  #16
Old 02-26-2017, 06:13 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
I just yank a hose and catch what I can lol.
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.72@108 1/8
10.41@133 1/4
  #17
Old 02-26-2017, 07:35 PM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
Originally Posted by rg3whitelbz View Post
I like my big black concrete trough to cover the largest area and probably holds 7-8 gallons.
Sent from my 0PJA2 using Tapatalk
Originally Posted by c20elephant View Post
Next coolant drain this is going in, Home Depot has some mortar mixing tubs 6" in height and 20"x28"..
X3. Just used one when I did the water pump. Catches 95% ....Just not the stuff that sneaks down the block/lines/skidplates/etc
  #18
Old 02-26-2017, 07:44 PM
N2BRK N2BRK is offline
Sinner
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #19
Old 04-17-2017, 11:20 PM
Wyley87 Wyley87 is offline
Gearhead
I got the one from Mfr. Used it during a coolant flush. The constant removing of the plug caused it to start leaking. I i installed a fumuto valve where the plug used to be. I might ad them to the sides of the block too but I haven't decided just yet.
Easy peasy draining now.
Sent from my SAMSUNG-SM-G930A using Tapatalk
