i would like to hookup a vacuum gauge somewhere to check the life left on my fuel filter where can i do this thanks in advance for any info.
If you searched either this forum or Google, you would find that there is a test port at the front of your motor right next to the alternator. You can buy a gauge that clips on there to check vacuum at idle. Kennedy Diesel sells one, and probably a bunch of other places too.
Sent from my Cat S60 using Tapatalk |
https://www.kennedydiesel.com/detail.cfm?ID=289
http://www.duramaxdiesels.com/forum/...ad.php?t=24024
Tom "BBT" 2003 GMC CC/SB 4x4 12.14@111.15 "Flyin' Brick" 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation 2014 Chevy Cruze Diesel -- the DD Two wrongs dont make a right, but three rights do make a left. Reality is a matter of perspective. This forum isn't for the weak of heart.....or wallet. From mufflerguy on yb, "Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" |
![]() Quote:
You should have opened with wanting a permanent gauge. I'm not familiar with any kits off the top of my head, but you could piece one together. I'd be tempted to replace the bleed screw with a digital sensor and use a digital gauge inside the cab. You could run a tube all the way, but they tend to get damaged easily, then you have a vacuum leak and the truck won't start.
![]() Quote:
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold. Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install. EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe). Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission. ----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.---- 06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali 18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
