  #1
Old 02-26-2016, 03:43 PM
N2BRK N2BRK is offline
Default Lock up box and tps error
I bought the box used from a member here a few weeks ago. I love it! But this morning I popped a P2138. I reset it and nothing came back yet. Any ideas on this?
Thanks!!
Wally
__________________
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #2
Old 02-26-2016, 04:39 PM
Awenta's Avatar
Awenta Awenta is offline
Default
Which box
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #3
Old 02-26-2016, 05:10 PM
mike diesel's Avatar
mike diesel mike diesel is offline
I'm alright.
Default
2138 and 2140 will be thrown any time the box is used. Typically they are ghost codes and will not set the light.
__________________
'89 s10 daily driver
  #4
Old 02-26-2016, 05:56 PM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
Quote:
Originally Posted by Awenta View Post
Which box
Title says BT
Quote:
The codes associated with the box are 1271 and 1272 unless the 6 speed box is different.
OP double check all of your connections, solder the connections too don't use the t-taps.
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
  #5
Old 02-26-2016, 08:03 PM
Default
Thanks. Yep it's the 6 speed BT box. My truck flashed an Engine Power Reduced message at me this morning, which prompted me checking codes. Most connections are soldered, but I did use tap ins on the TPS and ground to the BCM.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #6
Old 02-26-2016, 08:05 PM
Default
It's the first hiccup since I installed a few weeks ago. I'm away from home on business until Sunday, so I can't do much right now.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #7
Old 02-27-2016, 06:49 AM
Default
Just fired up again. First since yesterday morning. Threw the code again right away. Damn
__________________
08 LMM Crew 4x4
Exergy 12mm
  #8
Old 02-27-2016, 06:58 AM
Default
Interesting. Keeps throwing it. Box not coming on either. I'd better check fuse and connections when I get home
__________________
08 LMM Crew 4x4
Exergy 12mm
  #9
Old 02-27-2016, 08:11 AM
OregonDMAX's Avatar
NOT IN OREGON
Default
It's throwing the code when you start the truck or when you use the box or arm the box?
__________________
Sean
02 CCSB
  #10
Old 02-27-2016, 12:41 PM
Default
Start the truck and before I make it a block or so, it throws. I did not try to arm. Last time I noticed no light, so I tried to arm and nothing happened.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #11
Default
Temps are so low lately, that the trans would be too cold to arm even if I tried
__________________
08 LMM Crew 4x4
Exergy 12mm
  #12
Old 02-27-2016, 05:36 PM
Default
Uh oh. Now it's every time that I stop. I made it through my appointments tonight with one hand on the wheel and one on the clear dtc codes button hope to make it home.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #13
Old 02-27-2016, 07:20 PM
Default
I decided to try for home tonight instead of tomorrow. Each stop it limped. Anything more than light throttle it limped. At least I'm home. Hopefully I can find something tomorrow.
__________________
08 LMM Crew 4x4
Exergy 12mm
  #14
Old 02-27-2016, 07:36 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
On of these codes is a throttle code, if you unplug the box what happens
__________________
Sean
02 CCSB
  #15
Old 02-28-2016, 09:19 AM
Default
Unugged it all. P2761. Going to just unplug controller next I guess
__________________
08 LMM Crew 4x4
Exergy 12mm
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
