  #46
Old 02-19-2016, 07:28 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
What do you consider "warm egt's"? Are you still on stock injectors?
Is your turbo one of Fleece's? Or is it the Borg billet wheel?
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #47
Old 02-19-2016, 08:07 PM
PACougar's Avatar
PACougar PACougar is offline
Default
The top end power is fantastic. I did have to down shift under those circumstances, but I was running a Socal 9100 I imagine it wouldn't have been nessacary with a reasonable cam.
__________________
2004 LB7 EC/LB 2WD Dropped 6" in the front on coil overs and 7" in the rear on 18"s, Hellwig front and rear sway bars. Caltracs traction bars.
Socal Diesel built bottom end, FI S480 Billet wheel and race cover, RDL Headers and pipes,
Dual Cp3(1 modded and 1 stock), Exergy 100% over injectors,
Socal Diesel injector clamps, Socal Stage 2 Heads/ARP Head Studs
Suncoast GMAX-5 plus some billet built by my best friend Dave(He's a Badass like that), 1058 converter, MikeL Cooler
Mag-Hytec pans on Tranny(Scraping a little) and Diff
Custom modified MBRP exhaust i.e. it dumps in front of the rear tire(Also by Dave). Never had a cat
Labonte Motorsports water/meth, AirDog II 200
Custom 5" Intake Pipe w/AFE Filter, BD Cool It Intercooler,
EFI Live DSP5
Torsen limited slip(POSI), Gauges
DON'T PURCHASE FROM INDUSTRIAL INJECTION UNLESS YOU ENJOY GETTING SCREWED!
  #48
Old 02-19-2016, 09:52 PM
kiwilml's Avatar
kiwilml kiwilml is offline
Default
Yes I'm still stock injectors and when egt's get over 1500 I think that's hot enough and wish it wasn't that high but I know people run them a LOT higher lol..
And I got it all from Wcfab so not sure where turbo came from. It is a Borg Warner though. I kinda though it was from fleece but could be wrong.
I will say that I love how my truck runs with it, still pulls really good at top end like was mentioned..
__________________
2016 Chevy CCSB.. Currently stock except for EZ Lynk tuning by PPEI with a 5" flo-pro exhaust..
  #49
Old 02-19-2016, 10:39 PM
IOWA LLY's Avatar
Yes, its really me
Default
Thanks for the info fellas. I really appreciate it.
I wonder if the egts are lower with the 87 turbine.
I'm not sure about the lmls, but I know on the older trucks it's almost impossible to keep high rpm egts low with a max effort tune using stock injectors. Twins do the best job of that but they still creep up at high rpms.
I wish some more people would chime in that have ran this turbo and towed with it.
__________________
2003 GMC CCSB LLY
  #50
Old 02-20-2016, 07:52 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
87 turbine would help egts.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #51
Old 02-20-2016, 11:42 PM
DetailsUnlimited's Avatar
DetailsUnlimited DetailsUnlimited is offline
Default
I ran the FPE 72 for a bit. Great power. 11.24 @ 122. 7k lbs. changed my shift points while driving and towed the 8k lbs TT. While towing I would manage the egt's by manual downshifting. You get use to it. Never seemed to be a issue. Fleece had my truck for two weeks in Indy so I drove the suburban with trailer to get the truck and race. Loaded the burb on the trailer and drove the truck back to Arkansas. 10hrs straight with no issues.
__________________
Gaylon(Tark)Tarkington
Trucks Name: Consistantly Inconsistant!
06 LBZ CCSB
Built motor
Team Hole in the Piston "RIP" 10/21/11
2011 NHRDA Ennis, Tx Sportsmen Champion
2011 NHRDA Sportsmen World Champion
2014 TS Performance 12.0 Index
New ride - 07 3500 Duramax Van
  #52
Old 02-21-2016, 10:00 AM
IOWA LLY's Avatar
Yes, its really me
Default
I'm not familiar with the 472. Does it use the same 87 turbine as the 468?
__________________
2003 GMC CCSB LLY
  #53
Old 02-21-2016, 05:05 PM
Default
Yes, 72/87 .90
__________________
06 LBZ CCSB
Built motor
  #54
Old 02-21-2016, 07:35 PM
IOWA LLY's Avatar
Yes, its really me
Default
How were egts with the 472? Towing, and racing at that power level?
__________________
2003 GMC CCSB LLY
  #55
Old 02-21-2016, 10:12 PM
Default
700hp tune 1 towing egt's stayed around 11-1300 65mph. Racing I can't give a honest answer. But it never turns my isspro red warning light on which is set at 2000.
__________________
06 LBZ CCSB
Built motor
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
