  #1
Old 07-09-2018, 03:14 PM
DOINSND's Avatar
DOINSND DOINSND is offline
FNG
Default 2005 LLY Swap into 2003 LB7 Cold Intake Problem
I have a 2003 Lb7 Duramax. I put a 2005 LLY engine in it. And I installed a 2006 LBZ mouthpiece on it.
My question is I need to install a Cold air intake box and tubing into the 2003 truck. So the MAF is from a 2003 -2005 uses the the same MAF. The only problem is the 2006 MAF is different style bolt up. So all the after market 2006 intakes tubes won't work with the 2005 MAF.
Can I run the 2006 MAF with my 2005 wiring.
Thank you
I have EFI live in the truck
  #2
Old 07-09-2018, 04:12 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
I don’t know on the maf being able to be made to work, I doubt it. The only piece guys use is the lbz mouthpiece with an lly air tube and lly air box. The mouthpiece and tube don’t line up super well but it works.
__________________
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #3
Old 07-09-2018, 06:43 PM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
smokinum
Default
01-07 MAF “bolt up” the same, but LBZ MAF is not the same internally. 07.5 LMM was a change in MAF style visually and bolt pattern
__________________
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #4
Old 07-09-2018, 09:11 PM
frankenstien's Avatar
frankenstien frankenstien is online now
Default
If I'm reading that correctly, you might have a completely different MAF?
I have a 2005 LLY, with a LBZ mp, and a LBZ S&B intake, I don't remember there being any issues with it bolting up, I didn't have to buy a different MAF, how ever, it did have to be rescaled for the larger intake tube.
I can grab a pic of the intake if you want
__________________
2005 ECSB LLY
Danville Tuned
5'' exhuast
Fass 150
Built Trans w/SC1058
Bumpers built by me
  #5
Old 07-10-2018, 08:59 AM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
Default
^ thats how ive read it on here. I also have a 04.5 lly and wanted to do an intake. Everything I read said go lbz and have it calibrated for that maf.
  #6
Old 07-10-2018, 06:30 PM
DOINSND's Avatar
FNG
Default
I thought it was a different MAF, it looks like they changed it after 2007 so it should work. MY BAD
  #7
Old 07-11-2018, 05:24 AM
LCAC_Man LCAC_Man is offline
Gearhead
Default
You will probably have to change your MAF voltage table, the difference is usually enough to kick a CEL.
__________________
Len Barron
2000 Express 155"wb Passenger Hightop
  #8
Old 07-11-2018, 10:21 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
You do have to modify the tune, but an lbz intake WILL work on an lly after the tune changes. It's one of the 1st upgrades I reccomend to lly owners. Even GM installed LBZ intake system's on lly overheater's, hence the factory tune file being available for the round air filter.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #9
Old 07-12-2018, 04:18 PM
DOINSND's Avatar
FNG
Default
I put a LBZ intake in and it worked fine. I did not change my MAF or tune. No codes yet
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
