Old 02-06-2018, 04:18 PM
dylon333 dylon333 is offline
Gearhead
Default Lbz a40 tune
Anybody have a 10377105 trans tune for a stage 1 trans? Noting crazy just something to take better advantage on the trans?
07 lbz ccsb deleted, intercooler pipe, Rebuilt trans with unknown upgrades (done by P.O.) 4in to 5 in exhaust.
Old 02-06-2018, 04:55 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
What is a stage 1 trans?
2003 GMC CCSB LLY
Built by me, tuned by me.
Old 02-06-2018, 05:04 PM
Chevy1925's Avatar
You donít tune the trans to what itís built for, you only tune shift points to what you like or what you do with the truck. This is where things get very different from a dodge
James
best time to date: 12.39
Tailgate Crew Member #4
Old 02-06-2018, 07:50 PM
Gearhead
Was told it had bigger converter, shift kit, and upgraded clutches. Trans shop said it was their stage 1. Came in the truck so all I can say for sure is, the converter is red, and the trans can take some abuse.
So I can just run the stock tune? Your spot on, used to them dodges. I took Josh h early lock up tune and played with it. Man that'll be fun at the track but no way to dd that. The truck came with a tune that was locked so I assumed I needed to get another tune for it.
Old 02-06-2018, 07:57 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
I would suggest ppei trans tuning. It will make your stage 1 trans hold a extra 250hp. So that would make it a stage 2 in a indirect way.
2006 ccsb Lbz Tow rig
2006 rclb 6.6
Old 02-06-2018, 08:17 PM
IOWA LLY's Avatar
Yes, its really me
This ^^^^^
2003 GMC CCSB LLY
Old 02-06-2018, 09:59 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Originally Posted by IOWA LLY View Post
This ^^^^^
Wait, what? I'm a bit slow tonight, but I thought only the LML and newer Allison had any control of line pressure (and therefore clutch holding) through a tune?
Old 02-07-2018, 06:27 AM
IOWA LLY's Avatar
Yes, its really me
Sorry. Both posts were sarcastic humor.
I get so tired of the ďstageĒ this and that. Itís just stupid.
2003 GMC CCSB LLY
  #9
Old 02-07-2018, 04:39 PM
Gearhead
How would you like me designate it. I mean that's how every trans builder does it?
  #10
Old 02-07-2018, 06:05 PM
zakkb787's Avatar
zakkb787 zakkb787 is online now
<thatís not me...
Basically from what youíve said your trans is pretty close to stock. Here the trans is either built (gone thru, triple disk converter, better clutches, etc etc) that hold 700 or more hp or stock. I wouldnít trust more than 400 ish with what youíve described.
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #11
Old 02-07-2018, 06:36 PM
Chevy1925's Avatar
They are just being grouchy cause it’s a common thing and gets annoying. There really is no stage for an Allison, the way some mfg sell them that way is to give you a warm fuzzy feeling about what it can hold and an easy way to sell you something. Really, it’s majorly inconstant cause not every place that calls a trans a stage 4 is built the same. a trans should be built for what you plan to do, not based off a stage.
Since you are on a stock charger, I wouldnt change shift points but you can play with them if you want. Just FYI, tow/haul mode as it is written in EFILive is actually 4low. Can’t remember what one is actually tow/haul mode but search it here and look for ferminators posts.
I would also leave the lock up stuff stock because we don’t know what kind of converter you have. Making it lock up under wot by 2nd gear may cause it to die sooner if it can’t hold the power.
James
  #12
Old 02-08-2018, 04:35 AM
Gearhead
Good enough, I'll just leave it all alone then. it shifts decent now. Thanks man
