealed plastic bag with fresh diesel inside the pump. Includes a good regulator and has the drive gear and block adapter.
__________________
  #24
Old 02-13-2018, 08:15 AM
jpowel29's Avatar
Default
Prices are OBO and do not include shipping or Paypal fees. Blocks and crankshafts will ship LTL freight (banded and shrink wrapped on a pallet). Just about everything else can go regular ground shipping. Buyer has the option to arrange shipping on their end as well.
__________________
  #25
Old Yesterday, 06:28 AM
jpowel29's Avatar
Default
LLY crankshaft - $275
LLY rods - $100
LLY cam - $100
LLY Balancer - $25
LLY Flexplate - $40
LBZ Std Bore Block - $400(will need to go .020" over)
Coolant Crossover Bridge and Thermostat HSG - $40
LBZ Cam - $100
LBZ Flexplate - $40
LBZ Balancer - $40
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
