  #61
Old 11-05-2017, 10:47 AM
bdr_diesel's Avatar
bdr_diesel bdr_diesel is offline
Gearhead
Who?
  #62
Old 11-05-2017, 12:00 PM
Forever's Avatar
Forever Forever is offline
This 1 time, at band camp
Originally Posted by IOWA LLY View Post
You are the Douchebag on Facebook. You came here to brag. Not discuss. You are the one with a Facebook profile that says, and I qoute "I'm fu**ing brad, what else do you need to know".
People like you have given all of us in the diesel community a bad rap. You give zero input. You help no one. You have absolutely no knowledge of how to further the sport or improve anything. You simply convince people to pay you to do something that you know almost nothing about. Enjoy it while it lasts because reputations catch up to people like yourself.
lol
10' LMM
  #63
Old 11-05-2017, 01:53 PM
gmduramax's Avatar
Shits broke
I really don't get what the discussion is. Is the track at really high elevation? If it's not then the trucks are slow as ****.
10.98@124mph
Tailgate Crew Member #1
  #64
Old 11-05-2017, 02:24 PM
melms23's Avatar
melms23 melms23 is offline
Byron is an hour and a half from me. It's right on the rock river, and 1000' if that for elevation.
I never had a problem there, I figured my regular cab was on par for times, low 12s with s475 over stock.
2002 ccsb
2002 ecsb lbz zf6
Sold: '15 Denali
Sold: '04 rclb lly zf6
Sold: '07 rclb lmm
SDP s475/stock Twisted Tuned
12.1@111 1.79 60ft
  #65
Old 11-05-2017, 02:39 PM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
730ft is the elevation I found for byron.
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, tuning from Arron at All in trucks.
Best 1/4 to date: 11.35 in the chase for 10ís.
  #66
Old 11-05-2017, 03:49 PM
Chevy1925's Avatar
Maybe it has a 6% incline
James
best time to date: 12.39
Tailgate Crew Member #4
  #67
Old 11-05-2017, 03:51 PM
bdr_diesel's Avatar
Gearhead
That sounds about right on with what Iíve seen down there, probably seen yours actually. But I mean according to what they say stock trucks should be running, you should be in the 11s..
06 LBZ CCSB - DDP 72mm, 60% injectors, stock cp3, stock trans....purchased 10/2017
Iím new here..
  #68
Old 11-05-2017, 03:56 PM
N2BRK N2BRK is offline
08 LMM Crew 4x4
Dipper Trans/Mark's 68mmStg2R/40 over LBZ tips
Exergy 12mm
  #69
Old 11-05-2017, 05:27 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Bryon has been one of the best tracks I've been to over the years as Brett and myself have set many personal bests there. Here is the major problem with your argument, drag racing is awesome because it is math and math never lies. This is how I explain it to my customers and it will make it easier to understand for you. When drag racing your mph tells you what it should have ran and your et tells you how good of a job you did driving it. If the truck is healthy and making consistant power then you can make 10 passes and the mph on all of the runs will say within a mph or two but your et can be all over the board. Example, I went to Maryland in the spring and made 12 passes and the mph stayed consistently 137-140mph but my et ranged from my best of 10.2-11.4 because of traction and other issues I was having with the truck and my poor setup. MPH never lies and if I had my truck setup correctly then I should have been closer to the 9.7-9.8 range. Your low mph means your not making the power you think you are. 2 Years ago I went to Byron with a stock junkyard LMM motor with my 68Stg2R and a big pump and sticks and ran 11.27@119.7mph. Best pass of the day was the first one and as the day went on the traction out of the whole was going away and my last pass of the day I ran my slowest time but highest mph of 120. Last year I went with a triple setup and built motor with same fuel setup and went 10.48@139mph.
https://www.youtube.com/watch?v=FVUx8nDsdIU&t=56s
https://www.youtube.com/watch?v=DwDSatBu7sU
And you definitely know the track is good when Brett leaves the line with the front end hanging in the air every time!
https://www.youtube.com/watch?v=c4wX0FEGNDw
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTStg2 Exergy 12mmcp3 1/8th 9.11@77.51 1/4-14.174@96.8mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #70
Old 11-05-2017, 05:35 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
But, but, my tuning and especially my trans tuning and trans build were spot on. How can this be?
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #71
Old 11-05-2017, 05:52 PM
bdr_diesel's Avatar
Gearhead
The one truck for sure will have the exact same setup next year, might try out some tuning from not around here and see what we can get. And I see exactly what you’re saying Mark....I took my truck 2 years ago and ran 13.7-13.9 in 2wd but my speed was always in the 101-102mph range.
And especially the tuning we have on the 68mm 4094 truck...it would NOT stay on top at all, could feel it fall a little bit every shift.
I’m also getting multiple stories everywhere. Locals are saying the times are really good, and obviously on here with you guys spread out across the country are saying they are really slow.
Iím new here..
  #72
Old 11-05-2017, 05:57 PM
Awenta's Avatar
Awenta Awenta is online now
Common mark that couldnít have happened at Byron
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
  #73
Old 11-05-2017, 06:01 PM
bdr_diesel's Avatar
Gearhead
Okay, we are originally talking stock power trucks here.
Iím new here..
  #74
Old 11-05-2017, 06:08 PM
Ne-max's Avatar
Ne-max Ne-max is online now
I like turtles
What's that have to do with track times being accurate? Or are you talking about stock trucks being faster then your modded ones?
2006 ccsb Lbz Tow rig
2006 rclb 6.6
  #75
Old 11-05-2017, 06:12 PM
bdr_diesel's Avatar
Gearhead
Lol, there is literally a half second difference that local guys here run between Earlville/Cordova and at Byron.
Iím new here..
Closed Thread
