Old 02-16-2018, 08:12 PM
Philv's Avatar
Philv Philv is offline
Gearhead
Default Trans feels like it's slipping.
My lb7 has 268k miles and the trans every so often it'll feel like it's slipping, but never goes to limp mode of throws a dtc. Also sometimes it'll shift nice and firm other times it'll shift very smoothly. I've also noticed it does it more under half- full throttle, could the TC be failing? I'm running amsoil low viscosity in it.
2001 GMC Sierra 2500HD SLE EC/LB 4x4
Cold air intake
4" exhaust
Wastegate trickery thingy. Lol
Old 02-16-2018, 10:30 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
A healthy stock Allison will never have a firm shift. They will shift smoothly if everything is working right. Firm and hard shifts can easily break hard parts. On a good built Allison, they will shift pretty smoothly even with big HP.
So if you are feeling some firm shifts, it might be a warning sign. I lost a transmission when the trim springs broke (found that out later), and the ECU couldn't control the shifts well. It shifted firm, which I didn't know was a problem, so I ignored it until one day it just broke a shaft on a 30% throttle 3->4 shift leaving work.
Old 02-17-2018, 07:23 AM
Philv's Avatar
Gearhead
Yeah I plan on doing a built trans, but first is fixing my injectors. Looks to be roughly 10-11k I need to put into the truck to be mechanically sound. Hope I can get this job I just applied to cause then I could afford that and more. Lol
Cold air intake
4" exhaust
Old 02-17-2018, 07:45 AM
torqued2dmax's Avatar
Why are you running low viscosity in AZ I would have thought it would be for cold places ?
05 CC/LB DRW LLY Allison
Old 02-17-2018, 08:23 PM
Philv's Avatar
Gearhead
That's what amsoil recommends. My brother also runs low viscosity in his lbz.
Cold air intake
4" exhaust
Old 02-17-2018, 10:03 PM
TheBac's Avatar
TheBac TheBac is offline
If you think it's slipping now, that lift and big tires you're now talking about will kill it. Start saving for that rebuild.
I would've just put Dex3 or Transynd in it and called it a day.
Tom
Old 02-17-2018, 11:45 PM
DAVe3283's Avatar
This x100
The Allison is one of the first clutch-to-clutch transmissions made, and as such it is picky on fluid more than most for holding power and shift quality.
Dex3 is cheap and readily available, and is what I run. It works perfectly, as that's what it was designed for. Transynd works great too, and lasts longer between changes, but is hard to find and expensive, so I don't think it is worth the hassle.
I wouldn't run other fluids in the Allison, even if Amsoil says too. They are in the business of selling their oil, not saving you money.
Old 02-18-2018, 12:28 PM
Viscosity to a point is to protect parts , low viscosity high temps = broken or warn out parts . Do not run WOT in 5th till you are ready to slug your way over to Mike Ls , its on its last leg .
  #9
Old 04-05-2018, 07:20 PM
Philv's Avatar
Gearhead
Just a little update. I did a drain and fill with amsoil torque drive, and the trans shifts much better. I didn't realize how much it was slipping until it grabbed with the torque drive. I just hope when I have the cash and do the 45% sac injectors, the trans won't explode.lol
Cold air intake
4" exhaust
  #10
Old 04-05-2018, 07:29 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Your tuner can keep stock power levels with the new injectors.
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #11
Old 04-06-2018, 03:59 PM
Philv's Avatar
Gearhead
Which tuner will do that? I'm not running one and have been looking for the right one.
Cold air intake
4" exhaust
  #12
Old 04-06-2018, 05:12 PM
zakkb787's Avatar
<thatís not me...
Youíll need to run efilive with those SACs.
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
