  #76
Old 08-19-2015, 05:06 PM
Cknight199's Avatar
Cknight199 Cknight199 is offline
Originally Posted by Ne-max View Post
I am running a social af9100 with 150% injector .
My cam is around that spec and my compression ratio on my motor is 16:1 and I see 290-300 psi cold, yours seems about right.
"Relentless" 2007 LBZ CC/SB
Plenty of Air and Fuel
Huge thanks to Custom Auto, and Starlite Diesel
  #77
Old 08-19-2015, 05:40 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Thanks. Not to much info out there on actual compression with different ratios.
2006 ccsb Lbz Tow rig
2006 rclb 6.6
  #78
Old 08-19-2015, 05:45 PM
Cknight199's Avatar
Yea I was looking for info the other day but figured since mine were all within 10 psi of each other that I was good
  #79
Old 08-19-2015, 09:39 PM
Fingers's Avatar
Fingers Fingers is offline
Village Idiot
The pressure you will see will depend greatly on the length of the connection to the compression gauge. The longer the hose, the lower the indicated pressure. Each cc of additional volume reduces the effective CR by about 1/4 point and thus the indicated pressure on the gauge.
But.....What do I know.
'04.5 EC/LB 4x4.
Howard Rods w/ oiler hole.
Oval Chambers and valve reliefs cut in Mahle Cast Pistons. 17.5:1
SoCal Stage 2 heads, 3388 Cam, Billet Flywheel, and harmonic balancer.
Danville 68mm VVT Turbo
100 over injectors.
PPE Dual CP3s
ProFab Castflow headers and uppipes.
100 PSIA MAP Sensor
Kennedy dual lift pump.
Dynoed 690 HP / 1200 TQ
  #80
Old 08-19-2015, 09:48 PM
mike diesel's Avatar
mike diesel mike diesel is offline
I'm alright.
Is there a length of hose that is considered to be some sort of "national standard" or "accurate" when doing a compression test?
'89 s10 daily driver
  #81
Old 08-19-2015, 09:59 PM
Fingers's Avatar
Village Idiot
No
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
  #82
Old 08-20-2015, 05:17 AM
Ne-max's Avatar
I like turtles
Correct me if im wrong but the adaptors with the valve in them that hold the pressure should still get you to the same point after so many revolutions? So let's say the first one gets to 220, second, 260 and so on. Just curious John.
2006 rclb 6.6
  #83
Old 08-20-2015, 06:42 AM
JoshH's Avatar
JoshH JoshH is offline
Yes. If your adapter has the schrader valve in the tip, the length of your hose will only change how long you have to crank on it to get max pressure. Crank until the needle stops moving.
06 Silverado 4x4 CC/SB
  #84
Old 08-20-2015, 06:49 AM
catman3126's Avatar
catman3126 catman3126 is offline
Ehhh?.... You don't say?
Putting my motor in now that has 16.5:1 .020 overs. will just be waiting on injectors after Saturday to have fire. can't wait to hear them.
2005 2500HD dmax, CCSB, 4" exhaust, Built motor with Carillo's .020 over 16:5.1 piston with .075 reliefs, Socal 6480 alt fire cam, ported LBZ head's, Exergy 10MM pump Stock lly cp3 on the belt, 400% LBZ injectors, S471/87 compounded with a GT5541R 106MM Fleece billet charger Werhli fab S400 install kit with bridge and piping, Merchant Auto Billet push tubes, Socal Valve springs, Socal valve covers, Socal flex plate, Mishimoto black intercooler, DSP5, Air dog 165,
1986 K10 short bed LQ4/4L80E
1984 CJ7 Powered by a 2000' LS1 5.7L
2015 LTZ Z71 LML, CCLB 3500HD.
  #85
Old 08-20-2015, 07:10 AM
Ne-max's Avatar
I like turtles
Ok. But the adaptor needs to be same length as glow plug with valve at vary end correct? The adaptor I used did not go down as deep.
2006 rclb 6.6
  #86
Old 12-18-2017, 10:35 AM
ctodd36 ctodd36 is offline
Gearhead
Originally Posted by Bigdirtylbz07 View Post
Waiting on the machine shop as well. Running your .020 overs at 15.5:1 a Hamilton 192-200 cam, Hamilton pushrods and springs, heads are getting a valve job, lb7 cryo treated crank, keyed cam and crank, 100% overs. Plus all the mods in my sig. Hoping to hit a good high hp single charger number. These pistons sure do look pretty tho!
Hey what did this set up make?
04 ECSB 2.6SB Puller in Progress
13 CCLB LML Daily
  #87
Old 12-18-2017, 03:33 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Good timing for this to bump back up. I have just tore down our puller engine with 2 seasons on a set of forged .040". 26 pulls and 18 dyno runs. Half of those at 1250hp and half of them at 1500+. They are still mint condition. We will be re-ringing just because.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #88
Old 12-18-2017, 06:01 PM
KRODMAX/KS's Avatar
KRODMAX/KS KRODMAX/KS is offline
Gearhead
60k @ over 750hp+/1400tq+ as a daily driver/work truck dragging a wagon @ over 6k.
06 CCSB
Carrillo's, Fingers cast w 37mm reliefs 17:1, ARP, SoCal 3388AF cam, flex-plate, dampner & springs, M/A push rods, DHD y-bridge, coupler & lock-up box, Danville Billet 68R1, motor mounts & water pump, Energy 10mm, 45% over inj, Airdog 4G 165, AFE, Banks, Mag-Hytec, ProFab Tow-flows, MBRP, Magnaflow, QA1, Cognito, McGaughys, CalTracs, TruTrac, AC Delco Extreme duty rotors, LML 20" & Nitto 305/50/20 420's
Motor built by Danville/tuned by Mark
Mike L Built Trans w billet shafts, hub and "K" converter
758HP/1441ftlbs
  #89
Old 12-18-2017, 06:03 PM
Gearhead
This is great news Iím excited for my new motor to see its longevity with these pistons !
13 CCLB LML Daily
  #90
Old 12-18-2017, 08:49 PM
Fingers's Avatar
Village Idiot
Very nice.
'04.5 EC/LB 4x4.
100 over injectors.
PPE Dual CP3s
100 PSIA MAP Sensor
