  #1
Old 09-03-2017, 11:02 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default Airdog 165 pump
Went out today to leave and noticed when I turned on the key I did not hear the lift pump. No blown fuses and I have 12v at the pump with the key on. Problem is I bought the truck with the airdog on it, so I have no clue about the warranty card. Anyone else get them to replace the pump?
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #2
Old 09-03-2017, 11:52 AM
Awenta's Avatar
Awenta Awenta is offline
Default
Doesn't hurt to call and give the serial. Their warranty is really good. If not they will probably sell you a replacement 4g pump for like 200$ so it's worth it either way
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #3
Old 09-03-2017, 11:55 AM
Default
I think mine is 3-4 years old...
__________________
  #4
Old 09-03-2017, 01:07 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
No warranty if your not the original buyer or the card didn't get mailed in. You can buy a new pump and get the warranty again.
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #5
Old 09-03-2017, 04:29 PM
KRODMAX/KS's Avatar
KRODMAX/KS KRODMAX/KS is offline
Gearhead
Default
If AD is not able to warranty your pump; sure they will. I have an updated 165 that have on the bench that I will make a deal on. I upgraded to the 165 4G. The one I have is a year old.
__________________
06 CCSB
Carrillo's, Fingers cast w 37mm reliefs 17:1, ARP, SoCal 3388AF cam, flex-plate, dampner & springs, M/A push rods, DHD y-bridge, coupler & lock-up box, Danville Billet 68R1, motor mounts & water pump, Energy 10mm, 45% over inj, Airdog 4G 165, AFE, Banks, Mag-Hytec, ProFab Tow-flows, MBRP, Magnaflow, QA1, Cognito, McGaughys, CalTracs, TruTrac, AC Delco Extreme duty rotors, LML 20" & Nitto 305/50/20 420's
Motor built by Danville/tuned by Mark
Mike L Built Trans w billet shafts, hub and "K" converter
758HP/1441ftlbs
  #6
Old 09-03-2017, 05:52 PM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Default
Quote:
I bought my 165 II in 13'
What's the update?
__________________
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
  #7
Old 09-03-2017, 05:54 PM
Novak's Avatar
Default
Warranty is only applicable if the original receipt was sent in within 30 days of purchase
__________________
2008 LMM :SOLD 2/18
  #8
Old 09-03-2017, 05:59 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
with it out of warranty, it shouldn't hurt to open it up and see if there is something simple like debris stuck in the impeller.
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #9
Old 09-03-2017, 08:19 PM
Default
It hasn't popped the fuse but the pump def isn't running. I will have to get the serial number off of it, I'm not sure exactly how old it is. Pm me about the other airdog
__________________
  #10
Old 09-03-2017, 09:18 PM
Frogman1's Avatar
Frogman1 Frogman1 is offline
FROGMAN1
Default
Just got to cover the basics just incase and because it's an aftermarket private install. I just wired my Airdog II 165 and ran mine for the hummer about 45 days ago. Going over the basics is always worth a detailed look, especially since they say theirs lasts forever, and it wasn't you who hooked it up initially. As far as fuses and wiring, obviously, it works off a keyed hot circuit, usually plugged into a fuse in the engine compartment. 1. if you've traced the wires back, and all are intact, not fried against a rub point or the exhaust, etc., I've heard of shorts from mice nesting and eating the wires underneath the fusebox in there. 2. Have you unplugged the connection at the pump, checked the pins to ensure they aren't corroded, or just not quite plugged in all the way to make the connection? Put a small amount of electrical grease on them when you check. 3. Check the wired grounds. I believe that even though the pump mounts to the frame, it's a wired ground. 4. have you tried hot wiring the pump off of a continuous hot line? 5. any chance something significant could have been sucked up and lodged into the pump? perhaps an angry X-girlfriend or jealous husband? http://www.duramaxdiesels.com/forum/...es/roflmao.gif 6. Pull the pump. It's all quick connect lines and 4 Allen head small bolts and direct wire to a battery, inspect for obvious external signs, research the easy to do rebuild kit online and go from there. 7. Call Airdog and ask them why their Airdog pump has been running for 5 years straight and yours won't run for 10 minutes to get you down to the beer store and back? All seriousness; Do look online and find out as much as you can about the pumps, wiring, etc. so you have a better understanding of possible issues and solutions.
Best, Ralph
  #11
Old 09-04-2017, 06:57 AM
KRODMAX/KS's Avatar
Gearhead
Default
"Update" brand new motor, not part of the group of motors that were trash to many of us.
__________________
06 CCSB
758HP/1441ftlbs
  #12
Old 09-04-2017, 07:04 AM
Default
I checked the fuses and relay. I have 12v at the pump the pump just isn't running. I can pull the pump and check it. It just pisses me off cuz the airdog might be 4 years old but the truck only has 38k miles on it. The airdog may have 15k miles on it. Doesn't it go thru the filter before the pump? If so I wouldn't think dirt is in it. I run the Donaldson filter
__________________
  #13
Old 09-04-2017, 07:18 AM
KRODMAX/KS's Avatar
Gearhead
Default
Call AD with the serial number, they will tell you if it was part of the bad batch. And give you options, I would sell my 165 for half the cost of a new motor. If you end up having to pay out of pocket.
__________________
06 CCSB
758HP/1441ftlbs
  #14
Old 09-04-2017, 11:26 AM
Default
Pulled pump apart. Motor is def shot. I'd post a pic but Photobucket is such a c!nt now. Not paying to link pics
__________________
  #15
Old 09-04-2017, 01:33 PM
2004LB7's Avatar
Default
upload them here
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
