  #16
Old 05-30-2014, 06:26 PM
Dirtymaxx03's Avatar
Dirtymaxx03 Dirtymaxx03 is offline
Default
Look at power lifters. A guy weighing 200lbs needs to bench 500, squat 700 and deadlift 600lbs...to be somewhat competitive. That's alotta weight for not alotta man. So I give mad respect to those guys.
__________________
Sean
2003 Lb7
Efi Live
The Rabbit-build in progress
1984 2wd SB c10
Quote:
Originally Posted by hondarider552 View Post
big balls if you measure in seconds of duration
  #17
Old 05-30-2014, 06:39 PM
Andrew's Avatar
Andrew Andrew is offline
Costly Obsessions
Default
Quote:
Originally Posted by Burn Down View Post
Andrew if it's healed and there isn't any chips floating around in there have your Ortho guy look it over, If he says its healed and no chips.... Man Up!
Just start with simple arm raises and some light stretching, slowly add stuff in there and listen to your body
The Gym has literally given me a new purpose in life. I truly love it, all of it. I can embrace all disciplines and totally respect people who try... You don't have to be a beast, just try
Haha yea might be time to go back. The chip of bone is outside of the socket but were it chipped off is inside so its constantly inflamed cause I can't lay around that long. But after reading all you've messed up then hell I know its time to man up I'm an over achiver when it comes to them things im a firm believer in pushing yourself till you cant anymore then go further. I'm 6ft an 250 but not nearly as toned as I used to be. I'd be happy just to tone back up lol
__________________
2007 lbz 2500hd built trans built motor efi by moonshine big thanks to all my friends an family helping me achieve this an for all the info you guys on here have donated to me
  #18
Old 05-30-2014, 07:03 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Quote:
I agree. Have you ever watched Richard the Ant Hawthorne lift? The guy has to be pound for pound the strongest man I have ever seen...
  #19
Old 05-30-2014, 09:51 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
5'11 185lbs 10% BF. I never measured it but all abs are chiseled out. Lifting stats are while I was on 500mg of test per week. I noticed while on test I could eat anything I wanted and not gain any fat, although the guys on bodybuilding forum say test has ZERO effect on fat loss.
DL 475
Squat 375 gotta work on that one
Bench 305, although I hit 295 4 times the other day.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #20
Old 05-30-2014, 09:56 PM
WolfLLY's Avatar
Making Chips
Default
I also noticed I developed big veins while on test. Also gonna throw this out there, I got NO sides from that cycle other than the, unavoidable one. My wife thought that I would roid rage all the time lol, but she told me she likes me on test haha. Women
__________________
LB7 ECSB 4X4
  #21
Old 05-30-2014, 09:57 PM
Burn Down's Avatar
Default
Quote:
DL 475
Those are some good numbers. You got me by 55 pounds on squat and 50 on Deads good work
I'm guessing your bench has come up some as well 315/320ish.
Just over the counter test or doctor prescribed?
  #22
Old 05-30-2014, 10:08 PM
WolfLLY's Avatar
Making Chips
Default
UGL test, AI, and proper Post Cycle Therapy. No over the counter test state side bro
__________________
LB7 ECSB 4X4
  #23
Old 05-30-2014, 10:17 PM
Taylor-34's Avatar
Taylor-34 Taylor-34 is offline
Default
At 500mg of test a week you really won't see much more than aggression as far as sides, it's the compounds you add in that imbalance you and cause the side effects.
Test doesnt effect your metabolism, but it does effect the nutrients your body absorbs from the food intake as well as your core temp by less than half a degree but that is enough to burn the fat..
Also you can get a script for trt from a doc. The dosages are prescribed at about 250mg which is perfect for cruising but if you wanted to say "stock up" it isn't hard to gather enough for a blast n cruise... Easiest way is to go tell your doc at your physical that you have no sex drive, you're always lethargic, lil depressed about yourself and you don't know why.. He will send you in for blood work and you just so happen to have come off cycle three weeks prior and didn't run a PCT and your test levels will be low enough he will sign that pen so fast.. Truck is convincing him you don't want androgel.. My I mean a friends excuse was that they have a few small children and they are too worried it could rub onto their skin...
__________________
2011 Ex cab SB 4wd LML 4" FLO PRO exh. EFI Live PPEI tuning, FTS leveling kit, Kryptonite UCAs, Fox 2.0 shocks,
2011 Single cab LB LML
Sold~~2005 CCSB 4wd LLY~~
  #24
Old 05-30-2014, 10:18 PM
WolfLLY's Avatar
Making Chips
Default
I'm not endorsing AAS, just giving my feedback.
I should have achieved those stats naturally before starting anything. BurnDown, Man that's awesome you did it the right way, definitely put in some hard work.
__________________
LB7 ECSB 4X4
  #25
Old 05-30-2014, 10:20 PM
WolfLLY's Avatar
Making Chips
Default
Tell me about your experiences? I was considering NPP next time.
__________________
LB7 ECSB 4X4
  #26
Old 05-30-2014, 10:28 PM
Taylor-34's Avatar
Default
I've "reasearched" every compound under the sun, have stacked, blast cruise you name it I have been lucky enough to have run tests on it
Currently on blast with t e s t E 750mg a week with T r e n A c e 50mg a day and 2iu hygetropin H G H..
NPP is great esp people like me with joint issues, I try and save it for my winter cycle tho because it's a wetter compound.. So Tes E at 500 and N P P at 400 a week mixed in with Injectable D- Bol at 75mg a day would be somethjng a winter bulker might like..
Within your goals right now tho I would really look into EQ will give you moderate strength gains but the endurance levels go though the roof while on...
__________________
  #27
Old 05-30-2014, 10:32 PM
WolfLLY's Avatar
Making Chips
Default
I'm going to bulk hardcore this winter. You like oral dbol? I mean heck I like my liver but is four weeks really gonna hurt it bad? I've read where it stacks on muscle faster than injectable dbol
__________________
LB7 ECSB 4X4
  #28
Old 05-30-2014, 10:38 PM
Taylor-34's Avatar
Default
Well in my experience oral is rough on the liver yes but injecting juice into your muscles is just as rough on your liver.. The reason i prefer inj is because 1 you can run lower doses with more efficiency because it will be absorbed into your blood stream and less will pass through the liver thus being filtered out, but 2 the more important factor is it doesn't make you retain every ounce of damn water you look at the way oral D Bol does, a lot of guys still say well hell that's what Dbol is for to look big.. Well ya, but I don't need to look like I'm in 3rd grade again trying to lose 10 pounds of baby fat in my face... M
Tur ana bol is somethjng you might wanna look into as well if you are like me and concerned about water retention it's basically the same compound but has shown to hold even less water via oral ingestion
__________________
  #29
Old 05-30-2014, 10:44 PM
Taylor-34's Avatar
Default
Last winter I weighed 215 9% bf doing 130 dumb bell flies 160# DB presses and 900# leg press..
Now my priorities changed I'm down to 187 10% bf at 5'10 been at this size since March and have been really happy so I doubt I will ever do another bulk, I like my clean eating and cheat days but I'm just kind of burnt out on being big and losing all my flexibility esp with climbing poles for a living..
I think when I hit 40 I wanna be at 215 12-14% bf and ride that out but right now I'll stick with my 18" T. Rex arms
__________________
  #30
Old 05-30-2014, 10:50 PM
Burn Down's Avatar
Default
Thanks!
No judgement here, as I stated before it's not a magic shot that you take and wake up the next day Jacked, you still have to bust your ass, it just amplifies your hard work/results.
Only reason I ask about it is because I'm very ignorant about them. I would like to here pros and cons from people that have first hand knowledge You know the old saying "I can get a good look at a T-bone by sticking my head up a cows ass but I would rather just ask the butcher"
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
