  #121
Old 02-14-2017, 08:24 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
Stock lb7 flow 1080 ml/min LML flow 880 ml/min. That is a static number. Now in a assembled form lml injectors do flow more fuel. It is because if their design and function that allows that.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #122
Old 02-14-2017, 12:07 PM
bigmackmiller's Avatar
bigmackmiller bigmackmiller is offline
Default
Was it determined what a 45% sac is to a VCO?
__________________
2007 LBZ EXT CAB S/B 4x4 SLT
4' MBRP SS
  #123
Old 02-15-2017, 09:52 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Quote:
Where at? At idle I have found they flow slightly less fuel than a stock vco, but that quickly changes as pressure goes beyond 40mpa. I only have the basic flow sheet on a set which says at 160mpa and a 1700 pw, they should flow in the 165-168 mm3 of fuel(I want to say stock lb7's were in the 120 range at the same pressure and pulse).
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #124
Old 02-17-2017, 04:01 AM
elcaminonut69 elcaminonut69 is offline
FNG
Default
I have been double dosing my Suburban with Opti-Lube XPD and the smoking is pretty much gone but the smell is still there. Someone please correct me if I'm wrong blue smoke at idle is leaking tip and hard or no start when warm is the injector returning to much fuel pass the ball and seat. I have never had a hard start problem just the blue smoke. My Bosch reman injectors were installed at 168,000 and I now have 232,000. Way to soon to put out another $3000 plus on parts. These injectors were installed in October of 2015. My better judgement says to put new injectors in with the SAC nozzles but I think I'm going to just do nozzles as I am curious . I know it would be a lot of extra work if I have to pull them back out. Might do a return test while I'm in there to make sure.
  #125
Old 02-17-2017, 08:41 PM
LEGALLY INSANE
Default
Quote:
Yes, bad nozzles can cause blue smoke from a diesel. High return rates can cause a hard or no start as well as a hung injector staying open. I started to roll the dice on nozzles as mine had 71K miles on them, but in the end I opted for complete units as I know 99% of the shops out there don't have the equipment to balance them, and I wanted to make sure they were as close as possible. And at $1K for a set of SAC nozzles, they would have been an EXPENSIVE gamble.
__________________
  #126
Old 02-17-2017, 09:08 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
Mine has a horrid eye watering diesel smell and it's been hazing bad at idle, like you can see it plain as day, so I'm guessing I'm gonna be due for injectors soon?? Truck has 95k on it.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #127
Old 03-05-2017, 09:53 AM
FNG
Default
I Hope I just cured my injector problems with a 2006 LBZ lol. Now to get the time to swap it.
  #128
Old 03-10-2017, 04:18 PM
FNG
Default
I went ahead and ordered tips. I'm going to try it and see how much it helps. Hope to put them in this weekend if I get time. It's smoking to bad and looks like its going to be another month before I get time to swap the LBZ in.
  #129
Old 03-11-2017, 08:18 PM
LEGALLY INSANE
Default
I will say I've been working quite a bit on tuning, and have learned ALOT. These sac injectors require pilot changes imo. I tried adjusting the pulse and timing tables all over the place, but until I started making some pilot changes, I never could get my throttle feel/control where I wanted it at slow speeds. I'm still testing changes to them as I have found I can get it to run good hot, but once it cools off, it's a different animal. So now I have to wait for it to cool off netween changes so I can balance the changes to get good throttle control/manners hot AND cold while keeping it running smoothly. It's taking me some time though.
__________________
  #130
Old 03-13-2017, 03:49 PM
FNG
Default
Well I got my tips installed over the weekend and what a difference. My balance rates are like Fermanators although they are starting to even out and my CFR went to 10 mm3. It runs a whole lot better, smokes pretty good on launch but drops quickly to a light haze and spools super fast but like Fermanator my boost has dropped off on the top end. I installed the new tune before I drove it so I can't comment on how they act on a stock tune. Originally my CFR bounced between 2 and 3 and smoked horribly and now it's at 10 occasionally dropping to 9. Best of all the blue smoke is completely gone
  #131
Old 03-13-2017, 04:15 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Quote:
Sounds like a cold deleted lmm to me
__________________
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
  #132
Old 04-01-2017, 04:00 PM
Bustedknuckles's Avatar
Bustedknuckles Bustedknuckles is offline
Honey Badger
Default
Where did you get the nozzles? My truck just started hazing at idle. Still starts and runs perfectly with no fuel in the oil. Less than 30k on the injectors (i think) and I'm willing to take the gamble as i can swap injector nozzles in a evening with a buddy or 2 helping so I would rather do that than spend $2500 on injectors!
__________________
04 lb7: 06 front clip, EPR s366, 30% over injectors, ARP head studs, Idaho-Rob tunes, airdog, PPE trans, Precision ML converter, etc......
  #133
Old 04-03-2017, 02:52 PM
Brent@LDS's Avatar
Brent@LDS Brent@LDS is offline
Default
He would of got the nozzles from us.
__________________
Looking for LB7 Injectors?
Check these prices out!....
......... Lincoln Diesel Specialties .........
Phone: 920-361-7700
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
