  #811
Old 07-16-2017, 06:40 AM
Chevy1925's Avatar
Originally Posted by Dozerboy View Post
I can't keep sway bar bushings in my vehicals for nothing it seems like. I've just quit doing them although the clunk it makes after they are missing drives me nuts too.
Are the Dorman mounts an updated version that help with the beaming? I don't have much issues with that since I moved out of socal other then on one long overpass in town.
These have been the longest lasting end links I've had. They are napas and lifetime warranty. My lift destroys these too. With torsion bars I could run without them and still have decent cornering. Not with coilovers now lol. Took a drive up to napa to get new ones with no links and you would have thought it was a trophy truck with all the body roll.
I have no idea on the dormans helping with beaming. I'll find out when I take it out for a longer drive.
Originally Posted by chavez91 View Post
OOOHHH.... I neeed to come over and see this! Nate and I were discussing this for the past few days as to what we were gonna do.
I have been meaning to talk to mike about removing the trans cooling from the radiator and just running a larger trans cooler with fan. Trans temps never seem to be a problem... They only seem to suffer because they have to follow the coolant temps when they rise because its absorbing heat from the radiator instead of the radiator helping it cool. lol
But we plan on trying out a few ideas.
Well with mikes cooler, even with coolant temps at 240*, trans temp never went over 205-210. I wouldn't bypass the rad.
James
best time to date: 12.39
Tailgate Crew Member #4
  #812
Old 07-16-2017, 07:33 AM
PureHybrid's Avatar
Isuzu Shakes IT
Part number for the lca bushings?
Jesse
  #813
Old 07-16-2017, 07:37 AM
Chevy1925's Avatar
No idea. Box didn't have one and I bought them from tomac. They are energy suspension's though.
James
  #814
Old 07-16-2017, 08:26 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
James what did that radiator cost? I looked around on there site and could find anything for diesels. Does it look like it's going to make a big difference?
04 LB7 ECSB Built motor, Wagler narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #815
Old 07-16-2017, 08:56 AM
Chevy1925's Avatar
I bought it through coolertowing.com. Joe is a local and goes by engineer(and some numbers) on diesel place. He makes quite a few options for cooling these trucks down while towing heavy in AZ heat. Ron Davis builds them for him. Is cheaper to go through Joe as well as I found out lol.
He makes an aux radiator that goes below the cooling stack that I would have used but my bumper and oil cooler won't give me the room for one. I was afraid of just throwing a Ron Davis replacement in and not getting any results so after talking with Ron, he suggested a dual pass to try. He says it generally adds about 20% more cooling that way. Add in the fact the fun design and cores add 20% over the stock rad, I think I'm doing well. Emailed Joe and he agreed it would be a good idea to try. Took about 6 weeks from start to finish.
It was 1500 for this radiator but I'll be 1800-1900 in it total after the van bridge and re-orienting it to point to the pass side, upper rad hose, and extended trans lines. Not cheap but it's high quality, Ron stands behind his stuff and it's USA made. I'll get some pics of the rad when I pull it out. Don't want to do that till I mm ready for install
James
  #816
Old 07-16-2017, 10:02 AM
rcr1978's Avatar
Thanks for the info I need to do something with my stuff way to many Mtn passes/big rolling hills here and tired of the 230+240 temps pulling traiers.
The auxiliary is almost not much less than the radiator I wonder witch way is the better route with a stock bumper front end?
  #817
Old 07-16-2017, 03:45 PM
Chevy1925's Avatar
The aux cooler for sure
James
  #818
Old 07-25-2017, 08:43 AM
Chevy1925's Avatar
finally drove the truck into work today. 100 times better than the poly's and definitely nicer than the old body mounts. truck is quiet, smooth and i dont notice much beaming but our highways arent all that bad. im taking the truck on a trip to vegas this weekend for my moms birthday, there is a nasty stretch of highway just before the casinos that this truck beams horribly on. we will see how she does friday
James
  #819
Old 07-25-2017, 09:50 AM
whitetrash21's Avatar
whitetrash21 whitetrash21 is offline
put on da damn helmet day
I know the section. 215 between 95 and 15. Mine feels like it's going for altitude through that part of town.
  #820
Old 07-25-2017, 10:02 AM
Chevy1925's Avatar
yup, exactly lol. damn good test for suspension smoothness thats for sure!
James
  #821
Old 07-30-2017, 06:51 PM
Chevy1925's Avatar
Well 85-90mph all the way there and 80 on the way home. This old girl has some short legs for that speed lol. 2550-2650 rpm at 85-90. On top of that, I forgot I had pilot injection shut off above 2500. Wife says "why did the truck get so loud" so my response was "that's horse power baby". Got an eye roll and cranked the tunes up. I was too lazy to play with the tune as well.
These body mounts are no fix for the bounce issue. In fact, the polys rode better in that aspect but in every other aspect of driving, the dormans won hands down for me. The truck ride pretty well over the nasty section of Vegas freeway but those bumps are large enough to go through the few inches of rear spring travel and make you slap the overloads. If I was under 80, she bounced bad. Above that, smooth as glass. Like hitting a whoop section off road lmao
James
  #822
Old 08-10-2017, 09:01 PM
Chevy1925's Avatar
Summit order for trans line parts showed up yesterday, thermostat housing was been rotated and just need to pick up a van rad hose. Radiator install will commence Saturday morning.
Going to smooth some edges down and throw a little silver paint on this bad boy. Hopefully this works out as cleanly as the idea in my head lol
James
  #823
Old 08-12-2017, 11:58 AM
Chevy1925's Avatar
Mmmmm love the way she looks. Too bad it's gunna get covered
James
  #824
Old 08-12-2017, 02:34 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is online now
Wound for sound
That is a sharp radiator.
Reger
100k miles. Piston eater.
  #825
Old 08-12-2017, 04:28 PM
Chevy1925's Avatar
Had to end early today. Got to the point of mocking up trans lines and building them. Also had to redo the belt routing to the style Shane ran (may still run) since lb7s can't be like every other year.
This is at rest. As the truck runs, clearance increases
Belt route, curious if I start launching belts again
Mock up. Spliced two trans lines together to let me pull it in for the night.
Only one trans line built so far. Cleaned my intercooler along with all this. Wasn't too bad but damn I forgot how much it weighs!
James
