Old 07-12-2017, 12:24 PM
RonC RonC is offline
FNG
Default beside myself after first trans fluid change
I have a 2006 silverado 2500 hd with the allison trans and its my toy hauler for my showcars and yesterday I had its first fluid change since I bought it new.It only has 40k miles and I had just finished a trip back from Kentucky to pick up my neices rv trailer.So being the trans was never serviced I decided to take it to the dealer that has taken care of my truck since new.Boy I would never think that would have any regrets but my truck trans temp after the service is running above the normal range that it was running with the original fluid!! Withe the original fluid NOT TOWING it would stay about 150 160 and towing my trailer with my showcar (about 8k lbs) would run about 200 degrees and maybe 220 uphill.Now without towing its running 180 and sometimes allmost 200. Is the dextron 6 fluid different than the original dextron 6 that the factory put in my truck when new? The dipstick says use dextron 6 so its not a early trans that was built before dex 6.Anyone else have this problem? Its driveing me crazy!!
Old 07-12-2017, 12:25 PM
PureHybrid's Avatar
Isuzu Shakes IT
Check to see if it's overfilled
Jesse
Old 07-12-2017, 12:30 PM
FNG
Level is ok right in the high temp cross hatches. Its really crazy that would change the operating temp with just a fluid change
Old 07-12-2017, 01:01 PM
Chevy1925's Avatar
where in the high temp cross hatches and how hot is the trans when you are checking it? these trans are temperamental on fluid level. was both the internal and external filter changed? how was the fluid changed out?
James
best time to date: 12.39
Tailgate Crew Member #4
Old 07-12-2017, 01:08 PM
RickDLance's Avatar
RickDLance RickDLance is offline
Check to make sure the spin on filter is a factory Allison part.
www.ProFabPerformance.com
We also handle S & B filters, Air Dog lift pumps, American Eagle wheels, and Kraftwerks Superchargers.
On my 20th Duramax & still Loving them!
Old 07-12-2017, 02:20 PM
FNG
temp was 185 190 and in the middle of the hot hash marks. Both filters were changed with GM parts. The external filter I change every year and that has never affected anything before.The dealer did a drain and internal filter and replaced with dex 6. truck was allways serviced at the same dealer. would the transyn from castrol run cooler? Im leaning towards the fact that GM might have changed the dextron 6 since 2006.
Old 07-12-2017, 02:46 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Take a quart out of it and see if there is a change. Spin on filter has no effect on temps. It is a low pressure filter on a separate circuit.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 07-13-2017, 01:07 AM
FNG
Im taking it out for a drive with the trailer and will see what happens because I will be going to the Menards chevy show Sunday at Maple Grove dragway in Pa.
  #9
Old 07-13-2017, 12:04 PM
FNG
loaded the trailer up and so far ok.I guess the level might have been lower before the service when the factory filled the trans.Didnt know level would affect temp that way on this trans.
  #10
Old 07-13-2017, 01:22 PM
WVRigrat05's Avatar
Wound for sound
Level can affect it 20-30 degrees
Reger
100k miles. Piston eater.
  #11
Old 07-14-2017, 07:31 AM
FNG
Thanks all.I did drain 1 quart and that made the difference.
  #12
Old 07-14-2017, 07:51 AM
Balindir's Avatar
Balindir Balindir is offline
Rod shortning in progress
Just out of curiosity. Is the spin on filter only for the valve body circuit? and the pan filter for the main fluid to the clutches and TC?
-Travis
Moonshine | s475 | Suncoast | Airdog | Studs | Braces | Sleeves | Traction bars |
  #13
Old 07-14-2017, 08:13 AM
Mike L.'s Avatar
Correct.
Spin on filter works off of 125 PSI max as the solenoids cannot handle anything above that. It is called the control pressure circuit.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #14
Old 07-14-2017, 11:17 AM
Balindir's Avatar
Correct.
Learn something new everyday! I always wondered why there were 2 filters, Thanks for info!
-Travis
  #15
Old 07-17-2017, 02:11 AM
FNG
Just got back from the Menards chevy show and the truck ran great trans temp stayed around 170 and was never an issue.Thanks again for your suggestions and info.Ron
