  #31
Old 07-07-2015, 06:09 PM
RichLMM's Avatar
RichLMM RichLMM is offline
Originally Posted by x MadMAX DIESEL View Post
Mine bends to the side. And press it all the way to the floor. It's a swap though, so it doesn't have the weld on bracket on top. But the guy I know who broke them was the test dummy for their some of their clutches, he spent all season not even getting off the line cause of issues.
I can barely move my truck because of pedal flex I gotta figure something out
2001 2.6 truck the other woman
2013-2014 shootout productions 2.6 points champ
thanks to caleb baker@blackout performance
  #32
Old 07-07-2015, 06:13 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
I know it sucks! I actually have a piece of all thread ran down to it from the dash frame. But it still sucks.
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #33
Old 07-08-2015, 05:07 AM
RichLMM's Avatar
I just ordered the weld on piece from the dealer the other day I hope it helps
  #34
Old 07-08-2015, 05:42 AM
zf>allison's Avatar
zf>allison zf>allison is online now
you never had your car.
Part #?
05 2500 hd common rails,
Reg cab zf6/MANual transmission
Arp studs and grade c's, welded water pump, 45% nozzles, bolted mounts, weighted Dual disc south bend, efi live, fass, sportsman, afe intake elbow, 3 inch bridge and cold side ic pipe, pcv reroute and egr delete, 4" fenderwell dump exhaust, caltracs, and a lincoln locker, weight reduction
285/60/17 toyo proxes on lmm wheels
Down on 2 leaves, t bolts gone.
new best
12.310 @111.52mph 1.79 60ft stock turbo
Instagram-636zf6
  #35
Old 07-08-2015, 06:54 AM
RichLMM's Avatar
dealer has 15313209 for the bracket and 11517182 for the bolt
  #36
Old 07-08-2015, 07:50 AM
zf>allison's Avatar
Just stiffens it up?
new best
Instagram-636zf6
  #37
Old 07-08-2015, 08:36 AM
02greysixer's Avatar
02greysixer 02greysixer is offline
Your truck has it already. Us converts have nothing supporting the top rear of the pedal assy. Good to know you can buy that bracket. I'll have to do that too
Sent from my SAMSUNG-SM-G870A using Tapatalk
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
  #38
Old 07-08-2015, 08:37 AM
<<<< No Horsepower
I bought it too. But then I started to tear it down to weld it in and put it back together lol. Like seriously everything on the dash has to come out
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
Manual Mafia
  #39
Old 07-08-2015, 10:30 AM
RichLMM's Avatar
I still have the heater box etc in my truck I guess this is a good time to remove it all like I've wanted to do
  #40
Old 01-11-2016, 06:18 AM
Mikesmithdmax Mikesmithdmax is offline
FNG
Sorry fellas I had forgotten all about posting this on here, I scrapped this original idea on the last truck I replaced the pedal in... the new design utilizes the stock push rod and ball on the master cylinder... this way you won't have to do any wire splicing or cutting on your truck. I've only made 3 pedals for local guys, and the one in my last zf6 truck. First 2 had the safety switch disabled, but the latest design I did it on a 6.0 5 speed truck, everything is 100% custom fabbed, and compared to the one I posted pictures of on here, the new design is engineered much better. I have an idea also for a kit that will use your stock plastic pedal arm, you'll have to drill the pivot point out for a supplied bushing, remove your pedal bracket, install my steel bracket. And push the new steel piviot pin thru the assembly. Just an idea, but im thinking itd be a more economical fix for most guys.
I'm not sure how to exactly go about selling anything on the net.... I do have a PayPal account from eBay. Maybe one of yall maybe able to help,
Be patient with me on replying, I've got 1000 different things going on, and honestly don't have a chance to get on here a whole lot. My email is -------- mike199067@ymail.com thanks for the intrest
  #41
Old 12-29-2016, 08:23 AM
MervZF6 MervZF6 is offline
FNG
Hey can I still get this pedal,I need one asap!
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
