  #31
Old 05-30-2014, 10:54 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Taylor your a Friggin chemist
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #32
Old 05-30-2014, 11:00 PM
Burn Down's Avatar
Default
Quote:
Originally Posted by Mpsoldier View Post
Lift daily endurance really 2weeks heavy weight 1 week high reps. Ever sense deployment it gives me a challenge on what I can do and how to relieve stress in a positive way. My only goal is to hit 200pds. I am 6'1" and 193 now, but cut up not fat well only a little. My legs are the strong point, squat 315 for 8 and leg press 975 for 8.
Good job on the squating! It really is one of my weak points but I have only been doing them for less than a year. I have come along way in 9 months. I just don't want to be the guy in the gym that has to wear sweat pants cause he has small leg and calf syndrome
__________________
03 Reg Cab ZF 6
  #33
Old 05-30-2014, 11:06 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Quote:
Originally Posted by Burn Down View Post
Thanks!
No judgement here, as I stated before it's not a magic shot that you take and wake up the next day Jacked, you still have to bust your ass, it just amplifies your hard work/results.
Only reason I ask about it is because I'm very ignorant about them. I would like to here pros and cons from people that have first hand knowledge You know the old saying "I can get a good look at a T-bone by sticking my head up a cows ass but I would rather just ask the butcher"
Well if you get the urge to try it out, start with test! It's safe and it works.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #34
Old 05-30-2014, 11:16 PM
Burn Down's Avatar
Default
Quote:
I have thought about it, at 39 I'm sure my natural test is dropping pretty fast. I can tell a difference in my results, much slower than when I was 18... Maybe after my powerlifting meet in the fall?
I toyed with powerlifting in the fall and trying to do a bodybuilding show the following summer or just jump head first into the olympic lifts. I will feel it out after this fall.
__________________
03 Reg Cab ZF 6
  #35
Old 05-31-2014, 01:44 AM
micky's Avatar
micky micky is offline
FNG
Default
I Powerlifted from 1978 -1993 with Australian Drug Free Association
I broke 63 State and National Records in 82.5kg, 90kg, 100kg and 110kg Divisions. Best Lifting weight was 82.5kg (181 lb)
Best Comp Lifts at 82.5 bodyweight were Squat 322.5kg (711 lbs) Bench 212kg (467 lbs) Deadlift 317 kg (700 lbs) Total 825 kg (2648 lbs)
Never used the (Gear) Still train 3 times a week at my own gym. 67 yo this year
My opinion if You want to grow muscle go for a mix of mainly repwork with a few heavy doubles or singles periodically. You want to get strong then go for as much weight under 6 reps in shortest possible workout time then recover. Heavy lifting knocks the body around energy wise. After a Comp I wouldn't touch a weight for 3 weeks before starting a new cycle. I believe weight training is still one of the best things for the body
  #36
Old 05-31-2014, 03:55 AM
LWATSON's Avatar
LWATSON LWATSON is offline
future trans limpers
Default
Any of you guys have issues with acne? I was doing test, tren, and HGH. Ive dropped the test and tren and just doing HGH now and its clearing up fast. Any suggestions?
__________________
Landon-2006 Silverado CCSB 4X4 LBZ
Rebuilt engine by Burkett Racing Engines
LBZ rods,.20 over LB7 pistons, head studs, balanced rotating assembly.
Exergy 12 mil stroker pump/ Exergy 200 overs
S475/88 hybrid compounds, turbos specked by Mark @ Danville Performance, Kit built by myself and Moparkxracer "Shade Tree Triples"
Cylinder Pressure/Dyno tuning by Danville Performance
Trans built by Diesel Addiction/ 1072-2 Limitless Diesel converter
  #37
Old 05-31-2014, 06:12 AM
WolfLLY's Avatar
Making Chips
Default
I had some mild acne on my back. I mean MiLD. Two weeks of accutane killed it.
__________________
LB7 ECSB 4X4
  #38
Old 05-31-2014, 07:57 AM
Taylor-34's Avatar
Taylor-34 Taylor-34 is offline
Default
Quote:
The acne usually comes because your levels were off, what mg were you running your test base at? What was the ace at? Was it every day or EOD pins? Test prop or enenthate?
There are two ways you can run that cycle, you can run your ace just under your test like 500mg test a week 400mg ace a week or a badass new way is to run your test with test prop and only run 450mg a week and your ace at 550mg a week.. Just run cabergoline with it to help with Tren dick
__________________
2011 Ex cab SB 4wd LML 4" FLO PRO exh. EFI Live PPEI tuning, FTS leveling kit, Kryptonite UCAs, Fox 2.0 shocks,
2011 Single cab LB LML
Sold~~2005 CCSB 4wd LLY~~
  #39
Old 05-31-2014, 07:59 AM
Taylor-34's Avatar
Default
lol you guys are def in my comfort zone now.. Anybody feel free to PM or text me I can help as much as my knowledge will allow..
Oh and sorry don't know how to group quotes into one reply off if my phone..
__________________
  #40
Old 05-31-2014, 08:19 AM
RENODMAX's Avatar
RENODMAX RENODMAX is offline
Dead Wrong
Default
5'9" 185
squat 325x2
Deadlift 405x2
Bench TBD
only been doing this since january
__________________
2014 Silvy 1500 CCSB- mostly stock fishing rig
2004 LB7 CCSB
Built trans, tuning, fabbed stuff by me- SOLD
  #41
Old 05-31-2014, 08:23 AM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
I'm all natural so far nothing against it. I thought about it 1000 times just never pulled the trigger. I'm 24 so I think I probably got a good amount of test in me already. Seems like everyone does it and it obviously helps. My thing is its money I can't drop in the old dmax!
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #42
Old 05-31-2014, 08:28 AM
Taylor-34's Avatar
Default
Ya it sucks both ways, either can spend the money on gettin big or can spend the money on my baby running good ha..
__________________
  #43
Old 05-31-2014, 08:33 AM
Taylor-34's Avatar
Default
Quote:
Originally Posted by RENODMAX View Post
5'9" 185
squat 325x2
Deadlift 405x2
Bench TBD
Must have some good genetics.. I know everybody loves to bench as much weight as they can because that's one of the staple alpha male lifts but what are your goals?
If you're tryin to get cut up now for summer try doing DB flat incline decline presses as well as flyes.. It will give you a more isolated workout for your chest as well as work your slow twitch muscle fibers stab izing the dumbbells through the movement..
__________________
  #44
Old 05-31-2014, 08:45 AM
indiana_jones's Avatar
indiana_jones indiana_jones is offline
LargeFarva
Default
great workout today. got out of bed hungover, slammed a qdoba breakfast burrito, and headed to work. damn i need to get back in shape
__________________
07 Classic Sierra 2500HD 4x4 LBZ EC/SB. Banks 6-gun tuner, Banks 4" exhaust, Banks intake, 45 Gallon tank, FASS 95GPH Titanium lift pump.
  #45
Old 05-31-2014, 08:48 AM
LWATSON's Avatar
Default
I'm very lacking on the tech side lol. A friend hooked me up and advised me on what and when to take. I took a test blend, I think it was a blend of 3 types, 400 mg every Monday. Tren, don't remember the exact mg but took 1 cc EOD. And the GH I'm only using .2 cc a day of that, tried more but hands hurt like a bitch at night.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
