Old 09-23-2013, 12:21 PM
Roc8man's Avatar
Roc8man Roc8man is offline
Default MLG vs MLG-K
Mike,
What's the difference between these two converters? I know you mentioned it to me when I stopped by last week but I think you said the stall was higher on the K. What are the stalls for each?
Thanks
David
2004.5 LLY CCSB
Built Engine
Twins - Danville 4094 68mm billetwheel / BW S480SX4
Dual CP3's
100% over Bosch injectors
DTS Intercooler
PPE Manifolds and Up-Pipes
Sun Coast Stage 3 trans
MLG-K Converter
Air Dog 165 Lift Pump
Tie Rod Sleeves
Cognito Braces
Merchant Auto engine and trans mounts
Diesel Day Dreams auxillary trans cooler kit
Caltracs
MBRP 4" stainless exhaust less kitty
EFILive DSP5
265-75/16 Goodyear Duratracs (looking for better)
Living at 6000' with typical track DA around 8500'...
Old 09-23-2013, 01:02 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
I absolutely love the K. ~200 miles on it.
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
Old 09-23-2013, 01:39 PM
sickdiesel's Avatar
sickdiesel sickdiesel is offline
the K is the best converter ive ever driven!
Dustin
Current: 2018 Ford Raptor 802A
2017 GMC L5P Denali CC/LB Cognito 4-6" on 22s with 35s SOLD
Blackout :06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
OverBuilt :07 Chevy lbz 4x4 Caged and built to the hilt 10.42@134 SOLD
Special thanks to: Mike L, GTrippin, IdahoRob, SDP, ISSPRO, Yukon, Dmaxstore, Airdog, HSP, Hamilton Cams, and Flexalite
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
Old 09-23-2013, 03:34 PM
Roc8man's Avatar
Do you guys have any idea of what the stall is on the K?
Thanks
2004.5 LLY CCSB
Built Engine
Dual CP3's
DTS Intercooler
MLG-K Converter
Tie Rod Sleeves
Cognito Braces
Caltracs
EFILive DSP5
Old 09-23-2013, 03:47 PM
Roc8man's Avatar
Have you guys tried towing with it? I tow 3-5 times a year with a 10k tow hauler...
Thanks for any help or advice.
David
2004.5 LLY CCSB
Built Engine
Dual CP3's
DTS Intercooler
MLG-K Converter
Tie Rod Sleeves
Cognito Braces
Caltracs
EFILive DSP5
Old 09-23-2013, 03:51 PM
Vsouth Vsouth is offline
Towing can be done with the K version. It takes a few rpm to get the load moving, but is doable. I had close to 30k miles on mine towing 8-11k.
It is not a towing converter, but it will work.
NHRDA 2011 Super Diesel World Champion
NHRDA 2012 Sportsman World Champion
A big thanks to: Edge Products, Adrenaline Performance, ATPTrucks, Dmax Store, Yukon, Flexalite, Fusion Bumpers, Danville Performance
2006 GMC 2500hd CCSB 4X4: Built to the hilt, and run till she broke!!
Old 09-23-2013, 03:55 PM
sickdiesel's Avatar
X2.
Dustin
Old 09-23-2013, 04:28 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
The G converter is a tight converter and stall would probably be around 1800/1900. It is not for big singles or high altitudes.
The K is around 2500/2800 stall. It's an amazing converter considering how it couples so hard after launch.
Verlon has had a lot of experience with racing the K and towing with it. Dustin has had a lot of experience racing the K also. There are only 5 out there right now but there will be a lot more pretty soon.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #9
Old 09-23-2013, 05:27 PM
OregonDMAX's Avatar
NOT IN OREGON
i got a question, what do you consider high altitude? anything above sea level? im at around 3-4k feet
and from what ive read the K converter would be great for twin/triple setup much more over a single? as you stated.
Dustin, is that with your new twin setup on the white truck or is that not finished yet?
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
  #10
Old 09-24-2013, 07:12 AM
sickdiesel's Avatar
I've been racing on the k all season with my old set up that was including the 10 sec passes.
The new set up with finished yesterday and I'm going to pick it up this weekend so I'm very excited to see how it acts with the new gt5541/gtx4202 set up.
Dustin
  #11
Old 09-23-2013, 06:43 PM
Getting faster
I have "stalled mine to 2600 but over 2300 it breaks all tires loose, don't need to push the converter that hard when I don't need to.
stall is only half the story. The part throttle coupling unlike any other converter ive ran.
"OldManTan"
  #12
Old 09-23-2013, 08:37 PM
05chevy's Avatar
05chevy 05chevy is offline
What is the price on the K. Looking to upgrade my converter with the engine build this winter
05 lly, s475, 40% nozzles, stock cp3. 11.69 @115
685hp/1100ftlb
97 12valve
  #13
Old 09-24-2013, 10:07 AM
Mike L.'s Avatar
The K runs 1495.00 with core exchange.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #14
Old 09-24-2013, 02:45 PM
Roc8man's Avatar
Mike,
If I wanted a K, how long does it take to get one and could I get it at a stall around 2300 instead of 2600?
Thanks
David
2004.5 LLY CCSB
Built Engine
Dual CP3's
DTS Intercooler
MLG-K Converter
Tie Rod Sleeves
Cognito Braces
Caltracs
EFILive DSP5
  #15
Old 09-24-2013, 03:05 PM
Mike L.'s Avatar
Originally Posted by Roc8man View Post
Mike,
Thanks
David
No can do. I would suggest a Suncoast 1055 for your needs.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
