Go Back   Duramax Diesels Forum > Competition > Drag Racing
Reply
Thread Tools Display Modes
  #1
Old 04-20-2018, 05:25 PM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
Default Which are faster drag radials or cheater slicks/slicks
I made some changes to my truck over the winter. I want to get some runs in on what I currently have but I am contemplating changing my wheel/tire combination. I'm either going to a 16 x 10 with M & H 30 x 14 cheater slicks, 12/16 Nostalgia slicks or 17 x 10 with 315/50/17 MT ET Street R drag radial or the M & H 390/14/17 Drag Radial. I read and hear that Drag Radials are faster due to less distortion. I see a ton of Drag Radials at the race track on cars instead of bias ply slicks. Any info would be appreciated. Thanks
__________________
06! GMC Sierra RC Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, ARP 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TrRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergys w/185% MS 8 hole nozzles ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box, 18x9 Raceline Assualts Hooiser Drag Radials 325/45/18s . TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx Best 60'---1.44. Best 1/8---6.39@105.92. Best 1/4---9.978@136.39
  #2
Old 04-20-2018, 05:29 PM
GM_Guy GM_Guy is offline
FNG
Default
Radials are a lot more predictable. I don't like the idea of a bias ply on the front of a diesel truck but people have obviously had success with them.
I think the main reason for the bias ply is if you need the tire height because you are limited on a radial.
Sent from my SAMSUNG-SM-G935A using Tapatalk
  #3
Old 04-20-2018, 05:48 PM
Street rodder
Default
For sure on the tire height limitations. That is mainly due to the fact that we can’t use a 15” wheel . The 12/16 M & H Nostalgia slick is 31.5” tall but it is a bias ply.
__________________
  #4
Old 04-20-2018, 06:26 PM
FNG
Default
I'm far from a pro. I never left hard enough to need anything more than a nitto 420. I feel some like the look because not every "drag truck" needs radials
  #5
Old 04-20-2018, 07:08 PM
Street rodder
Default
With the 3.73s the current wheel tire combo will dead hook on tune 3 , tune 4 and 5 spin out of the hole, the more power I put to it the more spin. LOL. I am hoping that the 3.42s help me with that, if not I'll sell what I have and change my wheel/tire combo.
__________________
  #6
Old 04-20-2018, 07:13 PM
FNG
Default
I think my converter was too loose to spin out of the hole, It would fight for traction a little bit when it would hit lockup. But this is a vastly different setup and I was leaving in 2nd.
  #7
Old 04-20-2018, 07:27 PM
Street rodder
Default
I too leave in 2nd. Only way to go
__________________
  #8
Old 04-20-2018, 07:31 PM
FNG
Default
Yeah my converter was hanging on for dear life lol.
  #9
Old 04-21-2018, 04:10 AM
TROJAN366's Avatar
TROJAN366 TROJAN366 is offline
Gold Rush
Default
I ran 305/45r18 ET street R radials and they absolutely hooked better than a street tire. I was leaving in 2nd with 3.42s and still had to be careful not to spin. I ended up selling them and picked up another set of 30x14s. I never had any issues with the 30x14s feeling unstable at 130+. I bought my old set from Pat off Casper and sold them to Mike Graves. As far as I know Mike is still running them and his truck flat out hauls the mail.
__________________
05 LLY CC/SB
Roderiques ATV Built Motor, HSP Twins, NLX88/Danville72R,
S&S 200s, S&S 10mm & LBZ, Tuned by Danville Performance
Suncoast Competition trans and Goerend Converter
1125hp/1628lbft 10.52@132
Thanks to
Chris @ Roderiques ATV in Westport MA
Mark Broviak @ Danville
Joe and Dave @ HSPdiesel
  #10
Old 04-21-2018, 05:14 AM
Street rodder
Default
So is Mike running the 30 x 14 Chester Slicks or the ET Street R tires ?
__________________
  #11
Old 04-21-2018, 05:20 AM
TROJAN366's Avatar
Gold Rush
Default
Quote:
he is running the 30x14. I sold them to him a while back then got the bug and bought the ET Street R. There is no comparison.
__________________
05 LLY CC/SB
Thanks to
  #12
Old 04-21-2018, 06:10 AM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is online now
yerp
Default
Quote:
He popped one running over someone’s exploded compressor wheel on his 9.55 pass at UCC last year but aside from that they are still the ones you sold him.
__________________
Limitless Diesel Performance
413-770-3585
  #13
Old 04-21-2018, 06:16 AM
zf>allison's Avatar
zf>allison zf>allison is offline
you never had your car.
Default
28x10x16s on pyos Hoosier full slicks. Smaller tire but never feel unstable. And I hit the traps at 131 mph last night, taller slick might be more mushy but these smaller ones feel fine and are super light.
__________________
04.5 single cab lly zf6 barely not stock.(the jalopy)
05 single cab lly zf6
Arp studs, welded water pump, 100 overs, dual fuelers, valair 1000 hp triple disc, danville efi live, fass 150, custom single s400 kit,
serious weight reduction
28x10x16 Hoosier slicks on pyos
Down on 2 leaves, t bolts gone.
best
10.91 at 129mph, 1.577 60 foot
dynoed 743 hp raceweight 5k with driver
Instagram-636zf6
  #14
Old 04-21-2018, 10:39 AM
Street rodder
Default
So Trojan366 you preferred the 30 x 14s over the ET Street Rs ?
__________________
  #15
Old 04-21-2018, 04:58 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
I also run the 30x14’s and really like them! 2nd gear start on 3.42’s here and I leave around 50psi on them.
__________________
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTStg2 Exergy 12mmcp3
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
