  #31
Old 03-13-2018, 04:06 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Does it crank a long time before starting? If so, watch rail pressure while cranking. I know LDS is a great company, but it isn't impossible for any good shop to have a bad injector sent out ever.
I think it sounds like bent rods could be a possibility. Compression check will tell the tale.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #32
Old 03-13-2018, 06:31 AM
stroke250's Avatar
stroke250 stroke250 is offline
I May Be Lost...
Agreed on the compression check.
Bent rods could very well be a possibility. My buddy had a similar issue and compression was low on his(I will note it was not drastically low/not much difference between cylinders). With everything else checking out on his, we pulled the motor and found a couple bent rods.
Ventured away from the diesel world currently... trying some gasser trash
  #33
Old 03-13-2018, 06:51 AM
danzick's Avatar
danzick danzick is offline
playing with fire
I thought bent rods as being a possibility, but I don't know how letting it sit would affect that? also, Its been acting like this since the injector install just not nearly as severe. AT the time all I had was some stock trans safe tuning from Kory. And I really haven't been beating on it much. No sled pulling or 1/4 mile runs or anything like that.
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #34
Old 03-13-2018, 07:35 AM
danzick's Avatar
playing with fire
Doesn't crank any longer that normal to start.
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #35
Old 03-13-2018, 03:51 PM
TheBac's Avatar
TheBac TheBac is offline
Im just kind of curious why you havent done any actual diagnosing other than to check balance rates?
Tom
  #36
Old 03-13-2018, 04:30 PM
danzick's Avatar
playing with fire
ive just been so busy building my own house/shop that I started in November there isn't really any time to do any diagnostics for me.
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
  #37
Old 03-15-2018, 06:38 PM
Been everywhere Been everywhere is offline
FNG
Originally Posted by danzick View Post
bringing this back up. I think this is from bad injectors. Ever since I put some garbage injectors from LDS in this thing a few years back it has never started right. I fired it up tonight after it has sat for 2 weeks. smoked like crazy and had a bad miss/knock. I started noticing it wasn't going away. One balance rate is at 15, and another one was at 5. it smoked like crazy driving until it hit around 140 on the ECT. Balance rates are ok when its at operating temp. I think these two injectors have been leaking into the cylinders since I installed them. This would explain why it always blows a ton of smoke at start up.
I used Merchant Automotive’s injectors when I replaced them in my crew cab last year and they’re great. Loved their deluxe install kit. I used their upgraded stock injectors.
Daniel / Big D *DPJug #14
2003 Chevy 2500HD Ex Cab SB D/A w/ 154k+
2003 Chevy 2500HD Crew Cab 4x4 D/A w/ 160k+ miles, sprayed Bedliner, B&W Turnover
2003 Chevy 2500HD Ex Cab D/A w/ 400k+ miles, Line X sprayed bedliner, 36 gal transfer tank, air foil, B&W Turnover w/ Fiver adp (bought new)
1994 Ford E350 Uhaul 17' box 7.3 diesel / auto 186k+ miles
Sold 1996 GMC 2500HD Ex Cab 6.5 TD w/ 343k+ miles, 3000lb adjustable overload springs, Ultimate sprayed bedliner (bought new)
K&N air filters & Optima batts in all and Prolong in the oil & trannys
2003 Hitchhiker II 30.5ft RLBG Fifthwheel w/ two slides
Previously owned 1994 Chevy 2500HD Ex Cab 6.5TD, put over 120k on it
Semper Fi :saluteusa: Overcome & adapt
  #38
Old 03-16-2018, 12:46 PM
torqued2dmax's Avatar
There have been a few cases on this site in the last few years that people have chimed in with , where they have said , why do I have 2 or 3 Qts extra oil on dip stick ? In those cases that I remember , with the help from people on this site , it was determined that a stuck injector ball that got dirt or rust from HP lines was the cause and the others were leaking return lines . Are you making any oil ?
05 CC/LB DRW LLY Allison
  #39
Old 03-16-2018, 12:59 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Stuck, bad, dirty or otherwise injector ball will cause high return rates but rarely if ever is associated with causing the fuel to get into the oil.
Cracked injector bodies or loose return lines on the injectors or even a seeping high pressure line at the injector could leak fuel into the oil. And bad seal on the CP3
Leaking nozzles could also wash down the cylinder wall and get into the oil if bad enough
2008 Chevrolet 3500HD DRW LTZ
  #40
Old 03-17-2018, 08:16 PM
danzick's Avatar
playing with fire
Sorry, been busy. I'm still going to upload that video. Monday morning marks a week since the last time it ran. I'll start it again then and take a video for comparison. And no, I am not making oil.
2004 lb7 ec/lb
Built trans
PPEI tuning
s475/stock twins
