  #16
Old 03-20-2018, 10:49 PM
DylOrr's Avatar
DylOrr DylOrr is offline
Gearhead
Default
Put in a tested good lbz cp3 and all seemed well at first. Same symptoms again except it doesn't smoke when its idling now. I'm going to double check the fuel to be sure it didn't get bad fuel, water, or gas in it. It's my dad's truck so who knows. But I'm going to throw a set of injectors in if the fuel all seems fine.
The truck will start right up after sitting overnight or even for a couple hours. It eventually starts dropping rail and dies.
__________________
Dylan
2015 LTZ- baby tune, 4" with muffler
  #17
Old 03-21-2018, 05:05 AM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
I assume you drained fuel filter water separator into a white container to check for stuff first ! Then did you change the injector return regulator , it may be held partially open by something or an internal malfunction ! Good luck !
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #18
Old 03-22-2018, 08:20 PM
TxDmax88 TxDmax88 is offline
FNG
Default
More then likely injectors, I had a replaced my cp4 with a new cp3 in my LmL having similar issues. Thought it was the pump but I had a few injectors returning too much fuel. Try testing the return on your injectors, no more then 3 ml in 15 seconds or cranking.
This might help you: https://oregonfuelinjection.com/serv...l-diagnostics/
__________________
2015 GMC Denali HD Dually
EFI Live
S&b intake
4" straight pipe
EGR and DPF Delete
AFE DFS 780 lift pump
  #19
Old 04-03-2018, 09:25 PM
DylOrr's Avatar
Gearhead
Default
Forgot to update. Did injectors and a return line setup and that fixed the issue. I went ahead and dropped the tank and there was a lot of metal in the tank and fuel basket. I would definately reccomend doing this if the cp4 goes.
__________________
Dylan
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
