  #31
Old 12-30-2011, 05:29 PM
Rosscup's Avatar
Rosscup Rosscup is offline
Gearhead
i either use power service or half a qt or so of ATF
02 LB7 CCSB
Built motor big twins and a lot of fuel
  #32
Old 12-30-2011, 06:32 PM
Dragonsfireloki Dragonsfireloki is offline
Stanadyne has my vote. I know merchant automotive sells it, xtreme diesel does also. You can find it pretty cheap on amazon too.
  #33
Old 12-30-2011, 10:47 PM
JD4440's Avatar
JD4440 JD4440 is offline
<< Lo-Carb Monster
I'm in the middle of testing the Amsoil treat / cetane combo. So far no different that the schaeffers 2000. I keep forgetting about opti-lube. I'll try it next
Chris
EFILive(Tuned by JoshH),SC IV,PPE,TTS,Big Dipper,Ect.
O.S. 6128--508hp/12.26@107.4 so far.......Thanks Josh
Originally Posted by Trentnell :
Politicians are the only people in the world who create problems and then campaign against them.
  #34
Old 01-22-2012, 05:29 PM
fctry286's Avatar
fctry286 fctry286 is offline
WhisperMax
Figure I would post this. I have been using PS with 2 stroke. Great results quite and I have been getting about 16 mpg. I just got a gallon of XPD opti lube, will post results when I start using it this week.
EFI live, PPE stage 5, PPE. stuff.
  #35
Old 01-22-2012, 06:02 PM
AubleAK's Avatar
AubleAK AubleAK is offline
stanadyne.
2001 Chevy Ext. Cab Short Bed
EFI Live by SS Diesel Tuning -
thanks Steve!
LBZ rods, ARP Head Studs, 475 over stock twins
4 Inch Turbo Back Straight Pipe
3 inch Downpipe
20" XD Monsters
Suncoast Gmax and Precision ML Converter - Built By Me
Airdog 165
Died 9/13/12 - broken valve
Born Again 12/16/12
Died again 1/9/13
2011 GMC Sierra SLT LML
stock- and staying that way
  #36
Old 01-22-2012, 06:54 PM
KarlLLY's Avatar
KarlLLY KarlLLY is offline
Smoky Hollow Forge
Stanadyne, every tank. I buy it off Ebay by the case
  #37
Old 01-22-2012, 07:10 PM
Dukw82ish's Avatar
Dukw82ish Dukw82ish is offline
FNG
1/2 quart atf in every tank.
  #38
Old 01-22-2012, 07:26 PM
JD4440's Avatar
<< Lo-Carb Monster
Please do. I gained about 1 mpg off my electric fans but nothing by switching to Amsoils product. I have about 3 more tankfulls of the stuff before I begin testing the opti-lube I have here.
Chris
  #39
Old 01-22-2012, 07:31 PM
ecc_33's Avatar
ecc_33 ecc_33 is offline
Junior Member
a gallon or so of atf every fill up. ( a fill up is usually up to 15 gallons nothing more) I have had up to 3 gallons of atf/hyd fluid in the tank and about 6 gallons of diesel fluid and my truck still ran perfectly fine. I know that is way over kill but i was tryin to get rid of some oil lol.
02 extra cab long bed
Thanks: CRANK IT UP DIESEL PPE ATS SUPER DIESEL MCRAT RACING
CREATURES OF THE NIGHT BES RACING
Carrillo rods, Hamilton valve springs, ATI damper, 60% bigger nozzles, head studs, S475 turbo, 4inch lift kit, ATS dual fueler, ATS Tranny,Bunch of SD parts,lobonte water injection, AD 165gph,
best time 11.63 at 116 49,200 miles
  #40
Old 01-25-2012, 01:36 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
I though about Hyd oil but its flash point is so much higher the diesel I was thinking it might not burn thoroughly and leave deposits.
06 GMC 2500 CCSB SLT LBZ 4X4
  #41
Old 01-25-2012, 02:06 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Its funny that even after unbiased tests people still have their own professional opinions...
Reminds me of the AMSOIL cheerleaders
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #42
Old 01-25-2012, 04:17 PM
RichLMM's Avatar
RichLMM RichLMM is offline
cenpeco fuel treatment here as well...took away the blue smoke on cold mornings on my girls 05 lly...
2001 2.6 truck the other woman
2013-2014 shootout productions 2.6 points champ
thanks to caleb baker@blackout performance
  #43
Old 08-07-2016, 04:49 PM
scorpion31 scorpion31 is offline
FNG
Best Additive Stanadyne lube formula! Marvel oil lubricate like 5-10micron this Stanadyne 157 micron check lab results. Next is Schaeffer Diesel treatment 2000 and last one is Amsoil diesel concentrate!
  #44
Old 12-05-2016, 12:30 PM
70ssclone 70ssclone is offline
josh
I run 2 stroke tcw3 from Walmart and a little bit of diesel kleen and to behonest my lly has had a lope/surge for a good while but if I consistently run 2 stroke oil in the fuel it disappears . Can anyone else attest to the same thing ?
05 lly ccsb , straightpiped mbrp 4in , efi live,autometer sport comp gauges, 20x10 fuel mavericks on 295 m/t , 160k and counting
  #45
Old 12-05-2016, 01:09 PM
fc8464 fc8464 is offline
Gearhead
I run 2stroke oil in the summer and white power service in the winter.
