Old 07-03-2011, 03:18 PM
paint94979's Avatar
paint94979 paint94979 is offline
Beer Nazi
Default Engine noise
After driving it pretty easy came to a stone and the engine is knocking... No smoke. It is about 100* today and the truck never sees this kind of heat. Could it be fuel knock of some sort? I do not have my laptop with me either so logging isn't possible right now
LLY's are COOL
HUGE Thanks to Chris, Mike L., McRat Racing, Total Performance Diesel, PPE, Trent, Wicked Diesel, Mike, Henry of Creatures of the Night, Exergy Engineering and the rest of Team Salad<--My Tailgate's Always open for all of you!!
11.84 @ 115
Tailgate Crew Member #2
Old 07-03-2011, 03:43 PM
custom8726's Avatar
custom8726 custom8726 is offline
Sounds like you need my built motor sooner then later On a serious note its hard to say without any logs or hearing it in person, but if all your gauges are reading normal and no excessive smoke out of the crank case or exhaust I would just run it and see if it goes away.. (Obviously check your oil/fluids) Good Luck!
Old 07-03-2011, 04:06 PM
gmduramax's Avatar
Shits broke
Its probably 9 quarts of oil low
10.98@124mph
Tailgate Crew Member #1
Old 07-03-2011, 04:09 PM
paint94979's Avatar
Beer Nazi
Oil psi is good... Recently replaced the water pump and we over torqued the nut on the balancer doubt that has anything to do with it
LLY's are COOL
11.84 @ 115
Old 07-03-2011, 07:14 PM
paint94979's Avatar
Beer Nazi
What are the signs of bad fuel?
LLY's are COOL
11.84 @ 115
Old 07-03-2011, 08:20 PM
paint94979's Avatar
Beer Nazi
stuck injector?
LLY's are COOL
11.84 @ 115
Old 07-04-2011, 04:48 AM
dmaxfireman's Avatar
dmaxfireman dmaxfireman is offline
'Can do' kind of guy
forest through the trees brother, did you ice pick injector 5 harness ?
the rest of those values are a little funky see if they get better after the ice pick
-Fireman
Old 07-04-2011, 03:48 PM
duratothemax's Avatar
duratothemax duratothemax is offline
<--- slippery roads
piston skirts self-clearancing themselves on the crank?
2012 Denali - R&D testbed for upcoming new products.....
2005 Silverado LT - Blown up/broken too many engines and parts to care about making it fast anymore, so its back to mostly stock - The best names in the industry for parts/advice/help...MikeL.Guy-SoCal.Rob-ATP.Evan-Limitless.McRat.BigDipper.Bobo.Tony-RRDP.Fingers.Eric-MA.EFILive...
BT DieselWorks, LLC - EFILive tuning - Duramax/Allison/gasser STANDALONE HARNESSES - Allison lockup controllers - Allison tapshift kits - Digital DSP-5 switches - full assortment of great electronic improvements and gadgets for your GM truck/SUV
All products available for sale through our online store at www.btdieselworks.com
Be sure to "like" us on Facebook at www.facebook.com/BTDWorks
Be sure to "follow" us on Instagram @btdieselworks
  #9
Old 07-04-2011, 04:52 PM
ecc_33's Avatar
ecc_33 ecc_33 is offline
Junior Member
Oh yea babe, I know this all to familiar now
02 extra cab long bed
Thanks: CRANK IT UP DIESEL PPE ATS SUPER DIESEL MCRAT RACING
CREATURES OF THE NIGHT BES RACING
Carrillo rods, Hamilton valve springs, ATI damper, 60% bigger nozzles, head studs, S475 turbo, 4inch lift kit, ATS dual fueler, ATS Tranny,Bunch of SD parts,lobonte water injection, AD 165gph,
best time 11.63 at 116 49,200 miles
  #10
Old 07-04-2011, 05:23 PM
ChevyDieselLLY's Avatar
ChevyDieselLLY ChevyDieselLLY is offline
Whats A Budget???
Hope its nothhing bad nick
Justin
04.5 Chevy LLY EC SB LT Mostly Stock..... SOLD
Now I drive a minivan
U.S.M.C. 2003 - Present
  #11
Old 07-04-2011, 06:43 PM
TheBac's Avatar
TheBac TheBac is offline
Here's hoping its something simple Nick.
Tom
  #12
Old 07-04-2011, 08:00 PM
paint94979's Avatar
Beer Nazi
Thanks guys it is def. an injector issue, as I pulled up my driveway I heard injector rattle coming from the driver side and low and behold #5 is +15... What is "ice picking"?
LLY's are COOL
11.84 @ 115
  #13
Old 07-04-2011, 08:09 PM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is offline
yerp
Do a search its a trick for fixing lly injector harnesses but I thought it was mostly 2 and 7 that were the problem but I could be wrong.
Limitless Diesel Performance
413-770-3585
  #14
Old 07-04-2011, 08:12 PM
paint94979's Avatar
Beer Nazi
I just found it but how can I know for sure the harness is the problem?
LLY's are COOL
11.84 @ 115
  #15
Old 07-04-2011, 08:30 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Sounds like to me the injector is sticking open if your +15,not sure if that is alot but a buddy of mine had injector sticking issues in his lb7 sounded just like a rod knocking.its done it to him 3 times that i know of.He tripples his power service in the fuel and it goes away
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
