  #106
Old 04-18-2018, 05:33 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<that’s not me...
The fuse for the glow plugs is beneath the actual fuse box. Need to take it off and ohm it out. May fix that issue. Need to get that sensor back where it should be. If you’ve got blocker plates chances are a stock tune was flashed into it and there’s that issue fixed too.
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s.
2011 Yamaha YFZ450X
2003 Yamaha YZ250
  #107
Old 04-18-2018, 06:00 PM
MolonLabe420 MolonLabe420 is offline
DirtyMax
Ok so maybe the plastic cover comes off to expose that fuse. What sensor "needs to be back where it should be"? The truck came with an Edge CS is the glovebox. When I plugged it in, it said there was no CELs and that it was on economy level. Is there a way to tell it there are blocker plates on, or is that a whole tune type of thing?
I have a few pictures to post quick
4/4/18 - Bought my 1st diesel
2003 GMC Sierra 2500HD - Crew Cab, Short Bed
LB7, Auto, 4x4, Plain A$$ Interior, 135k
Thank You Mr. Trump!
God Bless America <3
  #108
Old 04-18-2018, 06:05 PM
zakkb787's Avatar
<that’s not me...
Maybe it’s just me but the pressure sensor you posted doesn’t look like it’s in anything. If the truck has blocker plates the edge won’t delete so there is those codes. And yes the plastic cover comes off to expose the fuse.
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
  #109
Old 04-18-2018, 06:08 PM
DirtyMax
  #110
Old 04-18-2018, 06:18 PM
DirtyMax
The 1st picture I posted is the 122 sensor that isnt clipped to anything but has a hose going to the intake I believe. The 2nd picture is that relay I pulled out... that whole unit isn't bolted to anything, just laying there. Looks like 2 bolts, with metal sleeves, could be a ground for that unit. What should it be bolted to? I dont think I see anything in that area it could go on...
  #111
Old 04-18-2018, 06:37 PM
JoshH's Avatar
JoshH JoshH is offline
The truck had an EGR, but it has been deleted. That much I can see very easily in the pictures. It must not have been tuned for the delete. That could explain the EGR and the MAF codes.
06 Silverado 4x4 CC/SB
  #112
Old 04-18-2018, 09:03 PM
ChrisPerry's Avatar
The unit with the 2 hollow metal sleeves is the intake heater control . The intake heater is already removed and pluged, I can see that in one picture. Where do the wires go? Looks like one is bolted to the back of the alternator.
Thats the p0540 code.....
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
  #113
Old 04-18-2018, 09:26 PM
ChrisPerry's Avatar
In the first pic, the 122 sensor clips to the tab right above it in the pic. The tab is just bent up , should be at a 90 straight down from where it's bolted on.
I know you said the MAF looks clean, but you need to spray it down with MAF cleaner. You have an oiled filter, chances are it's been contaminated with oil from the filter.
