Old 05-17-2017, 09:43 PM
Dennis,max Dennis,max is offline
FNG
Question Truck doesn't go into gear
I have a 2001 Chevy Duramax has the Allison trans. Wouldn't move the indicator on the dash would just flash so changed the nsbu switch and no difference, had the tcm flashed and reprogrammed and still nothing so I changed the ignition switch and the truck then went into gear but took a few seconds before it kicked in then went back to not moving and just flashing on the dash. Also if I unplug the 4 pin wire connector on the nsbu switch the truck will move but only in limp mode. Any help would be awesome this truck has had me spinning for awhile now
Old 05-18-2017, 07:45 AM
Chevy1925's Avatar
Pull the codes and quit throwing parts at it hoping it will fix it
James
best time to date: 12.39
Tailgate Crew Member #4
Old 05-18-2017, 07:05 PM
FNG
The truck doesn't set any codes
Old 05-18-2017, 07:08 PM
Burn Down's Avatar
What are you using to ck the codes with? Cheapo scan tools normally won't pull allison codes.
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
Old 05-18-2017, 07:10 PM
FNG
Snap on Ethos, the check engine light doesn't even come on
Old 05-18-2017, 07:21 PM
FNG
I can get the truck to move but once I do I can't go far and it will just quit moving and the gear selection flashes but truck won't move unless I cycle the key a few times
Old 05-18-2017, 08:08 PM
Chevy1925's Avatar
You have codes, you just have an electrical issue going on that needs to be address. Start at the Tcm and follow the wiring back looking for frayed or cut wires.
Did you put the nsbu in as the instructions stated?
James
Old 05-19-2017, 02:59 AM
FNG
Yes I did and checked all the wiring the dealership I took it to to get tcm flashed look over the wiring as well and didn't see any problems
  #9
Old 05-19-2017, 06:22 AM
Blackmax123 Blackmax123 is offline
Start simple. Have you checked the oil level?
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
  #10
Old 05-19-2017, 06:46 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
May be plugged sump filter.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #11
Old 05-19-2017, 06:56 PM
FNG
That's the internal filter right?
  #12
Old 05-19-2017, 07:44 PM
KyleC4's Avatar
KyleC4 KyleC4 is offline
Yes. Pull codes or have someone with a tech II actually look at data when problem occurs
TEAM Chevrolet Cadillac
Mike L and Inglewood transmission
  #13
Old 05-21-2017, 05:08 AM
FNG
I have
