  #1
Old 03-22-2012, 09:59 PM
z79outlaw's Avatar
z79outlaw z79outlaw is offline
Default opinions on this Ingersoll Rand air compressor
I've been kind of just looking for somthing on craigslist locally but havent found anything, I dont use alot of air of even have any air tools right now, I use cordless tools as much as I can but it'd be nice to have an air compressor I seen this one in a flier is it any good? With proper maintenece can I expect a long service life out of it?
Its $999 at Tractor Supply but here is the Northern tool link because it has more detailed specs that TSC
http://www.northerntool.com/shop/too...Product%20Page
I was also looking at a two-stage 5hp Quincy compressory that had a 60 gallon tank but that was substanially more at $1400.
http://www.northerntool.com/shop/too...0475_200350475
__________________
-Nick
Sold 08 GMC 4X4 CC/SB 6" Fabtech, BMF's
09.5 Last of the brand G8 GXP
98 Silverado 3500 Cummin On Strong- 12v cummins p-pumped nv4500
  #2
Old 03-23-2012, 12:46 AM
mean06 mean06 is offline
FNG
Default
That's a big investment when u don't use them atm. Unless u plan on using them a lot I would say go smaller
__________________
2006 gmc 2500hd ccsb LBZ 4x4 with 6" fabtech lift and 37" procomp x-t. Diablosport predator- SOLD
  #3
Old 03-23-2012, 01:20 AM
Chad's Avatar
Chad Chad is offline
Chad231
Default
The IR's are great I have 2 in my shop the 7.5 HP/80 gallon and 10 HP/120 gallon type 30's. Mine run hard 5 days a week and not a problem in 5 years since purchase. Just maintain it and it will last your life time, if its not 40 hour+ work weeks. Get an auto-drain if you can, well worth it. A mix of air tools and cordless is always a good thing.
__________________
Chad
05 GMC CC3500 LB SRW "Big Red"
EPR Twins Industrial Injection Carillo Mahle ARP ProFab EFI Live PPE Krptonite AirDog Cognito Mike L. Merchant Auto
04.5 Chevy CC3500 LB SRW "Great White" ARP
AFE ProFab EFI Live PPE Kryptonite Caltracs Mike L.
  #4
Old 03-23-2012, 03:56 AM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
IR is probably the best,i got a used husky 80 gal 2 stage off craigslist for 400 and i love it.Theres deals out there expand your seach a little i had to drive 100 miles round trip for mine.
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #5
Old 03-23-2012, 04:12 AM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
I love my IR. Not a problem in 2 years.
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #6
Old 03-23-2012, 09:18 AM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
I recently went through the same decision, and I shied away from the IR from all of the complaints about motor failures on the smaller single phase powered units(particularly the 5HP ones made in MEXICO). The QUINCY will be the last compressor you ever buy though as they are a solid piece. I decided on a BEL-AIRE unit myself. It was priced right about the same as the IR unit, is a true commercial grade unit, and is built right here in the US. The only drawback to it is they use an aluminum block with a bolt on cast iron cylinder assembly. It is very durable, but the aluminum block makes it a little louder than a solid cast iron one. And if you plan on using it alot, I would go with one that has a magnetic relay on it for switching it off and on. mine doesn't have it, but I don't put but a few hours a week on it. And definately go with a 2 stage compressor, I can't believe how much less water I have to drain from the tank with a 2 stage VS my old single stage unit(and the added pressure sure is nice for the impacts).
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #7
Old 03-23-2012, 06:38 PM
DieselS10's Avatar
DieselS10 DieselS10 is offline
Gearhead
Default
I've been using a 7.5hp/80 gallon IR with the built on dryer and auto drain for a little over 10 years daily. I'd buy mine again in a second.
__________________
1985 S10 extended cab longbed with an LLY/Allison/241/241, Dana 60, 14 Bolt, Air-ride and 38's.
  #8
Old 06-08-2012, 01:36 AM
cjake cjake is offline
FNG
Default
I do not have an opinion on the Ingersoll Rand air compressor because I haven't used it yet. I already used many different air compressor because I do not own one. Whenever I need one I go for air compressor rental services. This is very convenient because I always get the right size and it is cheaper than buying one. Next time I will check if they also have Ingersoll Rand air compressor.
  #9
Old 06-09-2012, 09:44 PM
rms2012 rms2012 is offline
Default
Quote:
Seriously?
I know the Aggreko guys, here in Phoenix, and they rent large equipment.
Not what's being talked about here.
I worked for the IR dealer in Vegas. And, had a lot of training with them.
One of the features of the Type 30 was the ability to service the compressor with stages 1-4 rebuilding kits. Stage one being the minor one with intake, exhaust valves and gaskets. Stage four was the major overhaul with piston, rings and everything in the first three kits.
We sold the electic motor in odp (open drip proof), TEFC (totally enclosed, fan cooled) and X-proof (explosion proof).
So, as stated above, they may now source their motors cheaply.
We competed with Quincy, Sullair and Atlas-Copco.
__________________
Rick
2007 LBZ 4x4 regular cab
S & B Intake - Diable Predator
285/75/16 Michelins - 8' Bedslide
Amp Steps - Bilsteins
  #10
Old 06-09-2012, 10:45 PM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default
I used to have a 220 80 Gallon Bel-Aire and loved it. Sold it to an old boss, moved it to the shop, dont work there anymore and now I dont have my compressor
On the hunt for another one now for my new shop.
__________________
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
  #11
Old 06-10-2012, 01:58 AM
Righteyeblind's Avatar
Righteyeblind Righteyeblind is offline
Default
I have the IR one you listed it is nice and fairly quite but will not keep up with a 1" gun but all other tools it is fine.
__________________
"Pepper" 02 CCSB
Tuned by Tony
Carillos, stock LB7 pistons, head/main studs, Socal springs
GMAX 5 with 1055 converter
Garrett TV8403(GT55/47 hybrid)/ITS 74mm BB compounds
FASS 260 pump
ATS Dual Fuelers
Kennedy Diesel 40 over sticks
THANKS to Albert (BurnDown)<<<BIG HELP!!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
