  #16
Old 03-16-2016, 09:16 AM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
Quote:
Originally Posted by jpowel29 View Post
wow - very nice. What are the build specs if you can share
Thanks bud, it is SoCal Stg1 built motor that we pulled apart and oringed the block and upgraded to the 625+studs and SoCal 6480AF cam. 200%inj from Exergy and Dual fuelers. Has my newest 72mm Stg2R VGT in the valley with the new BullseyePower NLX ballbearing S483/96 1.32ar atmosphere turbo with the new Gen4 tuneable map cover which is cool. Customer wanted a fun reliable 1,000hp street truck so this is where we ended up with it. This power was produced on 2100us and 22degrees of timing max and made 78psi boost.
This motor is going in an 08 LMM CCSB truck for a customer from out in the Virginia area.
Sorry Tom, I'll try harder next time sir!
__________________
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTStg2 Exergy 12mmcp3 1/8th 9.11@77.51 1/4-14.174@96.8mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #17
Old 03-16-2016, 09:24 AM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
Stupid VGT's can't make any power Mark, everybody knows that by now.
But seriously, sweet to see those big of numbers on such a simple setup!
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #18
Old 03-16-2016, 01:03 PM
moparkxracer's Avatar
moparkxracer moparkxracer is offline
Default
Va area, wonder if I'll see him running around... Lol.
__________________
Thank you to:
Engine build: Burkett racing
Transmission: be in Evans hands soon
Turbo spec: Shane (S Phinney on here)
Turbo kit built: myself and Landon at Shade tree triples
Tuning: Mark at Danville performance
Fueling: Exergy
And everyone else who made this possible, Thank you!!
  #19
Old 03-16-2016, 03:05 PM
Awenta's Avatar
Awenta Awenta is offline
Default
Quote:
Make sure your go pro is on standby!
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #20
Old 03-16-2016, 03:48 PM
coldLBZ's Avatar
coldLBZ coldLBZ is offline
Default
Nice work yet again Mark
__________________
Dan
2006 Chevrolet 2500HD 4x4 CC/SB LBZ Allison
PPE Hot+2 ET, S&B Cool Air Intake, MBRP 4", PCV Reroute, BD Manifold, SD Manifold, SCIV/PPE-Precision Converter/Pump Rub Fix/T-Case Brace/SoCal Diesel Flexplate By Ted @ MPL
2014 GMC 1500 4X4 RC/SB 5.3L
2008 GMC 1500 4x4 CC/SB 6.0L 4L70E - GONE
  #21
Old 03-16-2016, 03:50 PM
coldLBZ's Avatar
Default
Quote:
Originally Posted by DAVe3283 View Post
That was an impressive pull! It cleaned right up, and didn't even smoke much getting on the turbos.
I sure wouldn't mind having a setup like that on my truck. Pity I can't run a VGT.
Sure you can
http://www.duramaxdiesels.com/forum/...ad.php?t=35104
__________________
Dan
  #22
Old 03-16-2016, 03:53 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Quote:
Originally Posted by coldLBZ View Post
I've got too much money into my top end (heads, injectors) to swap to a LLY at the moment, tempting as that may be. I have kicked around the idea of making my own VGT controller (I'm an electrical engineer & programmer), but I have too much on my plate at the moment.
Still, watching how Mark made that motor run makes me
Perhaps one day...
__________________
  #23
Old 04-05-2016, 01:46 PM
DMax Junkie
Default Chassis dyno comparison!
Sorry guys, been kinda busy but got this truck about ready to deliver to the customer and did the repeat run on my chassis dyno to see how far off the numbers would be. I actually got it to hook up better than than I thought it would and it made 65psi boost at 1085hp 1774ftlbs. Pretty cool to see an actual back to back dyno from engine to chassis dyno on same setup! Thought you guys would enjoy this. On the street, pretty useless tire frying machine, lol!
__________________
  #24
Old 04-05-2016, 01:55 PM
BLACKMAX1's Avatar
BLACKMAX1 BLACKMAX1 is offline
WAY2EVL
Default
Any pictures of the truck, maybe I'll see it around.
__________________
07 LMM
Tuned by Danville Performance
Danville 72VGT
Exergy 45's
PPE dual fueler
AirDog 150
SSDP Trans, SC1058 converter
HSP Diesel manifolds/up pipes
HSP Diesel intercooler tubes/bridge
Mishimoto intercooler
Kryptonite/Rare parts front end
  #25
Old 04-05-2016, 02:14 PM
N2BRK N2BRK is offline
Default
I actually got it to hook up better than than I thought it would :
Did you ever try some of that spray that I gave you? Curious if it works or if it's BS,lol.
Wally
__________________
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #26
Old 04-05-2016, 02:25 PM
DMax Junkie
Default
Quote:
Wally
Yes, I have been using the shit out of it! Works really good and it's the only way to get them to stick to the roller and actually do something. Tip of the year right there, thank you sir!!!
__________________
  #27
Old 04-05-2016, 04:19 PM
Default
No shit??? LMFAO! That's awesome!!! I was a little sheepish to suggest it, but it seemed logical that it should work. Hahaha. Great!
__________________
08 LMM Crew 4x4
Exergy 12mm
  #28
Old 04-05-2016, 05:06 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Traction compound? Never used a spray on.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
