Old 07-07-2015, 07:26 AM
SIKDMAX's Avatar
SIKDMAX SIKDMAX is offline
Highway Burnouts!
Default Ready to laugh? 1/2 Ton towing a Dmax question
Sup guys!
So, which way would you roll? 2014 1/2 ton towing SIKDMAX 400 miles lol. Only thing Im really worried about is tongue weight, I probably will be over no matter which way I do it. Pulled on forwards lots more tongue weight with the engine, backed on a lot of weight at the back of the trailer that could cause sway.
What are your thoughts?
Matt...2008 Chevy DMax CCSB 4x4 LTZ LMM
Carillos, Mahles, ARP 625s, SoCal Cam, Stage 1 Heads, 60% sticks, PPE Dual CP3, HTT 66SS/GT4718R Stainless Steel Twins, PPE High Flow Intake Manifold, Up Pipes and Headers. 6" MBRP single stack. Mike L. Suncoast 4 w/ 1057
Old 07-07-2015, 07:33 AM
DMAXchris's Avatar
DMAXchris DMAXchris is offline
DMax-less
Get a bigger trailer. Lol
I would do it with the truck facing forward. The trailer will prob wag with the tongue light.
06 Chevy LBZOlympic White Built Motor/Trans Bullseye s375 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76@115.12 SOLD
08 BMW 528xi
Alpine White Brown Dakota Leather Premium/Cold/Smoker Pkg LED AEs MTec D1S 50% tint
2000 Buick Regal GS
Bright White Lowered Homemade CAI 4500K HIDs Supercharged Beater
Old 07-07-2015, 07:37 AM
SIKDMAX's Avatar
Highway Burnouts!
Just bought the trailer 3 days ago, its more than adequate. 10,400 with dual electrical brake axles and drive over fenders. Its not a standard 7k model like my old turd that I put 3k+ miles on with the duramax on top LOL
Old 07-07-2015, 07:44 AM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
How far are you going Matt?
Nice to see that LMM out and about again
Id rather tow front forward. Bumper pull trailer pull like ass anyways though.
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
15 Cruze diesel
Tailgate Member #1 I prefer the backdoor
Old 07-07-2015, 07:52 AM
SIKDMAX's Avatar
Highway Burnouts!
SLO to Underground Thursday. Ill probably go to the scales today and weigh tongue weight both directions... I have a feeling both will be over LOL but with it forward is gonna be a lot a lot.
Old 07-07-2015, 07:57 AM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Def truck facing forward. It'll wag like a dog facing backwards.
Max out air pressure in rear halfton tires and take it easy, you'll be good to go more or less
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
Old 07-07-2015, 08:15 AM
Chevy1925's Avatar
Damn Matt, you still got the old girl?!
front facing forward for sure. i towed Steves truck with the ass end facing forward to cali and back when his clutches delaminated but i used a 30ft triple axle tongue pull that had alot of tongue weight to begin with and used my CC/LB. had 0 issues but i wouldnt in your situation.
with your light tow rig and shorter wheel base as well as a load at or beyond the what a 1/2 ton should be hauling, i would be running it front end towards the front of the trailer. scoot the truck back another 6" or so from the location you have it in the pic so you get a bit more weight on the trailer axles and not the truck. your stock 1/2 tires are going to allow the back of the tow rig to wiggle due to the fact they are most likely C rated or possibly D rated but the sidewalls wont be very stiff. this will amplify any trailer wag you get if you flip the truck with the ass end forward. its a VERY uneasy feeling when you feel the back of the trailer wagging and the back of your truck starting to follow suit.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 07-07-2015, 08:55 AM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
I am not sure, I had to haul my turn back from Chicago with a 2012 f150, I backed it on all the way so the back of the truck wasn't bottomed out but over 70 mph it would get a little wiggly, I am not sure if that was the pintel hitched or not though.
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #9
Old 07-07-2015, 11:08 AM
SIKDMAX's Avatar
Highway Burnouts!
LOL over 70... Im all for haulin ass but I am definitely setting the cruise at 55MPH and bringing lots of music.
Pretty sure I will haul it forward facing, going to test load it tonight and drive around a bit and see if the bounce/sway is less than how it was last night testing with it on backwards.
  #10
Old 07-07-2015, 12:22 PM
Burn Down's Avatar
These animals are supposed to help a bunch with sway... I have never used one but will when I move back home. https://www.google.com/search?q=load...g&ved=0CEMQsAQ
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
  #11
Old 07-07-2015, 01:18 PM
weazel's Avatar
weazel weazel is offline
Load it forward facing. If you have more weight on the rear of the trailer, it will drift left to right on you, and get worse the faster you go. Tongue pull trailers are horrible about that.
88 Chevy 1/2 ton- LB7 conversion project
93 Chevy K3500- CR Cummins conversion project
05 Chevy LLY 5" ex, EFI DSP5
  #12
Old 07-07-2015, 03:15 PM
Chevy1925's Avatar
i have those and a sway bar on my toy hauler. 37s that are only D rated still squirm enough in windy weather on a down hill as your coasting to keep a finger on the trailer brakes ready to pull and stop the sway the whole way down. cant wait to buy a fifth wheel this winter
James
  #13
Old 07-07-2015, 04:23 PM
bml2200 bml2200 is offline
I'd tow the the truck forward facing if it were me. That's what I do with my half tons when I need to pull one of the duramaxes.
2007 GMC 2500HD CC/SB SLE 4x4 LBZ- 68mm Cheetah w/ HX40 DP, Profab y-bridge, headers & up pipes, Big Dipper trans w/ 1058, Duramaxtuner, Cognito 4" NTBD w/ Deavers, FASS 150
2002 GMC 1500 ECSB SLT 2wd - DD
Sold: 2007 Chevy 2500HD CC/SB LTZ Z71 LMM Built
Sold: 2008 GMC 2500HD CC/SB SLT Z71 LMM Stockish
RIP: 2006 GMC 2500HD CC/SB SLT 4x4 LBZ Mild Build
  #14
Old 07-10-2015, 11:22 AM
SIKDMAX's Avatar
Highway Burnouts!
She made it just fine 420 miles yesterday. I ended up putting 10 ply tires on the rear of the truck which helped a lot, and I loaded it forward facing. It was just fine on cruise control at 65-70.
  #15
Old 07-11-2015, 11:28 PM
SIKDMAX's Avatar
Highway Burnouts!
Just got back - 10.2 MPG Loaded usually with the cruise between 57-67, and 15.0 MPG unloaded with the cruise 65-75. Not bad I guess.
