  #1
Old 02-14-2017, 11:57 AM
Cknight199's Avatar
Cknight199 Cknight199 is offline
Default Built Truck Part Out
Parting out my LBZ. Going to be adding stuff to this thread as it comes off the truck. Everything has almost 5k miles on them.
-Dual Fass 220 GPH setup. Includes everything needed (including fass's) to run 2 fass pumps where the spare tire goes. Feeds each cp3 with 1/2" fuel line and then has 3/8 return for each cp3 and injector bank. Also has custom injector return lines designed to be attached to 3/8 hose. The only thing this will not include is the sump. $1400 shipped
-2x 12mm Stoker II Double Dragon 120% $1400 each + core shipped
-Dual Fueler Kit w/ harness $1050 shipped
-NX Custom Kit, enough nitrous to add 800+ hp. Pieced together myself, not willing to part out. Includes everything needed to run 2 stages of nitrous except the switch/buttons (but includes relays). Has 2 stages, a lightning 375 and 125, plus a purge. 2x 15lb tanks with billet duel bottle holder. Each tank has a -6an SHO line that merges into a -8an and runs to the solenoids. Line is long enough to run on a longer truck if needed. Has 2x dry feed 90* fittings, 2x 24" SHO -3an to -4an lines, 2x 40 amp relays with harness's. Also will come with a NX 64 Jet holder kit with wrench and the following jets: .030, .050, .070, .093, .110, .136. $1700 shipped
Injector return line fitting
3/8 Return lines running into the distribution block where it becomes 1/2"
__________________
"Relentless" 2007 LBZ CC/SB
Plenty of Air and Fuel
Huge thanks to Custom Auto, and Starlite Diesel
  #2
Old 02-14-2017, 08:11 PM
quinton's Avatar
quinton quinton is offline
Default
You putting it back to stock?
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
  #3
Old 02-14-2017, 08:18 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Default
Quote:
Wandering the same
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
  #4
Old 02-14-2017, 08:25 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Default
Que?
__________________
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Tuned by Aaron Wiebe
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to: Scott@ SDP, Aaron Wiebe @ All In Truck Performance, Lyle & Clay @ Bama Offroad, and Justin Goode @ MBS Diesel
Best time to date: 12.80 @ 110.78
  #5
Old 02-15-2017, 08:10 PM
Hellrazr78's Avatar
Hellrazr78 Hellrazr78 is offline
Gearhead
Default
How many miles on CP3 installed with the kit?
Edit: Nevermind, if I'm reading right, there is no CP3 included with kit.
__________________
Murdered CC/SB LBZ Duramax/Allison, Modded Stock Airbox, N-Fab Six Step, MBRP 5" Straight Pipe,EGR Blocker, EFI Live By Rob Coddens, Socal Overhead Mount, Spek Boost + EGT Guages, Cognito 4" Lift, HD Tie Rods, 20" KMC Ambush, 33" Toyo MT's, Big Dipper Suncoast Stage IV, Precision Converter, Airdog II 165.
  #6
Old 02-16-2017, 08:03 AM
DefiantArms's Avatar
DefiantArms DefiantArms is offline
Limp Mode Cowboy
Default
"2x 12mm Stoker II Double Dragon 120% $1400 each + core shipped"
__________________
John
2005 Chevy 2500 LLY CCSB "Nyx"
5" Exhaust, , 20x10 AF Burnouts 305/55 BFG's
EFI Live By Mr. Idaho Rob
You are not a beautiful or unique snowflake, you are the same organic decaying matter as everything else.. -TD
  #7
Old 02-16-2017, 07:35 PM
Low366Dmax's Avatar
Low366Dmax Low366Dmax is offline
Pin it to win it
Default
Will you break up the nitrous kit?
__________________
07 CC/SB LBZ
Built motor
Fingers
Carrillo rods
9100af
250% exergy
12mm s&s
Air dog 165
Bullseye built 468 with a bullseye tct 83
  #8
Old 02-17-2017, 12:13 AM
Cknight199's Avatar
Default
Quote:
Possibly, pm me what your looking for
__________________
  #9
Old 02-17-2017, 12:16 AM
Cknight199's Avatar
Default
Dual fueler kit sold.
__________________
  #10
Old 02-24-2017, 05:42 PM
Cknight199's Avatar
Default
Bump.
Nitrous kit $1600 shipped
Dual Fass setup $1300 shipped
Stroker pumps $1250 ea. Shipped + core
__________________
  #11
Old 03-10-2017, 09:45 AM
hipp11B's Avatar
hipp11B hipp11B is offline
Default
Check your pm's
  #12
Old 03-10-2017, 08:23 PM
Limp Mode Cowboy
Default
Quote:
Originally Posted by Cknight199 View Post
Bump.
How much for a stroker pump without a core?
__________________
John
  #13
Old 03-10-2017, 10:36 PM
Cknight199's Avatar
Default
Quote:
Originally Posted by hipp11B View Post
Check your pm's
I didn't see a pm from you...
__________________
  #14
Old 03-11-2017, 06:38 AM
hipp11B's Avatar
Default
Damn, looks like it won't completely sent to you. Sent you a message on Facebook messenger.
  #15
Old 03-11-2017, 03:40 PM
Cknight199's Avatar
One pump sold. One still available
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
