  #46
Old 10-04-2017, 06:41 AM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Originally Posted by Dozerboy View Post
I thought this turbo was good for 40psi? Did you think you have more left in it or its the 36 psi due to your engine build flowing more?
Yes it is, I didn't change the tuning for the turbo. It was still set up for the stock turbo so vane position was dropping all the way to 0% on it. I have seen as much as 42-45psi with this turbo with the correct setup. Motor setup is definitely changing this info also as all the turbo combos made the most boost at 2,000-2,200rpms and fell off as the rpm went up.
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
159.8mph in standing 1/2mile
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out B68mm Stg2R
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
