  #1
Old 02-25-2014, 02:36 PM
Hot COCOAL's Avatar
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default Info wanted: how many miles on your ovals, what do you think?
So how many miles do you have on your oval bowl pistons? And how do you like them thus far, fuel mileage, oil consumption, sound of the engine etc etc....
I'm looking into using the oval bowl pistons in my build, the only thing I am really all that worried about is, I drive my truck allot, and I'm wondering what kind of longevity the oval bowl pistons offer, sure they're stronger across the wrist pin area, and they open up the piston bowl, but how do they hold up against the test of time/miles???
I just don't want to tear back into it in 80-100k like I would have to with a forged set, I'm guessing Jon's oval bowl pistons would hold up just as good or better than standard MAHLE race cast pistons, but I'd just like to hear a little more feedback before I pull the trigger
Thanks guys/gals
__________________
Jason-
Founding member of the "knows enough to be dangerous" club...
Hey, I'm NORWEGIAN... you try having a SQUARE head full of ROUND thoughts...
  #2
Old 02-25-2014, 02:41 PM
Hot COCOAL's Avatar
Default
Also, the truck is a daily driver and it will still need to tow a heavy load occasionally, as I said before, I drive the truck allot, 100mi a day sometimes more or less, but I drive it every day.
I need to take into consideration mileage/economy, exhaust emissions, longevity etc etc and with this thread, I am hoping to attain that info from you guys running Jon's oval bowl pistons..
If you wouldn't mind sharing compression ratio's, turbo set ups, peak hp and peak boost numbers, that would be really cool too
Thanks again
__________________
Jason-
  #3
Old 02-25-2014, 03:34 PM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default
Malibu????? On here had a set in his truck that he hot shotted with. Idk how many miles he put on but probably more than anyone else has.
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #4
Old 02-25-2014, 06:28 PM
Mpsoldier's Avatar
Mpsoldier Mpsoldier is offline
That just happened!
Default
Pretty sure he was at 80k before the accident
  #5
Old 02-25-2014, 08:03 PM
Hot COCOAL's Avatar
Default
Yeah, thanks guys, I'm hoping he chime's in...
Anyone else??
__________________
Jason-
  #6
Old 02-25-2014, 09:55 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
Default
Malibu has the most I know of, and with a marginal build at that.
__________________
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #7
Old 02-25-2014, 10:27 PM
moparkxracer's Avatar
moparkxracer moparkxracer is offline
Default
I'd like to hear some feed back too. I have a set in mine, Hope to have it running in a few weeks. Hope they hold up.
__________________
Thank you to:
Engine build: Burkett racing
Transmission: be in Evans hands soon
Turbo spec: Shane (S Phinney on here)
Turbo kit built: myself and Landon at Shade tree triples
Tuning: Mark at Danville performance
Fueling: Exergy
And everyone else who made this possible, Thank you!!
  #8
Old 02-27-2014, 11:26 AM
Hot COCOAL's Avatar
Default
Bump it up for some fresh eyes maybe...
Rob/Dustin/Verlon
Isn't Verlon running a set of Ovals in his rig??? I thought he was...
Mark B is runnin a set
Matt is
I know there's many more...
__________________
Jason-
  #9
Old 02-27-2014, 12:06 PM
Cknight199's Avatar
Cknight199 Cknight199 is offline
Default
Quote:
Rob/Dustin/Verlon
Matt is
Verlon busted his crank, not sure if he went with all new internals or not.
__________________
"Relentless" 2007 LBZ CC/SB
Plenty of Air and Fuel
Huge thanks to Custom Auto, and Starlite Diesel
  #10
Old 02-27-2014, 12:30 PM
sickdiesel's Avatar
sickdiesel sickdiesel is online now
Default
Quote:
he did not replace anything else. new lb7 crank and all the rest of the original parts were put back in.
__________________
Dustin
CURRENT: 2017 GMC L5P Denali CC/LB Cognito 4-6" on 22s with 35s
Blackout :06 GMC lbz 4x4 Built motor, HSP twins, DDP Injectors, Self built trans 11.68@118.5 SOLD
OverBuilt :07 Chevy lbz 4x4 Caged and built to the hilt 10.42@134 SOLD
Special thanks to: Mike L, GTrippin, IdahoRob, SDP, ISSPRO, Yukon, Dmaxstore, Airdog, HSP, Hamilton Cams, and Flexalite
LIKE US ON FACEBOOK!
Adrenaline Truck Performance IDAHO ROB 208.685.1000
  #11
Old 02-27-2014, 12:35 PM
mike diesel's Avatar
mike diesel mike diesel is offline
I'm alright.
Default
Youll be replacing forged pistons long before you reach 100k miles...let alone 80k miles. I would say you'll be close to finishing off set #2 by 80k.
__________________
'89 s10 daily driver
  #12
Old 02-27-2014, 12:42 PM
sickdiesel's Avatar
Default
Quote:
depends on the build and builder. and.. luck i think lol
my engine builder has close to 65k on a set of Mahle forged with zero blow by and hes running 1k+ hp. and live in Idaho with cold start frequent.
__________________
Dustin
  #13
Old 02-27-2014, 12:49 PM
Hot COCOAL's Avatar
Default
The crank broke...But I think the pistons were fine....
Quote:
So he'll be reusing the "oval bowl pistons" that he had in there when the crank broke, right?
And didn't you say he had 25k on those pistons?
While it's been seen numerous times, I'd have to say some factors are at play that could be shortening the lifespan of the builds out there using forged pistons.
The forged pistons are a pretty big crapshoot as far as longevity, if you ask me, and require a knowledgeable builder and disciplined heart to use. Really, between set up and how the user uses, maintains the build and understands metallurgy differences between the block, pistons and head, and how often the rig gets turned off and started cold, all play a huge role in the engines longevity, if I were to guess I'd say it's 20x more important/detrimental/crucial to the forged pistons vs cast, but that's a from the hip shot at a guess...
__________________
Jason-
  #14
Old 02-27-2014, 02:41 PM
sickdiesel's Avatar
Default
Ya he is putting the same pistons back in.
__________________
Dustin
  #15
Old 02-27-2014, 03:13 PM
quinton's Avatar
quinton quinton is offline
Default
Got 5k on mine and loving em. Will be building triple turbos for the truck hopefully by summer.
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
