  #1
Old 11-06-2017, 02:37 PM
gpn gpn is offline
FNG
Default Loud AD2 4G
I installed a brand new ad2 4g a few months ago chasing a fuel problem. It wasn't the fix but it was a great excuse to justify the expense...
Anyway, since then it just seems LOUD. I can hear it in the cab when idling, windows up and ac fan on medium. I'm deleted and 4" straight pipe on a LMM so it isn't real quiet when it idles. Why is the damn thing so loud? With the engine off and key in the run position you can hear the pump from 20' away from the truck.
I followed the instructions and I primed the system with the stock primer bulb before running it. Still on the first set of filters on the AD too.
__________________
Currently:
2009 GMC CCSB LMM ~ 4"MBRP Deleted/S&B ~ CTS2 ~ DSP5 from Rob ~ CAT/AD2 4G ~ Leveled w/ Kryptonite UCA & 5100's ~ B&W
quid leges sine moribus vanae proficient
  #2
Old 11-06-2017, 02:43 PM
NinjaMax's Avatar
NinjaMax NinjaMax is offline
WTF!
Default
I can barely hear mine in the drivers seat with the door open, truck off with the key on. Something isnt right
__________________
Wade
2017 Chevy "Sport" 2500hd CCSB ltz stocker
2006 Chevy LBZ - Deleted, 5" Magnaflow, Airdog II 165 4g.
2006 Chevy lbz LT ccsb 360,000 and counting..
5" exhaust, CAI...custom hail damage, peeling paint, etc...
2016 GMC 1500 slt 6.2ltr -wife's ride-
Sold
2016 Denali HD~tuned deleted
05 LLY CCSB~EPR compounds, cognito stuff, DDD Tuning, etc..
  #3
Old 11-06-2017, 02:58 PM
gpn gpn is offline
FNG
Default
Here is a short video. Key on engine off. Don't know why the image distorts.
https://www.youtube.com/watch?v=mSxDzr0P0WE
__________________
Currently:
  #4
Old 11-06-2017, 03:10 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Mine isnt loud either, sometimes I have to poke my head under the truck to make sure it's on
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #5
Old 11-06-2017, 03:13 PM
gpn gpn is offline
FNG
Default
Well that sucks.
__________________
Currently:
  #6
Old 11-06-2017, 03:15 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
Did you run a new pick up? Could be sucking air???
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
  #7
Old 11-06-2017, 03:26 PM
Ne-max's Avatar
Ne-max Ne-max is online now
I like turtles
Default
Quote:
X2. I seen them not seal on the pickup tube outlet causing this. Pull that fitting back off. Wipe clean. Try again. Also make sure your lines are ran correct.
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #8
Old 11-06-2017, 07:18 PM
N2BRK N2BRK is offline
Default
My buddy chased the same problem. He brought it to me asking if I could make a quiet box for it,lol. He called AD and the replacement is quiet; it was a lemon. My other buddy's got loud before they crapped out - all 4 so far. Call AD.
__________________
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #9
Old 11-06-2017, 07:26 PM
gpn gpn is offline
FNG
Default
I'll double check that the pickup seal is good and I'll also call airdog.
How hot to the touch does your motor get? Mine was warm enough that it wasn't comfortable to touch. I could keep my hand there but it wasn't nice. It was a nice 80 degree day today.
__________________
Currently:
  #10
Old 11-06-2017, 07:50 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Default
No offense to ad. but that's why I went with kennedy years ago my 06 has had kennedy pumps for 11 years now no problems at all have to lay on a creeper and touch them to make sure they're running they are so quiet. Sounds like you need a warranty replacement pump to address the concern if all connections are clean and tight. What's the pressure set at? If you have a gauge plumbed in?
__________________
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
  #11
Old 11-06-2017, 08:13 PM
gpn gpn is offline
FNG
Default
I didn't adjust the pressure because it supposedly was set right from the get go. I do not have a gauge. Guess I need to add a gauge?
__________________
Currently:
  #12
Old 11-06-2017, 08:41 PM
Default
Some are set high and low they set them at 15-18 if I recall at least that's what I remember then the and user can plumb in a gauge and set accordingly to their own psi if need be. Not saying you have a pressure issue but curious if yours is high and the pressure dead heading causing a back up in the supply and loading the pump up leading to the noise heard just something to think about may or may not be the problem could be internal to the pump motor itself. best bet is contact air dog and see what they recommend you try for proper diagnosis
__________________
  #13
Old 11-06-2017, 10:35 PM
NinjaMax's Avatar
WTF!
Default
did you happen to fill out the warranty card?
__________________
Wade
Sold
  #14
Old 11-06-2017, 10:39 PM
gpn gpn is offline
FNG
Default
It is sitting on the workbench in the pile of misc papers to deal with. Been meaning to send it in. Is that an issue?
__________________
Currently:
  #15
Old 11-06-2017, 10:41 PM
NinjaMax's Avatar
WTF!
Default
ya i dont know if they care about how much time has passed or not, but better get it filled out and sent in just in case you need to replace it.
__________________
Wade
Sold
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
