  #241
Old 06-29-2017, 02:16 PM
moparkxracer's Avatar
moparkxracer moparkxracer is offline
Default
That is the closed position, it opens to send oil to the cooler when it gets to temp. I heated water to check things out, it opens a lot .
Quote:
Originally Posted by JoshH View Post
How much does the thermostat on that Mocal piece block the passage when the thermostat is closed? It looks like it almost has the passage completely closed.
__________________
Thank you to:
Engine build: Burkett racing
Transmission: be in Evans hands soon
Turbo spec: Shane (S Phinney on here)
Turbo kit built: myself and Landon at Shade tree triples
Tuning: Mark at Danville performance
Fueling: Exergy
And everyone else who made this possible, Thank you!!
  #242
Old 06-29-2017, 03:12 PM
JoshH's Avatar
JoshH JoshH is offline
Default
Quote:
I understand that, but the oil has to bypass behind the thermostat to get to the passage on the other side and into the filter. The picture makes it look like that passage is very small with the thermostat closed. I didn't know if it was as small as it looks in the pictures or if it is just the camera angle.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #243
Old 06-29-2017, 04:24 PM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
Default
So the mocal is factory or was it r worked? If it is i see what your saying on the website they do look exactly the same.
  #244
Old 06-29-2017, 05:47 PM
Default
Prob the angel, it's open a lot more over the modified earls part.
__________________
Thank you to:
Fueling: Exergy
  #245
Old 06-29-2017, 05:49 PM
Default
The pic of the mocal is how I received it from them. I also got the prices to go to the -12 lines from them when I ordered it.
The other is the one super bee sells on here.
Quote:
__________________
Thank you to:
Fueling: Exergy
  #246
Old 06-29-2017, 09:54 PM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
I have one to and kinda thought the same thing but on a closer look it does not completely block off the oil cooler so there is still a little flow to the cooler when closed.
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #247
Old 07-03-2017, 08:51 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
Subd
__________________
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #248
Old 07-24-2017, 03:05 PM
npetric npetric is offline
FNG
Default
Quote:
Originally Posted by clrussell View Post
What's a full oil cooler kit worth? I'm not using the one on my Lb7 and don't plan on needing one honestly
Do you still want to get rid of this?
  #249
Old 09-20-2017, 09:29 PM
Awenta's Avatar
Awenta Awenta is offline
Default Engine Oil Cooler DIY
Where did you get the mocal plate?
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #250
Old 09-21-2017, 02:48 AM
Aka Mike Honcho....
Default
For the mocal plate. This is where I got mine.
https://www.racerpartswholesale.com/...Sandwich_Plate
  #251
Old 11-09-2017, 06:16 AM
DetailsUnlimited's Avatar
DetailsUnlimited DetailsUnlimited is offline
Default
Will the LBZ trans cooler flow enough to work as a oil cooler?
__________________
Gaylon(Tark)Tarkington
Trucks Name: Consistantly Inconsistant!
06 LBZ CCSB
Built motor
Team Hole in the Piston "RIP" 10/21/11
2011 NHRDA Ennis, Tx Sportsmen Champion
2011 NHRDA Sportsmen World Champion
2014 TS Performance 12.0 Index
New ride - 07 3500 Duramax Van
  #252
Old 11-09-2017, 09:05 AM
Aka Mike Honcho....
Default
I dont think so. I think thetrans cooler is -10 and the mocal adapter is -12.
  #253
Old 11-09-2017, 09:18 AM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
Quote:
The gains would be minimal imo, for all the work of having hoses made and a sammich plate installed for only a few hundo more you could have a nice fluidyne cooler
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
  #254
Old 11-09-2017, 07:21 PM
jlawles2 jlawles2 is offline
Default
I think the transmission God said the GM trans coolers are too restrictive. Would not want to risk starving the engine for oil.
Now you could probably get one of his trans coolers and use it.
__________________
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #255
Old 11-09-2017, 07:33 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
I used a stock 6 speed trans cooler as an engine cooler on my old samurai engine. I wouldn’t use it on our trucks.
__________________
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
