Old 02-17-2017, 08:45 AM
Frankin_truck's Avatar
Frankin_truck Frankin_truck is offline
Default Compression ratio
What's everyone's thoughts on compression ratios for a full blown sled pulling engine dedicated puller. Been doing lots of research this topic seems to be lots of mixed answers. Some say high compression is free horse power but hard on parts others say stay low and run more boost. I know statics and dynamic compression ratio play a big part in this. I was thinking 15:1 would be good. Open to suggestions
2007.5 lmm, Built motor, Built trans, Danville 72vgt over 484, 100 overs, dual cp3's and so on..........
Old 02-17-2017, 09:34 AM
gmduramax's Avatar
Shits broke
I would say since it's a dedicated pull truck and you'll be limited by turbo I would run high compression.
10.98@124mph
Tailgate Crew Member #1
Old 02-17-2017, 09:45 AM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
I like em higher also. 16:1 is lowest I've gone so far.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 02-17-2017, 10:04 AM
Awenta's Avatar
Awenta Awenta is offline
What class?
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
Old 02-17-2017, 11:25 AM
its a 2.8" class I run a gt55 bushed down charger bushed down.
Old 02-17-2017, 11:42 AM
Blackmax123 Blackmax123 is offline
Mine is 15.5:1. That's what Mark Brovaik recommend when I built my motor. I did loose 40hp gained a little torque over my stock motor with air and fuel the same. That's was also with a stock appearing Danville 2.5 vgt charger.
Sent from my SM-G935V using Tapatalk
2013 Chevrolet 3500hd duramax loaded ltz cc/lb dually (tow pig)- danville 2.5 stg1.5 charger, 5" afe exhaust, wehrli charge piping and egr delete,wehrli stainless downpipe and danville tuned. 5" zone lift, 315/70r17. 2" hub centric front spacers 3" hubcentric rear spacers between duals.
2008 Chevrolet 3500hd duramax ltz cc/lb dually (homemade handgrenade) built motor by me, Built tranny by me, big exergy pump and s&s over it, large exergy lbz injectors, ac delete, custom Danville s400 true 2.5 charger, roll pan, 8" single stack, custom hitch and a few more pulling goodies.
2015 Vw passat tdi sel premium blacked out(old lady's ride)
2014 chevrolet cruze diesel work car.
Special thanks to Danville Performace & Limitless Diesel
Old 02-17-2017, 11:58 AM
Mark06 Mark06 is offline
FNG
15:1 would give you most reliability at high boost levels.
Old 02-17-2017, 01:56 PM
Talked to a few reputable people in the duramax community 15-16:1 seems to be the general consensus. Turbo size seems to have a lot to do with
  #9
Old 02-17-2017, 04:04 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
I run 16.5:1 with around 85-90#'s boost from the triples. Blew headgaskets with standard H11 studs. Went to 625's and Oring heads, no problems for the last 10k miles
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #10
Old 02-17-2017, 06:33 PM
Dan@PPE's Avatar
Dan@PPE Dan@PPE is offline
Diesel Enthusiast
How do you fit those in your pants??
2500HD CC/SB LB7 2 Wheel drive 950+ RWHP
11.17@126 in the 1/4 with a 7.2x@100 in the 1/8th.
NEW BEST in the 1/8th 6.95@102, 10's Here I come!!
2500HD CC/LB LB7 4X4, Towpig
2500HD RC/LB 4X4.............. 9 seconds of fury!!!
Pushing the D to the MAX........
  #11
Old 02-17-2017, 08:28 PM
Harbin_22's Avatar
Turning it back up!
Haha, I honestly just beat on it all the time and hope for the best lol. This motor has made it a rough 15k miles and still going strong.
10' CCSB
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #12
Old 02-18-2017, 02:05 PM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
Not to go against the grain but my build wound up with 14/1 forged Arias cause I got some good deals on here for the Pistons , cam , lifters and several other parts from a member that was getting out of the sport. Flirting With Disaster had sold him all the parts I believe . I was a little concerned at first but once I had it all together and running I can say I am very happy with the results . It's very responsive and pulls extremely hard . The only thing I notice is that the engine needs to come to operating temperature in order for it to run its best . It has a white smoke haze till it warms up a bit then it's clean . Tune 1 is clean driving thanks to Mark Broviak. I'm doing 3.42 gears in it in the next month or so to see if I can get it deeper into the 9s on fuel only . Best time to date was on Tune 4 spinning a bit out of the hole . Gentleman at FWD said the lower compression would allow for a better air charge .
06! GMC Sierra RC Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, ARP 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TrRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergys w/185% MS 8 hole nozzles ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box, 18x9 Raceline Assualts Hooiser Drag Radials 325/45/18s . TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx Best 60'---1.44. Best 1/8---6.39@105.92. Best 1/4---9.978@136.39
  #13
Old 02-18-2017, 02:46 PM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
I think the forged pistons expand more when getting to operating temp than cast do. I noticed also that my motor with Mahle forged pistons run cleaner when pistons warm up a little.
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #14
Old 02-18-2017, 02:49 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
No protrusion required? Does the bushing need to be against comp wheel?
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #15
Old 02-18-2017, 03:45 PM
Street rodder
Zap your 100% correct .
