  #151
Old 01-04-2018, 10:04 AM
jlawles2 jlawles2 is offline
Originally Posted by malibu795 View Post
Why complicate it With dual voltage?
I'll update the starter with nice gear reduction 39 mt
Increased voltage = less amp draw on the batteries. And I agree keep it simple unless you need the extra torque from going 24v.
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
  #152
Old 01-04-2018, 10:17 AM
malibu795's Avatar
malibu795 malibu795 is offline
$300.00 is less headache...for current technology starter is alot less headache than dual voltage vehicle
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
  #153
Old 01-04-2018, 01:06 PM
Yeah. Definitely. Dual voltage would be a wiring headache.
  #154
Old 01-04-2018, 09:21 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
7.3kw / 12v = 608 amps / 2x batteries in parallel = 304 amps from each battery
7.3kw / 24v = 304 amps / 2x batteries in series = 304 amps from each battery
Only real benefit is you can use smaller gauge wire for the 24v setup
And, on the 24v setup, if one battery takes a s#it it wont bring down the other battery but it will prevent the whole system from working at full potential. On the 12v setup, one dead battery will likely kill the second
2008 Chevrolet 3500HD DRW LTZ
  #155
Old 01-04-2018, 11:28 PM
LBZ's Avatar
LBZ LBZ is offline
You need a small espar or webasto Adam. No need to plug in ever and always warm start up's.
  #156
Old 01-05-2018, 12:14 AM
malibu795's Avatar
"needs" alot of stuff Dale lol
Be adding grid heaters of the 24V 8.3s or at least trying too among other stuff
Adam
  #157
Old 01-07-2018, 02:35 PM
malibu795's Avatar
Started died... So new 39MT starter... Definetly spins over faster and Doesn't sound like it's struggling when cold
Adam
  #158
Old 02-03-2018, 04:24 PM
malibu795's Avatar
Originally Posted by Dozerboy View Post
How's the Mutt been treating you? Everything working out like you hoped.
I took an in-house loan out to get me the home stretch and up and running.. last payment was this check I received Friday..
So I really haven't had any extra money to re-adjust my blind shot in the dark and fire again..
The bigger turbo I put on is too small,
Plan is
Swapped from a 362/68 to a 363/74
I have talked to Joe @hsp about doing a 464/82 with an external gate, the concern I have right now is I don't have the fuel to spin a s400 charger..
The p-pumped is getting replaced with a 12m with common style DV 181/191 vs mine has constant pressure.. should be able to flow substantually more and better tunability along with 4k GSK set for full fuel to 2600rpm currently starts pulling fuel about 1800
New core is $1300.
Then install the 5*.014 injector I have.
Alternator/starter/batteries have all died and been replaced since I got it up and running.
It's solidly in the mid 8s for mpg have seen 9.5-10.5 couple times..
Diesel is pushing 3.50 or better here in the in the Midwest...
On a 2500 mile week avg
8mpg is ~300 gallons
10mpg is 250g
12mpg is ~200g
Multiple by say 50 weeks that's alot of money I'm leaving on the table...
Pretty sure once I get the engine timing good pump, right turbo, MPG will come up..
EGTs get warm quick @50į.... been grade speed limited by egts.... Probably be nuts come humid 90s in the summer..
Plan new CAC/radiator this spring along with AC condenser/pump/receiver/lines etc
Insulation/sound deadening/weather stripping needs done but I don't have a heated shop...
Edit
Found the OEM turning spec for a 430 hp 8.3 I pulled a H1C off
3802886 cummins #
H2d holset
Turbine Ind. 86. mm, Exd. 77. mm, 11 Blades
Compressor Ind. 64. mm, Exd. 94. mm, 7+7 Blades
Compared to s362/68
62/84
76/68
Adam
  #159
Old 02-03-2018, 04:42 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
The money you are/have spent in mods can buy a lot of diesel. I understand you may put enough miles on to justify it but most people when rationalizing their mods for mpg will never come out ahead...
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #160
Old 02-03-2018, 05:49 PM
malibu795's Avatar
geneally speaking i agree.
really depends on how many miles and how long you plan on keeping said vehicle, obviously, putting 100-120K miles down a year. my ROI will come much sooner, the higher diesel goes the faster my ROI happens. i plan on keeping this for at least 5 years
person that puts 20-30k on it over time he owns it say few years, naturally wont come out ahead.
for me saving ~100 gallons of diesel a week for 50 weeks at 3.50 a gallon is ~$17,500 dollars still in my pocket, that's pretty decent chunk of change especially for a business the does 150-200k year before expenses
the parts im using are while arent "cheap" they are substantually cheaper than most stuff on newer engines.
then theres the good stewart philasophy
Adam
  #161
Old 02-13-2018, 06:10 PM
malibu795's Avatar
Wore the rear pads off and caught a rotor
Both wore evenly
As with the theme of the truck.. mis-matched rear calipers in piston size....
Since rotors are inboard..... I put some cheap pads on,
got new rotors calipers pads, wheel seals coming.. swap everything when I get back from KS..
Front pads are 80% of new,
pads/rotors are same F/R
There's two caliper size (F) 2.6" and rear are either 2.6" or 2.8" if I can I'll put 2.8 all around..
Adam
  #162
Old 02-14-2018, 06:19 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Man there ainít nothing easy around you.
06 GMC 2500 CCSB SLT LBZ 4X4
  #163
Old 02-14-2018, 06:39 AM
malibu795's Avatar
That's my.life... nothing is easy...
Adam
  #164
Old 02-14-2018, 08:35 AM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Adam have you considered an AFC Live setup for the truck? will allow you to dial fueling on the go
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #165
Old 02-15-2018, 04:36 AM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
I give you another of credit. Either you really love what you do, make alot of money at it or just down right have alot of drive! I thought for sure by now you would have gotten a new career! Keep on keeping on!
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
