  #1
Old 02-17-2018, 09:01 PM
frankenstien's Avatar
frankenstien frankenstien is offline
Default Front output shaft seal leak issue
My front output shaft seal started leaking on my Transfer case about a week ago, figured out it was the front output seal, no big cleaned it up, ordered a seal from Merchant Auto, swapped seals was good for a day ish, here i am a week later and its leaking again. The seal from June only lasted 7 months
I used the special seal installer tool i also got from MA . Not sure what the deal is, it is a 2 piece seal, I am thinking maybe i installed it too far? maybe its rubbing too hard on the seal surfaces? see the pic, you can see the old line
I have checked the vent to make sure its clear, checked transmission fluid level, it is exactly where i left it, just at the "H" in HOT at 175F, T case fluid is about 1/4'' below the fill hole
Thought I would see if anyone had any ideas before i just put another seal in it.
History-I rebuilt the transfer case in June of 2017, new bearing and seal kit from a local driveline shop, also had new rear output bushing replaced and currently has regular vavoline Dex3 in it(same as trans)
__________________
2005 ECSB LLY
5'' exhuast
ATP EFI Live Fass 150 big cat filter
Built Trans w/SC1058
Bumpers built by me
Grade C HG's w/studs
Leveled 295/75/16 Toyo's
  #2
Old 02-17-2018, 11:50 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
Does the output shaft have a groove worn in to it from the old seal? If so, you'll need to split it apart and put a new shaft in, or see if you can install a new seal far enough in or out of normal to avoid the groove.
Sent from my Cat S60 using Tapatalk
__________________
  #3
Old 02-18-2018, 12:19 AM
Default
I didn't see any grooves when I installed the new seal, and it didn't appear that the metal sleeve on the inner part of the seal had spun, as it was fairly hard to get off the shaft.
When I pull this seal out I'll double check again for grooves.
__________________
2005 ECSB LLY
5'' exhuast
Bumpers built by me
  #4
Old 02-18-2018, 12:30 AM
DAVe3283's Avatar
Default
Hopefully you just got a bum seal. I ended up going through 3 rear axle seals before one actually held for more than a couple months.
__________________
  #5
Old 02-18-2018, 12:55 AM
Default
No good, I hope not, I'm going to try and get a GM seal this time
__________________
2005 ECSB LLY
5'' exhuast
Bumpers built by me
  #6
Old 02-18-2018, 06:55 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
Did you put a little oil or grease on the seal and shaft last time Mike?
  #7
Old 02-18-2018, 07:56 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Take some fine emery paper and polish up the shaft. Get rid of any rust, burs or imperfections. Then lube it up well before putting the new seal in
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #8
Old 02-18-2018, 09:12 PM
Default
Quote:
I didn't, I'm guessing I should have?
Would that cause it to leak between the mating surface of the inner and outer part of the seal?
__________________
2005 ECSB LLY
5'' exhuast
Bumpers built by me
  #9
Old 02-18-2018, 09:35 PM
Burn Down's Avatar
Default
It can cause the seal surface to burn and degrade over time. Always lube a lip seal before installing.
If it’s leaking from the bore of the t-case and the outer edge of the seal, it sounds like the bore is damaged or has debris in it. Clean with some scotch brite and brake clean. Put a thin layer of rtv or liquid Teflon sealant on the outside surface of the seal before you install it.
You need to use care when installing it as well. Find a socket that is just smaller than outside of the seal or a piece of pipe. Lots of guys distort the seal trying to use a hammer by itself.
  #10
Old 02-18-2018, 10:31 PM
Default
I cleaned out where the seal presses into the case it self and wiped everything down after I drained the T case. the seal had grease applied to the inner and outer lips when i took it out of the bag, but i didn't add any to it
i think i am not understanding something or mis communicating something.
in the pic looking straight on at the output shaft the gold ring and the black portion where they mate and it is leaking from, ill see if i can get a better pic
the seal I installed has a metal ring that is "pressed" on to the input shaft itself, the outer portion of the seal is pressed into the transfer case it self. so the center part of the seal spins while the outer part of the seal stays in place pressed into the case
also added a pic to show the metal ring inside
__________________
2005 ECSB LLY
5'' exhuast
Bumpers built by me
  #11
Old 02-18-2018, 10:54 PM
Burn Down's Avatar
Default
It came with a wear sleeve then. If it had grease on it that is enough. Sounds like you got a bad seal Mike.
  #12
Old 02-18-2018, 11:04 PM
Default
I hope so, i'd like to not pull my Transfer case again. This is my first go round with a seal like this
thanks for the help, hopefully youngs has a seal in stock
__________________
2005 ECSB LLY
5'' exhuast
Bumpers built by me
  #13
Old 02-18-2018, 11:05 PM
Burn Down's Avatar
Default
I’d try a gm one like you mentioned.
  #14
Old 02-18-2018, 11:08 PM
Default
I am going to call the dealership in the morning, see what they say, i couldnt find a gm part number on any of the larger gm parts sites, gmpartsdirect, partszoneonline etc, not sure what the deal there is
__________________
2005 ECSB LLY
5'' exhuast
Bumpers built by me
  #15
Old 02-19-2018, 06:24 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Iíve had the same problem with 2 different transfer cases now. Both with seals from Merchant auto, and using the merchant install tool. After reading this I think the tool is made wrong and pushing the inner portion of the seal in to far causing it to wear against itself.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
