Go Back   Duramax Diesels Forum > Chassis, Suspension, Appearance > Wheels & Tires
View Poll Results: which wheel would look best on my 02?
Monster Energy 538bm (top left in collage) 0 0%
Scorpion Sc19 (top right in collage) 2 9.52%
Scorpion Sc16 (bottom right in collage) 1 4.76%
I like tacoes... 18 85.71%
Multiple Choice Poll. Voters: 21. You may not vote on this poll
Thread Tools Display Modes
Old 03-05-2017, 09:57 AM
REW_388's Avatar
REW_388 REW_388 is offline
FNG
Default Need opinions on wheel quality...
I am finally upgrading my wheels on my 02 Dmax to 20x12. I have narrowed it down to 2 or 3 options. I was curious if anyone could give me some reviews and the wheel finish quality of Scorpion wheels and Monster Energy (same as TIS I believe) wheels. Just don't wanna spend all this money on wheels just to have them look like crap in a couple years.
RIG-2002 CC/SB 2500HD
SUSPENSION-Rancho 4 in. Lift -Tie Rod Sleeves -Brace Kit -Air Bags TRANSMISSION -Built by Tim Hecker -GMax 5 Pac -Precision ML Converter -MikeL Pump Rub Wear Plate -Transfer Case Brace PERFORMANCE- 60% Over Injectors- AFE Pro Dry S Stage 2 Intake -AirDog II -Banks BigHead Wategate- SDP Batmowheel- EFI with CTS Insight- ARP Head Studs- Banks Technicooler
Old 03-05-2017, 10:47 AM
ChrisPerry's Avatar
I don't know anyone using any of those wheels so no comment on finish quality, but I do like tacos.
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
Old 03-05-2017, 01:52 PM
Awenta's Avatar
Awenta Awenta is offline
Fuel or force
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
Old 03-05-2017, 02:43 PM
REW_388's Avatar
FNG
At least you're honest Chris lol
Arek there are 0 Forces I like and the Fuels I like I can't afford or half the diesel guys around here are running them.
Old 03-05-2017, 03:06 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
Honestly I think there a lot of better wheels out there then the ones you picked. Do you truley like those wheels? How much time have you spent looking? So many options out there for you and your truck.
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Tuned by Aaron Wiebe
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to: Scott@ SDP, Aaron Wiebe @ All In Truck Performance
Best time to date: 12.80 @ 110.78
Old 03-05-2017, 03:10 PM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
I really think there are much better options out there for rims. And depending on what you plan on running for backspace you may have a hard time clearing any decent sized tires with 20x12's and 4"lift.
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, tuning from Arron at All in trucks.
Old 03-07-2017, 10:57 AM
REW_388's Avatar
FNG
Spent several weeks looking and these are the ones I like best that no one else in my area has.
Old 03-07-2017, 11:00 AM
REW_388's Avatar
FNG
Also I did some measuring and talked to several shops and I should be able to clear 35s. Gonna need to do a little bit more fender massaging but not a lot more. I'm already clearing 35x13s and my current wheels have 4.25 back spacing.. Just not as much front lip of course.
  #9
Old 03-16-2017, 12:10 PM
WVRigrat05's Avatar
Wound for sound
No clear coated or gloss wheel is gonna hold up in salt or dirt roads without being knicked or scratched.
I run fuel kranks, I don't give a **** what anyone else has, because my wheels are better just because they're mine anyhow
Reger
100k miles. Piston eater.
  #10
Old 03-16-2017, 02:34 PM
kubitza123's Avatar
kubitza123 kubitza123 is offline
Bottom left
  #11
Old 03-16-2017, 03:23 PM
ALLY Fox's Avatar
ALLY Fox ALLY Fox is offline
Old Man Truck
Don't have a dog in the fight. If I can't tow heavy with a particular wheel style, it's not going on my truck. Haven't managed to break my H2s yet....
Basic old man '04.5 Sierra SLT long CC tow rig, EFI Live by Rob, trans by Mike L, Magnaflow DP, Airdog II 165, Ride Rites, LBZ MP, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W GN & Companion, Prodigy P3 and some other stuff but I can't remember what it is...
  #12
Old 03-16-2017, 03:31 PM
WVRigrat05's Avatar
Wound for sound
Mine are rated at 3250 a piece.
Reger
  #13
Old 03-16-2017, 04:46 PM
Awenta's Avatar
I almost got kranks but ended up with fuel crush. I also don't care if anyone else has them I'm getting them for myself.
Their rated for 3500 I believe.
Arek
EFI by Kory
  #14
Old 03-16-2017, 05:47 PM
WVRigrat05's Avatar
Wound for sound
Yep, 3,500 lb your right, I just looked it up.
Reger
