Old 04-23-2018, 10:28 AM
Kentucky DuraMax's Avatar
Kentucky DuraMax Kentucky DuraMax is offline
Gearhead
Default SoCal damper
Looking to buy a used SoCal damper(harmonic balancer) for LBZ.
Old 04-23-2018, 12:20 PM
Bbuchanan11's Avatar
Bbuchanan11 Bbuchanan11 is offline
Gearhead
I have an ati which should be the same as SoCal.
06 Silverado lbz 11.77 @115 sold
17 Silverado L5P ltz custom sport stock
06 gmc built motor/ trans dual fuelers 60 overs 75 over 66, 5600lbs... track times coming soon
Old 04-23-2018, 02:26 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
I have one also, pm me what you would be willing to pay for it if you want.
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
Old 04-27-2018, 02:15 AM
Gearhead
Thanks for the replies and I know they are basically the same but I would still like to get the SoCal brand
Old 04-27-2018, 02:54 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
DMax-less
They are identical. Only difference is the sticker.
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12 SOLD
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
Old 04-27-2018, 06:39 AM
Bdsankey Bdsankey is offline
Kentucky DuraMax, they are LEGIT the same balancer other than one has a SoCal sticker on it.
Also, might be a good idea to fill out your signature to tell us what year/model engine you have as LB7/LLY are one PN, LBZ/LMM are another, and LML is different as well.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 04-27-2018, 06:48 AM
torqued2dmax's Avatar
He said LBZ
05 CC/LB DRW LLY Allison
Old 04-27-2018, 06:49 AM
Originally Posted by torqued2dmax View Post
He said LBZ
It feels like a Monday haha, my bad. Been busy trying to get my motor assembled before I take time off for UCC.
Current Rides:
Past Rides:
  #9
Old 04-27-2018, 06:53 AM
And it looks like you are doing a great job on your new build !
  #10
Old 04-27-2018, 06:55 AM
Thank you! Glad to see people reading it. Fought the rings but finally got that problem licked and all 8 rod/piston assemblies are in the block and lightly bolted to the crank (they aren't at final tq).
Back to topic, seriously tho, they are the same balancer and you're just paying for the SoCal name.
Current Rides:
Past Rides:
  #11
Old 04-27-2018, 06:38 PM
Gearhead
If your still looking I’ll sell you thst ati still... let me know
