  #61
Old 03-03-2015, 05:26 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Quote:
Originally Posted by Cornell View Post
Okay. Thank you
No problem. It's been a day or two since I've done one, but going from memory all rooms are the same.
__________________
07 crew long classic, stock minus some pretty parts
Thanks to everyone on this forum who has helped me and those whom I bought parts from.
Special thanks to Evan, James, Russell, Mark and all the others I'm forgetting.
  #62
Old 06-30-2015, 01:10 AM
mfritch mfritch is offline
FNG
Default Torque? What torque?
I picked up my pump through the local GMC dealer as my friend is the parts manager. He used to be a line mechanic and I was talking to him about the job and mentioned the big toque number. He said, "Oh, you just spot torque the balancer bolt." I asked, "What the hell is spot torquing??!" He said, "You use a 3/4" breaker bar, 2' cheater pipe and you pull on it until you see spots." The look on his face was dead serious. That had me worried. Vinny, how did you arrange the #2 given the #11? That looks like snow in the background.
  #63
Old 06-30-2015, 06:58 AM
Awenta's Avatar
Awenta Awenta is offline
Default
Anyone ever break a balancer bolt?
I've broken bigger bolts with the above method. I'm careful with important bolts haha.
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #64
Old 06-30-2015, 11:48 AM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Default
Anyone heard from Vinny?!?! I sure hope he's doing ok. I miss him posting - a wealth of knowledge on many subjects.
__________________
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
  #65
Old 07-01-2015, 06:48 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Quote:
I was just thinking that yesterday when this thread was bumped. As I recall, he was having some serious health problems.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #66
Old 07-01-2015, 09:42 AM
SmokeShow's Avatar
Default
yeah I knew he was going through it with the lymphoma. Just hope he's in remission and doing well. Best I recall, he was a newly wed and everything. Just hate what he's going/gone through as a young man. Hoping for the best.
__________________
Mitch
  #67
Old 08-30-2015, 08:40 PM
ynotracing2221's Avatar
ynotracing2221 ynotracing2221 is offline
DMaxed
Default
How are you guys swinging the coolant bypass pipe out of the way with that little hose on it that's behind the big pulley that the fan clutch attaches to? I'm not able to move it enough to get to the bolt behind it.
__________________
2016 GMC 2500HD Denali
Stock......For now.
  #68
Old 09-12-2015, 02:10 PM
durallymax's Avatar
durallymax durallymax is offline
Default
Get a swivel socket
Sent from my SM-N910R4 using Tapatalk
__________________
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #69
Old 02-01-2016, 11:04 AM
ROGUE GTS ROGUE GTS is offline
Default
Well I dove into this ordeal Saturday, not awful but definitely not a lot of fun either. Shoutout to the guys at Danville, they had an LLY pump in stock and got it shipped out the same day I ordered it. Very nice job on the pins, and dimpled the end of the pin hole in gear and impeller so there is really no way that pin is coming out. My mostly stock truck likely wouldn't ever have an issue anyway, but I like the added security, this is essentially failsafe.
One thing I would also consider, if you are replacing the pump and the housing, get a new set of studs for the oil cooler flange. I didn't realize they were needed and despite my best efforts soaking the stud with PB, I sheared the head trying to get it out.
It's a pretty easy to find part, standard M8 on both sides, but still sucks to go hunting in the middle of the job.
Few things I came to realize last weekend while doing this:
Change the rubber hose from the bypass pipe to the turbo. It's 4" of 3/8" rubber hose, just do it.
BE SUPER CAREFUL WITH THE O-RING ON THE BYPASS PIPE INTO THE THERMOSTAT HOUSING.
Pressure test the whole thing before you put it all back together and find water running out of your bypass pipe. See above.
Don't even attempt that crank bolt with a 1/2" breaker bar, I don't care who made it. Amazon has 3/4" bars for under $40 rated near 1,000 ft/lbs, get one. Or pull the radiator/IC and hit it with an impact.
Use an air chisel on the clutch fan. IMO we should now just call this "the way it's done", all the typical universal tools I found are useless for this application. Air chisel had it spinning off in a couple seconds.
You're going to make a big ass mess, there is just no way around it. I decided to replace the upper and lower hose while I was in there and was wearing a gallon of coolant before the day was over. Keep an old mop and 5 gallon bucket handy. Everytime you turn around this thing dumps more coolant, especially when you finally pull the pump.
__________________
04.5 LLY CC/SB 4x4 DA.
  #70
Old 02-01-2016, 11:52 AM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
Nicely written!
__________________
Jason-
Founding member of the "knows enough to be dangerous" club...
Hey, I'm NORWEGIAN... you try having a SQUARE head full of ROUND thoughts...
  #71
Old 02-01-2016, 03:47 PM
juddski88's Avatar
juddski88 juddski88 is offline
Freedom Diesel
Default
If you do work on trucks regularly, I'd suggest not using the air chisel method and instead buying a fan clutch kit like what gearwrench offers. It's cheap on amazon and will make working on dodges and fords a lot easier as well. Also, I have never had great luck with the replacement upper oring for the bypass, so I always use one from my assorted kit, thicker and more durable.
__________________
2001 Chevy 2500HD ECSB
"Sore Subject" - Still don't have time for it.
I would never have learned what I have without George Alexander, Mike Lovrich, David Browning, Matt Handwork, Ben Tyler, Evan Drosehn and countless members of this forum and others.
Thank you.
2014 Jeep Grand Cherokee Limited, Ecodiesel
  #72
Old 02-02-2016, 09:08 AM
Default
Quote:
I can see that, in my case this was the first time in almost 10 years the fan had been off.
What is this assorted kit you speak of? I was just using the pack of O-Rings that came with the pump. Or do you mean just a generic assortment of O-Rings and find one that's bigger than the supplied piece?
__________________
  #73
Old 10-01-2016, 10:36 AM
BW544's Avatar
BW544 BW544 is offline
FNG
Default
Nice write-up subd for when I need to do this
  #74
Old 10-01-2016, 03:10 PM
Max Attitude's Avatar
Max Attitude Max Attitude is offline
11SIX
Default
Quote:
Thanks for letting us know!
__________________
Jared
05 Chevy 2500HD ECSB 4x4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
