  #1
Old 12-06-2017, 12:23 PM
MADD*MAX MADD*MAX is offline
Gearhead
Default LML front drive shaft
Is there anything special to removing the front drive shaft? I thought it was just a slip yoke but it does not seem to want to slide out.
__________________
2013 LML-Wherli S475 over stock twin kit, Cp3 conversion with fleece pro flow 750, AD 165, cognito 4-6" NTBD, PISK, 5' flo pro exhaust, ARP head studs tuned by Kory
  #2
Old 12-06-2017, 01:34 PM
fc8464 fc8464 is offline
Gearhead
Default
Should have a crimp band clamp on the boot on t-case side will need to be removed. I have seen where people did not replace that clamp and water gets into the splines and rust up solid. If this is the case slide boot back and spray with your favorite penetrating oil and tap in till front drive u-joint can be removed and carefully hammer out. Clean splines inside and out with a wire bush and lube splines. Besure to make sure boot is in good shape and re crimp clamps. Fred
  #3
Old 12-06-2017, 01:43 PM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
I'd also intall better u joints while you're at it.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #4
Old 12-08-2017, 09:46 AM
Gearhead
Default
Ok will do. What u joints should I be switching to?
__________________
  #5
Old 12-08-2017, 10:22 AM
AZlml's Avatar
AZlml AZlml is offline
Default
Spicer 5-795X is what I used. There's another thread around here about front u-joints on the LML letting go in 4wd.
__________________
Bryan
11 CCSB 4x4
Full delete, EFI by Ridgerunner, 5" FloPro, Profab manifolds and up pipes, Wehrli cp3 conversion, 3" downpipe, S&B intake, AD165 4G, DHD tie rod sleeves, 2" rear drop shackles, Rancho RS9000XL
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
