Old 05-26-2018, 01:33 AM
CRAWLEN CRAWLEN is offline
Gearhead
Default Head gasket Grade
currently doing a mild lmm engine build nothing big. just head studs,af cam and a few other bits. to make it safer to handle a bigger turbo in the future.
my question is tho, what grade head gaskets to use ? have heard different things from the biggest ones or just staying what grade is in the engine. i am going to be getting the heads decked.
so am i better going 1 grade bigger or staying the same grade any info is much appreciated
Old 05-26-2018, 06:52 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
I would measure when you get the rotating assembly in and mine was decked/touched up. I bought grade C's just cause then ended up putting in a B & A after measuring so now I have a set of C's laying around.
Edit: missed the part were your just getting the heads cleaned up not the block so you will likely just need what you had taken out but still measure the guy that assembled could have miss measured to.
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
Old 05-26-2018, 07:10 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Just do grade Cs
2006 ccsb Lbz Tow rig
2006 rclb 6.6
Old 05-26-2018, 07:51 AM
WVRigrat05's Avatar
Wound for sound
I almost ordered what was in mine but just ended up doing C’s.
Reger
100k miles. Piston eater.
Old 05-27-2018, 07:56 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Originally Posted by Ne-max View Post
Just do grade Cs
Why do you say that instead of checking the clearance and getting the right ones?
06 GMC 2500 CCSB SLT LBZ 4X4
