  #106
Old 11-19-2017, 08:45 PM
malibu795's Avatar
malibu795 malibu795 is offline
Thanks guys.
Maybe get someone to make one out of aluminum or another steel sheet after the holidays.. it will get me down the road in legal fashion though
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
  #107
Old 11-20-2017, 05:03 AM
NC-smokinlmm's Avatar
<<<Future tuna killer
Send me the dimensions and I'll cut one out of stainless on the plasma for you...
2001 LB7 ECSB SL Built trans, batmo, lbz cp3, everything else, etc... Sold...
2006 LBZ CCSB SLT < My first, Superchips Flashpac... Sold...
2008 LMM CCSB SLT < Blue beast. way too much to list.... Sold...
2015 LML CCSB Denali < Lifted 20's/35's Deleted Airdog ETC. Sold...
2016 LML CCSB Denali < Lifted 22's/35's >I officially need help.
2010 1500 RCSB Denali clone <Lifted 22's/33's, 5.3, 6L80, TVS1900, Mayhem tuned, etc ...
  #108
Old 11-20-2017, 06:30 AM
malibu795's Avatar
Adam
  #109
Old 11-20-2017, 08:02 AM
malibu795's Avatar
Some new
some old
Some digital
Some mechanical
some Isspro
some auto meter..
Phantoms blend well with the R14000 Isspro
Got a MUTT dash for sure
Adam
  #110
Old 11-20-2017, 12:53 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Heck if they all work thatís better than half the trucks I drive. Even some of the new trucks.....
06 GMC 2500 CCSB SLT LBZ 4X4
  #111
Old 11-20-2017, 01:34 PM
PureHybrid's Avatar
Isuzu Shakes IT
I love the Phantom2 gauges in mine, awesome at night. Don't think I'll ever go back to an incandescent bulb gauge again.
That arrangement doesn't look bad at all.
Jesse
  #112
Old 11-20-2017, 02:04 PM
malibu795's Avatar
At minimum 4 that are mechanical should work lol
IDK the phantom 2 where LED?
Mine are normal phantom..
the Isspro are LED..
Obviously the digital sport comp guages are LED
Some time next year I'll have matching style
Adam
  #113
Old 11-20-2017, 04:27 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Same here. Just ordered another one to add on the pillar.
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
  #114
Old 11-21-2017, 11:32 AM
malibu795's Avatar
Need to clean up under it...figured I'd let see some sunshine
Adam
  #115
Old 11-21-2017, 02:10 PM
lutzjk913's Avatar
Looking good!!!
Joe
13.44 @ 98.69
  #116
Old 11-21-2017, 06:38 PM
jlawles2 jlawles2 is offline
Sweet. Throw some good rubber on it, update he tags if out, and hook to something heavy.
I always enjoy seeing what you have going on with it. Be glad to see it finally hooked to a load as I have watched several of your builds and always enjoy what you are up to.
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
17 Denali CCSB 2500 4WD Stone Blue with Cocoa/Dark Sand Interior
  #117
Old 11-21-2017, 06:52 PM
malibu795's Avatar
did bench test on the tach and speed o.. tach works,, speedo doesn't.... and its thanks giving weekend... looks like I'm robbing the 3 3/8 160mph gauge out of my Malibu for a little while
boot gauge died too IDK why..
Adam
  #118
Old 11-22-2017, 06:24 PM
By chance, did you pinch the line or over pressure it on the bench? Don't forget to check to see if something is covering the inlet sending unit or gauge.
  #119
Old 11-22-2017, 07:09 PM
malibu795's Avatar
it wont go back to 0 once pressure is relieved..
isspro speedo is heading back to Oregon.. its doesn't even turn on and rattles as you roll it around.. someone didn't fully soder something..
pulling the 3 3/8 gauge out the Malibu happens to be a 160mph gauge unitl isspro gets me a new one.... they go full strength again Monday.
been working backside of the dash, getting all the lights on the truck working
c
calling up auto meter Monday see what they can do with the boost gauge
Adam
  #120
Old Yesterday, 08:30 PM
malibu795's Avatar
Got dash in, tank sending units wired, lift pump relay properly mounted, manual control of the fan Clutch done,
Went up an Down my driveway.. ~1/2 mile long got it up to 55ish fairly easily.. haven't put AFC live on it yet.. truck does 12psi of boost and 650į egt with stock fueling..
Think I got room to work with it..
Let it idle for a bit... It decided to left me know I fogot to tighten the lower radiator hose clamp...by putting 4-5gallons of coolant on the ground..
Adam
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
