Old 04-16-2012, 09:25 PM
super diesel's Avatar
super diesel super diesel is offline
<<<< Under Pressure
Default For your consideration. New SD "TT" Center link
This new adjustable center link from SD has the ability of DD (daily driving) style steering set up. SF (Street Fighter Mode) which is about the same as the Kryptonite and Exaxt steering setup. Or the unbeatable straight line performance of the solid SS Straight Center link that so many are using today. This new "TT" CL is made of solid 1.5" dia 316SS which is now twice as strong and comes with inner tie rod wrench, 4 extra greese zerks, 4 tie rod end plugs for the locations that aren't in use, and as always, the puller. Never before has the steering of the Duramax been so adjustable! Best of all the straight SS CLs from SD and PPE can also be converted to this set up if so desired to add versatility to your steering. More accessories will follow soon for this. PM me for pricing and info.
FOR REAL POWER: Remove the static wire from ovulation bearing and let her run!
McRat Racing, SoCal Diesel, Ridge Runner, Mike L. Special, PPE, Creatures of the Night Performance
Michael
OIL COOLING CLUB
CC LB7 4X4 Dually GMC with Fluidyne oil cooler
CC LLY 4X4 3500 SRW with oil cooling coming (stock with a few goodies)
Currently for street driving and towing GT4202 and Dual Fueler from PPE
Carrillo rods, Heads, balancing, cut pistons, Head studs, Injector clamps from Guy at SoCal
Tune by Tony at Ridge Runner (Clark Kent special)
Moded LBZ CP3s and special fuel system by Super Diesel
SC Trans w/snake oiler and cooler by Mike L.
Blowoff and Wastegate by Tial
Various machining touches, built and fabed by Super Diesel
Broke motor #2 becomes built motor #4
New motor and trans oil purifiers available (dual and single elements) and vital fluid cooling components. Start saving your truck today!
SUPER DIESEL 720-404-7553 Please leave message if no answer.
Old 04-16-2012, 09:37 PM
BLKLMM's Avatar
BLKLMM BLKLMM is offline
<<< Slow Mamba
Mamba
Special thanks to...
Rob @ MK Chevrolet
Mike L. @ Inglewood Transmissions
Dan @ PPE
Kory Willis @ Power Performance
Will Petty @ Troll Performance Tuning
Steve @ SS Diesel Tuning
Ben @ BT Diesel Works
McRats
10.62@134
Born 1/21/12
SOCAL DIESEL TRUCKS
Old 04-16-2012, 09:39 PM
Dan@PPE's Avatar
Dan@PPE Dan@PPE is offline
Diesel Enthusiast
Always thinking ahead!!!
2500HD CC/SB LB7 2 Wheel drive 950+ RWHP
11.17@126 in the 1/4 with a 7.2x@100 in the 1/8th.
NEW BEST in the 1/8th 6.95@102, 10's Here I come!!
2500HD CC/LB LB7 4X4, Towpig
2500HD RC/LB 4X4.............. 9 seconds of fury!!!
Pushing the D to the MAX........
Old 04-16-2012, 10:12 PM
cafryer's Avatar
cafryer cafryer is offline
looks killer.
Chavis, 2001 rc/lb Lots of air, Lots of fuel, Lots of spray.
2003 rc/lb zf6 South bend dual disk 64/75 compounds 30% injectors
Old 04-16-2012, 10:32 PM
Burn Down's Avatar
Nice! pm sent
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
Old 04-17-2012, 06:24 AM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
How does the conversion work?
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
Old 04-17-2012, 06:49 AM
<<<< Under Pressure
Travis. You just need to send the straight CL to me for retro fit. I Tig weld it on there with deep welds and on the proper angles. The accessories (wrench, plugs, and greese zerks) comes with it too.
Michael
OIL COOLING CLUB
Old 04-17-2012, 07:20 AM
Chevy1925's Avatar
now we need a super diesel one off super brace kit . cool idea though Michael, adjustability is always nice
James
best time to date: 12.39
Tailgate Crew Member #4
  #9
Old 04-17-2012, 07:28 AM
03badmaxxx's Avatar
03badmaxxx 03badmaxxx is offline
Ghost Element
Looks sweet!
Semi-built motor, ball bearing spinners, fire hydrants, SunCoast COMP trans
Andrew J Murdock
Account Manager // Brand Strategist
The BrandSmith Co.
Andrew@thebrandsmithco.com
  #10
Old 04-17-2012, 07:29 AM
<<<< Under Pressure
I'm working on a brace now James.
Thanks guys. No more swapping out CLs. This one does it all and is the best of both worlds.
The pics don't do it justice. It's far better in person.
Michael
OIL COOLING CLUB
  #11
Old 04-17-2012, 08:01 AM
Chevy1925's Avatar
sweet, very interested to see what you come up with
James
  #12
Old 04-17-2012, 08:54 AM
770JOHNNYW 770JOHNNYW is offline
how much are these bad boys?
  #13
Old 04-17-2012, 09:01 AM
snowman's Avatar
snowman snowman is offline
Evil Diesel Performance
looks good!
Cale
2006 EC/LB 2500HD 4x4, Fine Silver Birch. EV2's boost, pyro, rail, Homemade 3.5inch DP, 5inch with dual 6inch tips ,Danville GT3794va w/BatMo Wheel, PPE fuel fittings, PPE Dual Fueler, Industrial Injection 20% injectors, FASS 150, custom intake and y-bridge, GMax-6 with upgrades, sun coast 1058, EFI Live by Walls Rod Custom, Custom drop shackles, turned down keys, Novakanes 20x9 Stealth, 305/50 Zeons, 722hp, 1296ft/lbs
Stock trans., and converter 12.99@101 1/4
Built trans 8.092@85.64mph 1/8 stock turbo, stock fuel.
  #14
Old 04-17-2012, 09:12 AM
Tank222's Avatar
Tank222 Tank222 is offline
Man, just put a regular one on my truck about 2 weeks ago.
F250 6.7
  #15
Old 04-17-2012, 09:39 AM
crazycrew's Avatar
crazycrew crazycrew is offline
Let's Start A Riot
please PM me with a price Michael
Brooks Landry
2013 Silverado, Plasti Dipped front bowtie, Naked tailgate
SOLD'05 CC 4x4, 5" Straight, EFI live, Cognito tie rods and braces, Rancho 9000 XL, bumper lift, PPE shim, JVC 840, 3" shackles, T & B Fab traction bars, 20" H2's, PPE V, Precision ML, FASS Titanium 150, S475 w/race cover over stock, 3" y bridge, afe hot pipe
One Big Ass Mistake America
Closed Thread
