  #16
Old 01-08-2017, 08:23 PM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
No i havent done anything to the truck it just happened. The funny thing is i got out of the truck and thought to myself, oh sh!t i better see how much fuel i have. So i checked it. tank was above a quarter. So i put a check in the teller then jumped back in and went. i left the parking lot i looked again and it was empty... confusion set in.
It probably happened when I hit the speed bump or entered the street. Not a bad idea on how to check with the resistor it is a good point. I was going to throw a meter across it and check the resistance and fuss with it this weekend
  #17
Old 01-08-2017, 10:27 PM
jlawles2 jlawles2 is offline
You may also want to check the grounds.
Wiring from the top of the tank travels along the driver side frame rail, and goes under the fuse block. In the fuse block there is a connector for the fuel sensor and the outside air temperature sensor that displays on the rear view mirror. Check GMUPFTTER.com for a wiring pin out of the various connectors. Somewhere also buried in the document there is a set of resistor values for full tank and empty tank. For some reason I think the higher the resistance the more fuel in the tank.
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #18
Old 01-09-2017, 01:16 AM
Aka Mike Honcho....
Ill check it out when i get a dry day here. Were getting pounded with rain now and its my friday so maybe. ( might take a snow day and go play with the family )
Yeah ill have to check out the ohm value for the resister and make a jumper to check out the sensor and if thats all good ill check wiring.
  #19
Old 01-09-2017, 08:53 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
240 ohm empty to 33 ohm full
2008 Chevrolet 3500HD DRW LTZ
  #20
Old 01-09-2017, 09:00 AM
c20elephant's Avatar
c20elephant c20elephant is offline
C20ELEPHANT
https://www.gmupfitter.com/pdflists/view/6
https://www.gmupfitter.com/files/med...Electrical.pdf
~Mike~
2006 2500HD EXTENDED CAB LONGBED
