  #5716
Old 02-12-2018, 08:31 AM
minerigger's Avatar
minerigger minerigger is offline
Default
Was it your 1058 chris
Sent from my SM-G930V using Tapatalk
__________________
Brock
06 LBZ ECLB
Gauges, Danville Tunes, 5" Dumped, Trans by Evan, DP Stg2r, Sleeved/Braced and some other odds and ends crap that we all have
  #5717
Old 02-12-2018, 07:44 PM
minerigger's Avatar
Default
Started it for first time in 6 weeks. Hit high idle...man I love that sound. Then went to store with the boys. Then went to the interstate. 0-110 with alot of on ramp left. This thing is such much more responsive than this 15 work truck is. I'd have to see an equally done up lml or l5p to even think about switching
__________________
Brock
06 LBZ ECLB
  #5718
Old 02-12-2018, 08:58 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Deleted max effort with solenoid mod they are quite nasty...
__________________
2001 LB7 ECSB SL Built trans, batmo, lbz cp3, everything else, etc... Sold...
2006 LBZ CCSB SLT < My first, Superchips Flashpac... Sold...
2008 LMM CCSB SLT < Blue beast. way too much to list.... Sold...
2015 LML CCSB Denali < Lifted 20's/35's Deleted Airdog ETC. Sold...
2016 LML CCSB Denali < Lifted 22's/35's >I officially need help.
2010 1500 RCSB Denali clone <Lifted 22's/33's, 5.3, 6L80, TVS1900, Mayhem tuned, etc ...
2015 Corvette Stingray LT3 White on Black
  #5719
Old 02-12-2018, 10:03 PM
AZlml's Avatar
AZlml AZlml is offline
Default
Quote:
Will the trans actually hold with the solenoid mod on a max effort tune? Or is this like a "once in a blue moon run it on a max effort tune and pray for the best" type of scenario?
__________________
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
  #5720
Old 02-12-2018, 11:31 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
I think mines hurt and I have the solenoid mod, mines not even max effort. It's max on the factory fuel system with no lift pump. 2nd-4th lots of rpm with not a whole lot of go anymore and that's in tow haul with the converter locked, at least I think I need to get some logs to double check maybe the converters hurt to .
Without tow haul it blasts through the converter high revy no go
__________________
04 LB7 ECSB Built motor, Wagler narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #5721
Old 02-13-2018, 02:59 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
Sky View Imaging
Default
That blows... Literally... It come apart and clog everything up?
No. I caught it early. It started acting strange on high idle a few days ago. Then I noticed it wanting to load up after it’s warm when you’re on the brakes. It still drives and locks up fine.
Yep. 55k miles on it. I think all the highidle this year didn’t help.
__________________
06 Chevy LBZ
Olympic White • Built Motor/Trans • Bullseye s375 • 45% Injectors • Stock CP3 • Built and Tuned by Blackout Performance 11.76@115.12
08 BMW 528xi
Alpine White • Brown Dakota Leather • Premium/Cold/Smoker Pkg • LED AEs • MTec D1S • 50% tint
2000 Buick Regal GS
Bright White • Lowered • Homemade CAI • 4500K HIDs • Supercharged • Beater
  #5722
Old 02-13-2018, 05:44 AM
Default
Quote:
My 15 did fine, no issues in the 58k I had it. It was deleted at 5k I think, I set it on max effort and took it off it a few times to pull boats to Florida. I had a lift pump, full deletes and solenoid mod, truck was solid and very strong, I haven't deleted my 16 yet only bc I like how quiet it is. The deleted LML's seem extra loud to me compared to the LMM or lbz...
__________________
  #5723
Old 02-13-2018, 06:31 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is online now
Yes, its really me
Default
The solenoid mod is a short term bandaid.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #5724
Old 02-13-2018, 07:18 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
the c3's will get full main line pressure now instead of control pressure like the older years and the solenoid helps give you all that pressure but at the end of the day, you still are on 4 clutches in there and these clutches are not meant for abuse. the LML also wont limp as easy as the older trucks as it will instead start pulling power back if it senses slight slip. the trans and ecm will work well together to keep you from killing it quickly but this means you leave alot of power left on the table with the stock trans.
__________________
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #5725
Old 02-16-2018, 05:26 AM
Nathan.'s Avatar
Nathan. Nathan. is offline
Default
Removed my fender flares. There was all kinds of stuff that fell out of them upon removal!
__________________
2005 Sierra CC LLY
2006 Jetta TDI BRM
  #5726
Old 02-16-2018, 07:06 PM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
Default
Changed the oil and rain-x'ed the windshield
Sent from my SAMSUNG-SM-G930A using Tapatalk
__________________
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
  #5727
Old Yesterday, 02:52 PM
M.A.M.'s Avatar
M.A.M. M.A.M. is offline
Default
Getting close to dropping it back in... still got the harness to run, acc brackets, and drill/tap the upper oil pan for the oil drain...
  #5728
Old Yesterday, 08:44 PM
Gotboost06 Gotboost06 is offline
FNG
Default
Lost steering again..
Reply
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
