  #16
Old 06-16-2010, 09:00 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
If you r thinking of hooking to the fitting under the shafer fitting it's going to be tough to find it's 16mm x 1.5 female
like I said allready keep it simple and use a 1/4 barb fitting and hook your hose to it 1/4 " will work well
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #17
Old 06-16-2010, 09:05 PM
That's better
Originally Posted by x MadMAX DIESEL View Post
I didnt mean to say rail, sorry. Be careful when using a 7/8 wrench on the schrader valve trying to unscrew from the aluminum fuel line. Use PB blaster on it to be sure you don't mess it up like me
But what are you talking about?
start by using metric wrenches he does not need to split it!!!! Just pull the assembly off ....... Done
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #18
Old 06-16-2010, 09:09 PM
That's better
Cut this off at the right spot and you don't even need a barb fitting
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #19
Old 06-16-2010, 09:10 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Ohh I didn't notice the LB7 had a different setup. On my LBZ you either unscrew the valve itself or get an adapter to the scrader.... there is no valve assembly line that unhooks from the fuel line. the valve is attached to the hard fuel line itself...
And as far as the 7/8, its close enough with a 6 point
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #20
Old 06-16-2010, 09:27 PM
That's better
Lb7/lly//lbz all different
I only recomemded this because it is easy and IMO
the best place to get LP press from on a LB7
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #21
Old 06-16-2010, 09:42 PM
<<<< No Horsepower
I concur, looks like the best way. I had no idea they were different.
Sorry for all the confusion I caused, I'll go back to my corner now
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
Manual Mafia
  #22
Old 04-15-2018, 08:24 PM
kellock kellock is offline
Gearhead
Default gauge
Originally Posted by Big Angry View Post
I got a fitting from Tony B that replaced that valve, and it was quick and easy, and my autometer 15psi fuel gauge plugged right in. Simple 10 minute job.
hi who is tony b can u remember the size an name of the fitting thanks in advance
  #23
Old 04-15-2018, 08:35 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is online now
6 posts before your new post:
If you had read the whole thread before posting, your question would have been answered. I'm glad that you are searching, and you are close, but stick with it, you'll find the info
  #24
Old 04-16-2018, 12:16 AM
LBZ's Avatar
LBZ LBZ is offline
Banjo to AN and other styles are available to go in place of that fitting.
https://www.pegasusautoracing.com/gr...D=PLUMADAP16MM
