Old 05-15-2018, 06:52 AM
DefiantArms's Avatar
DefiantArms DefiantArms is offline
Limp Mode Cowboy
Default Ac funk
Wifeís terrain sat for about a week when it was getting some body work done and now it has a funk coming from the air vents itís the most prevelant after sitting and first turning on. Iíve changed the cabin filter any idea what to do?
John
2005 Chevy 2500 LLY CCSB "Nyx"
Legal Disclaimer: My comments on this board are based on my personal experiences and life lessons. Don't try this at home. Your mileage may vary. Model shown includes options. Past performance does not reflect actual capability or intelligence. I'm off my meds. Don't listen to a thing I say, you've been warned
Old 05-15-2018, 07:09 AM
Chevy1925's Avatar
mildew grows in the hvac box where the evaporator is as all the water doesnt always drain out the drain for it. you can leave the a/c off, windows down and turn the blower on to try to dry out whats in there for about a week or pull the hvac box and clean it out (not fun) or see if you can get your hands on a cleaner that can go in there after the cabin air filters to kill it/clean it out. i know they make foggers but i think there is an off the shelf cleaner too.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 05-15-2018, 09:18 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
X2
Might get lucky if you crank the ac on a hot day but most likely itís like a swamp in there now
Take it apart and clean with a soft bristle brush and bleach water
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
Old 05-15-2018, 02:46 PM
Limp Mode Cowboy
Thanks guys I’ll see what i can do to clean it
John
Old 05-15-2018, 04:10 PM
WVRigrat05's Avatar
Wound for sound
Originally Posted by DefiantArms View Post
Thanks guys Iíll see what i can do to clean it
Call me dumb, but I turned the 90 for my drain upside down and filled with bleach and then pulled it off and put the hose to it/let it drain 8-10 times.
Reger
100k miles. Piston eater.
Old 05-15-2018, 04:32 PM
Limp Mode Cowboy
I’m taking it to the dealer tomorrow for a free oil change so going to see if i can con them out of a hvac cleaning
John
Old 05-15-2018, 06:28 PM
Hambone's Avatar
Always learning
did it work?
worst case scenario you arenít 100% water tight and get water in the cab of the truck
Old 05-15-2018, 06:34 PM
WVRigrat05's Avatar
Wound for sound
I put towels in the floor, it did get some water in the floor board but it brought some junk out, mine didn’t stink but my floor got wet one day from the AC and I did a flush to get everything out of it, definitely not the right way but it worked ok.
Reger
  #9
Old 05-15-2018, 09:22 PM
ChrisPerry's Avatar
I used that Meguiars anti smell bomb stuff on a car I had for sale. Car smelled like ass and cigarettes before, like a new car after. (Not me, flipping it)
Rolled windows up with air on high and recirculating inside air, set off 2 cans, and left running for an hour. Had to wash windows and wipe down dash and panels after, but that was probably just the funk from the vents.
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
  #10
Old 05-16-2018, 03:45 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
Never heard of that before...^^
  #11
Old 05-16-2018, 03:58 AM
Nathan.'s Avatar
Nathan. Nathan. is offline
I have never tried it but I read on the internet (has to be true) that if you turn your blower on high and spray Lysol into the area that lets air come in from the outside (I believe under the windshield wipers) it will actually kill the mildew/mold. The downfall is that you would have to live with the scent for a bit. I think the mildew forms before your cabin air filter though.
2005 Sierra CC LLY
2006 Jetta TDI BRM
2014 Harley Davidson Street Glide Special
  #12
Old 05-16-2018, 05:33 AM
GMC_2002_Dmax's Avatar
GMC_2002_Dmax GMC_2002_Dmax is offline
The Still Master
get a OZONE Generator, pump in OZONE Rich Air, let the AC run on RECIRC, OZONE destroys odors, mold, bacteria in a high enough concentration.
They use them to eliminate smokers stink, after a house fire, etc
2016 Denali LML----> 2012 Denali LML SOLD
2007 GMC "Classic", LBZ, SLE1 ,RC/LB, 4x4
~Powered By "MOONSHINE"
12.525 at 107.07
2002-GMC Sierra 2500HD SLE/CC/SB/4X4~Powered By "MOONSHINE"
12.65 fuel only, 12.00 on some N20
Retired 04/18/2009...................SOLD 01/2014
  #13
Old 05-16-2018, 11:39 AM
I use them on boats to get rid of mildew and mold smells.
  #14
Old 05-17-2018, 03:29 AM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
https://www.bgprod.com/catalog/clima...g-frigi-fresh/
This is what we used at Toyota when I worked there as a kid...
  #15
Old 05-17-2018, 03:44 AM
Limp Mode Cowboy
Dealer wouldn’t do it for gratis so i messes with it a little but i poured about a cup of bleach in it with it in max and then rinsed it out with two bottles of water it helped a little bit. Picking up a can of ozone today.
John
HTML code is On
