Old 01-31-2014, 01:10 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
Default Fitting a dmax into a 67 to 72 C10
Have quite messing with my truck for now and have put my attention into redoing the body and probably making it a short bed. I eventually want to put a duramax into it, so I was wondering what I should do to the firewall when the cab is getting redone. It has a sb350 in it now and probably will get a twinned 5.3 before the duramax, but I don't want to have to redo the firewall in two or three years.
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
Old 01-31-2014, 01:37 PM
Kappa9012's Avatar
Kappa9012 Kappa9012 is offline
MAN.... I Broke it again.
if you're keeping the allison behind it the firewall and tunnel will need some serious work over the current setup.
Not sure how you'll get around redoing the firewall unless you've got a dummy to do mockup.
07 Lmm CC/SB
Built ally w/1057
Exergy 60 overs
Dual Cp3's
Billet S480 over stock from Wehrli
The man behind the tuning is Idaho Rob
Old 01-31-2014, 02:05 PM
<<<IT WORKS
It probably will be a 4L80E. I just was wanting to know if brett or someone who has done one has bothered to mess with there firewalls. There is lots of room under the hood, so I don't have to worry about making it bigger.
Old 01-31-2014, 03:44 PM
SmokeShow's Avatar
SmokeShow SmokeShow is offline
Brett's is heavily modified IIRC. Ol' dude over on CompD doing the body swap didn't modify his at all IIRC. Brett probably did to move engine back for weight bias for drag racing if I were guessing.
Mitch
SOLD02 Chevy 2500HD D/A EC SB LS
SCIII & X-Case brace by MA, Team Salad tuning & Trippin's DSP5, 4" Diamond Eye exhaust, Fumoto Valve, partially debadged, Rhino Bed Liner, SuperDiesel Intake Manifold and Ported Turbo Inlet
1983 GMC K30 CC SHORT BED
Awaiting Dmax/Allison Chassis Swap
Old 01-31-2014, 05:33 PM
<<<IT WORKS
I saw that swap on CompD and it looks good. If there any spots that are a good idea to redo for future turbo piping I want to do it now, while the cab is off and since my new cab is completely gutted.
Old 01-31-2014, 05:36 PM
<<<IT WORKS
Also the cab I just got is a manual cab, how well to you think a six speed T56 or what ever is in the newer cars hold up with a lot of torque.
Old 02-01-2014, 06:45 PM
bcdeutsch731's Avatar
bcdeutsch731 bcdeutsch731 is offline
You can do it without modifying the firewall. On my dads blazer that we are doing right now we cut out the firewall just like mine then ended up welding it all back in because we were able to set the engine far enough forward. We are using electric fans on his for clearance. On mine we modified the firewall so we could mount the engine as far back as possible. If you look at the trucks Facebook page you can see what we had to do to the frame. I don't have any pictures up yet of the new frame I did last winter, just the old frame.
https://www.facebook.com/pages/Deuts...83455581802944
1969 Chevy C10 Duramax Swap.
8.39@168mph
Race weight 4550lbs
Big Thanks Too
Danville Performance
HSPDiesel
Exergy Performance
Bullseye Performance
Wagler Competition
Old 02-02-2014, 01:00 AM
Turbo Performance's Avatar
Turbo Performance Turbo Performance is offline
They won't, you'll murder any manual I can think of besides one that came stock behind a diesel.
Levi
turboperformanceproducts.com
208)251-9141
Turbo/Manifold/Hotpipe Blankets
  #9
Old 02-02-2014, 05:24 AM
<<<IT WORKS
I figured that, but I would I would ask.
  #10
Old 10-17-2017, 07:48 AM
tetfemal tetfemal is offline
FNG
did anything come out of this?
I have a 72 k20 and wanted to swap a max into but there is no real information out there on the swap.
  #11
Old 10-18-2017, 07:00 AM
<<<IT WORKS
Not really yet, the project has changed direction a couple times and is back to a toss up between a old school SBC/BBC or duramax. This is about as far as I got with the old chassis. On a 2WD it looks like the engine cross member will need to be notched to get some extra forward as well as lower down to clearance. If you keep the Allison, you will need a High hump transmission cover, modified transmission tunnel or a body lift.
  #12
Old 10-18-2017, 09:05 PM
FNG
So I have a 72 k10 With a high hump transmission tunnel. I got it for nothing and was not sure what to do with it. The duramax idea got me excited to work on it after Iím done with my 67 c10.
I understand that the easier way to do the swap is to do a 2500HD chassis swap but I wanted to stick to with the original k10 frame.
