  #1
Old 10-14-2013, 05:01 PM
unfinished business unfinished business is offline
Default 07 LBZ install
I am installing Ben's box on my 07 LBZ and am wondering where y'all tied in for the 12v switched hot that is hot during running and cranking? I just do not want to hook it up incorrectly and fry something!
Thank you,
Paul
__________________
2008 LMM 4x4 SB CC -A few boltons
  #2
Old 10-14-2013, 05:42 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
I cant remember which fuse I tapped into on an LMM recently, but if you have a test light, use it in your fuse options while cranking to verify which ones stay hot while cranking.
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #3
Old 10-14-2013, 05:47 PM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
the dirictions i got were for 07.5 and up trucks and the wire indicated to splice into for power and ground is not the same for my 07 classic. For my truck, on the BCM (found under the dash under the steering column), i pulled the plug closest to the passenger side, its the light blue plug, in that plug you'll find a white wire on the "A" side of the terminal in the #3 location, this wire was a hot source providing 12v in accessory, crank and run positions of the ignition. For the ground, i used the black wire with a white stripe found in the middle plug of the BCM(brown one), located in the A6 pin position, iirc. i went to radio shack and got the same wire taps ben uses to tap into all my connections, soldering them all to insure a solid long lasting connection, I soldered the t-taps by using them to make an indent on the wire, then carefully stripped the space between the two marks,then inserting the stripped portion of wire into the t-tap and heating the poles on each side of the tap till it melted the solder while holding the solder to the middle of the wire between the poles, it made a real nice connection.
__________________
Jason-
Founding member of the "knows enough to be dangerous" club...
Hey, I'm NORWEGIAN... you try having a SQUARE head full of ROUND thoughts...
  #4
Old 10-17-2013, 10:37 AM
Default
I'm guessing this worked?
Anyone else wire up their bt l/u box like this?
BT DIESELWORKS LOCK UP CONTROLLER FTW
seriously one of the coolest mods I've done so far
I love it, it's simple and extremely effective
__________________
Jason-
  #5
Old 10-24-2013, 06:47 PM
Default
I did it tonight and it seems to work great!!
__________________
  #6
Old 03-06-2017, 05:31 PM
bigbopper bigbopper is offline
Gearhead
Default bigbopper
ben , do you have pin outs from01 to 06 computer and harness , blk connector , under fuse box ? george
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
